AS9102 Paragraph 5.3-5 - Lapse in Production - FAI Requirements
WCHorn
Rubber, Too Glamorous?
Paragraph 5.3-5 of AS9102 requires the organization to complete a full FAI when there has been a lapse of production for two years. Please consider the following scenario.
The organization makes products in 2010 and has a customer-approved FAIR on record. Product was subsequently manufactured for another order in 2011; there was an overrun that was stored in finished goods inventory. In 2014, the customer orders the part number. The organization is ready to supply product from finished goods but more than two years have lapsed in production. Can the product be shipped without a full FAI since the product was manufactured in the two year window that existed at the time of manufacture? The product does not exceed shelf life requirements and the customer has not revised the drawing or associated specifications.
Michael_M
Re: AS9102, Lapse in Production
We ship parts that have been sitting in 'stock' that were manufactured within the 2 year window but are now outside the time frame. We have the ability to prove (certifications, computer system, etc) that the parts were in fact manufactured years before.
In some cases, we have parts sitting in deburr (not finished) and a few years go by. In this case, to be safe, I will make a new FAIR as the parts were not finished going through all manufacturing steps within the time frame.
silentrunning
Your customer will be the one that will have to answer that question. I have had customers go both ways. We often run stocks on military parts and sometimes they set more than the 2 year maximum. Some customers will let me ship with copies of the old FAIR and some want all new documentation.
P
PaulJSmith
Yep, ask your customer. You should be able to ship, so long as you can document the production during that window. If they ask for a new one, though, you just do a new one. That's how it goes.
WCHorn
Thanks for your responses. If I have to ask the customer, then it seems AS9102 needs a bit of clarification, since this situation probably occurs frequently for specially designed consumables.
The customer said "no FAIR required" in this circumstance, which I believe is the logical response.
Golfman25
I'm not an AS guru, but the term "production" seems to be operative here. If you ship parts from stock, you still have the lapse in production.
What if you did the FAI on the in stock parts. Then started production 6 months later. If you use the FAI from the stock parts to cover your lapse, you could miss something from the new production run. Seems to me, you want to verify the new production after sitting for years to makes sure it is still working.
Michael_M
AS9102 FAIR is different than in process inspection. Technically speaking the AS9102 FAIR only applies to a single part as that is really all your measuring for the FAIR.
Jimw1954
I've always interpreted this to mean that any NEW production that is done with more than a 2 year lapse since the LAST production will require a new FAI. I don't see why you would need a new FAI for stock that you have already performed an FAI on previously. You can, at your discretion, perform one to verify the stock. I've always considered that the purpose of the FAI is to verify you have the capability to meet all print requirements. Of course, the customer has the final word, but I've never had a customer ask for a new FAI on parts they already have one on.
Rob1899
I agree with the others, it really depends on your customer. In my experience, our customers require a new FAIR if a new production run has happened outside the 2 year window. We have parts in stock that were ran 3-4 years ago that have a valid FAIR corresponding to the lot of parts in stock and our customers will accept that first article as there was no new production run and the traceability is there.
We have a large Aerospace customer that finally allowed us to mfr. parts and ship "without" a FAIR per AS9102 providing a) the same Customer revision is in effect as last time ; same tooling was used and b) We have not had any internal process revisions to the particular part number in question. Granted for the most part we use either "hard tooling" or a laser cutting program.
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D AS9102 - Assembly FAI for Use As Is or Repaired Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Conformal Coating & AS9102 - Is conformal coating material a COTS part AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B AS9102 COTS Form 1 vs. 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 - Completing Partial FAI's for Baseline Part Numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B AS9102 Supplier Flow Down Method AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
L AS9102 Form 1 Section 13 Detail or Assembly Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
W FAIR to AS9102 additional documentation Document Control Systems, Procedures, Forms and Templates 5
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
R AS9102 - Are FAIs against a Customer Red-Lined Drawings Allowed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9102 - What needs to be Bubbled on a Contract or Purchase Order AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9102 Form 2 Information - Special Processes - Plating AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S AS9102 - Clarification - PO asking for an Assembly at Rev B (Print at Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M AS9102 Training - Seeking third party agency that provides online AS9102 training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C AS9102 FAIR Form 1 Content Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Qualification Builds & Process Changes (AS9102 - First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R Accounting for Alternate Parts in AS9102 FAIs for Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S When to switch from a Partial AS9102 back to a Full AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S AS9102 Aerospace First Article Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R When is a new AS9102 report required for Outsourced Processing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B New AS9102 Rev B--CA vs UAI--purist vs. pragmatic AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M AS9102 Form #3 modification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G AS9102 Design Supplier Part Number vs. Customer Part Number AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Customer Documentation Errors when completing an AS9102 FAIR AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
W AS9102 Requirements - What information from the PO should be included in the FAIR? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S AS9102 Interpretation on Form 2 field 6 - Specification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Does anyone know when AS9102 Rev B will be released? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q AS9102 Handwritten Revisions on Ballooned Drawing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
S AS9102 FAI requirements - Inspecting with fixtures, templates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Two AS9102 Applicability and Interpretation Questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T AS9102 FAIR - Customer Drawing Revision Change AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K AS9102 Field 19 Signature Requirement AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
T Is IAQG planning an update of AS9102? Revision B of AS9102? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S AS9102 Parts with Machining Allowances for the Customer AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
H Do we need all three AS9102 forms if we manufacture only Piece Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
