AS9102 Supplier Flow Down Method
bguarino
Hi all. I work at a manufacturing company where we supply a MOTS (Modified Off the Shelf) assembly to one specific customer. This customer requires AS9102 FAIs from us and all suppliers we use. The AS9102 requirement was flowed down in their purchase order.
What are some (preferred) methods, or pro's and con's, for flowing down AS9102 FAIs to suppliers? The current internal debate is whether we add this to the drawing as a Note or on the POs we send out.
thanks!
Eredhel
Quality Manager
I'm a fan of using the same tool for the job, rather than a bunch of "if this then that". What are you all currently doing to flow down things that aren't dimensional, coatings, et cetera? I would prefer an AS9102 requirement to be PO not print, but that's how we do things. What do you all currently do?
bguarino
Thanks for all the good feedback. How do you trigger the PO code/line item? Is it an automated process (driven by MRP) or manual?
Mike S.
Happy to be Alive
The need for a given PO code to flow down to a supplier is established at contract review. If it is a part that we expect to buy many times and always with that code vs. a 1-off we will associate the required code(s) with the p/n within our MRP system so they auto-load every time it is bought. If the part is used for many different customers, each needing their own codes (requirements) flowed down depending on who it is for, we either (A) manually load the codes depending on who we buy it for or (B) apply the most stringent codes always (if practical) and auto-load them, so the part is good for any customer.
Steve Weber
We are a machine shop (AS9100 Rev D) that manufactures products from customer blueprints, we have no design authority. When sending out a product for special processes like Passivation, we would list the process and any specific information related to the process but only what is specified on the drawing. We do add a caveat to all PO's that says "NOTE: Certification to include (our company's name) purchase order requirements as well as any specs that supersede these requirements. Noted specs to include any addendums that apply. To date we have not had any issues from customer audits or Surveillance Audits.
G AS9102 Design Supplier Part Number vs. Customer Part Number AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T AS9100 and related AS9102 Supplier First Article Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
V AS9100 and AS9102 - Does our supplier have to do the FAI using the 3 AS9102 forms? Document Control Systems, Procedures, Forms and Templates 3
N Complying with AS9102 when the supplier is using 3D Model Based Definition (3D MBD) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
briteme4 AS9102 FAIR Requirement AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
briteme4 AS9102 First Article Inspection - do I need a second reviewer and signer? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B AS9102 - 3D printing a special tool required for assembly (counterfeit risk?) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
P AS9102 Form 3 Inclusions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D AS9102 - Assembly FAI for Use As Is or Repaired Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Conformal Coating & AS9102 - Is conformal coating material a COTS part AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B AS9102 COTS Form 1 vs. 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 - Completing Partial FAI's for Baseline Part Numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9102 Form 1 Section 13 Detail or Assembly Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
W FAIR to AS9102 additional documentation Document Control Systems, Procedures, Forms and Templates 5
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
R AS9102 - Are FAIs against a Customer Red-Lined Drawings Allowed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9102 - What needs to be Bubbled on a Contract or Purchase Order AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9102 Form 2 Information - Special Processes - Plating AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S AS9102 - Clarification - PO asking for an Assembly at Rev B (Print at Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M AS9102 Training - Seeking third party agency that provides online AS9102 training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C AS9102 FAIR Form 1 Content Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Qualification Builds & Process Changes (AS9102 - First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R Accounting for Alternate Parts in AS9102 FAIs for Assemblies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S When to switch from a Partial AS9102 back to a Full AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S AS9102 Aerospace First Article Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R When is a new AS9102 report required for Outsourced Processing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B New AS9102 Rev B--CA vs UAI--purist vs. pragmatic AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M AS9102 Form #3 modification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
WCHorn AS9102 Paragraph 5.3-5 - Lapse in Production - FAI Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
C Customer Documentation Errors when completing an AS9102 FAIR AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
W AS9102 Requirements - What information from the PO should be included in the FAIR? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S AS9102 Interpretation on Form 2 field 6 - Specification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Does anyone know when AS9102 Rev B will be released? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
