AS9110C Clause 8.5.1.2 Validation and Control of Special Processes for Repair Station
Mark_N
Hi everybody!
Does anyone have any experience with 9110 and special processes in Repair Station? We are the repair station that maintains Boeing and Airbus aircraft up to and insluding D-Check (heavy maintenance). During this maintenance we can use repair procedures that are considered as special processes but these proceses are very "light" if compare with a manufacture.
For example:
- we use a soldering for the repair of landing lights to change the bulb,
- we use a heat treatment for rivets during repairs of aircraft structure,
- we perform a lot of NDT inspections,
- we strip a paint and re-paint aircraft and components,
- we crimp connectors during defect rectification related to wirings,
- we weld some cracks on thrust reverses doors.
All of these works we perform iaw approved maintenance data from TC holders - AMM, SRM, CMM etc.
I feel some doubts that our repair station shall do the same things as manufacturer, regarding the special processes.
I have checked existing manuals:
- Airbus has Process and Material Specification (PMS) that estables requirement for the proceses in whole, and SRM (structure repair manual) that provides detail instructions for particular work.
- Boeing has Standard Overhaul Practices Manual that provides detailed instructions for the processes and SRM (structure repair manual) that provides detail instructions for particular work.
For example, Heat Treatment: SRM describes the themperature ranges, time and tests for verification but nothing about furnace parameters for heat treatment. These parameters and quality requirement for the process in whole I found in PMS.
Airbus know well and use NADCAP for their suppliers-manufacturer but when I tried to ask Airbus about their policy related to the special processes (throuhg techrequest service) in the maintence - nobody could understand what does special process mean. EASA does not use the term "Special process", they use the term "Specialized works"
Thechnical manuals (AMM, SRM etc) do not use the term "Special process" also.
So, when we perform the works that can be considered as the special processes, we always do it strongly in compliance with approved instructions developed by TC Holder (Airbus or Boeing). We also do not fabricate any parts during repair.
My question - What procedures we have to develop additionally to be in compliance with AS9110 requirements?
Situation is very funny as all our maintenance managers know nothing about special processes and this repeats in all Repair stations that I know.
Mark_N
Re: AS9110C Clause 8.5.1.2 Validation and Control of Special Processes for Repair Sta
I really need advice :(
howste
Thaumaturge
Here are the requirements that need to be met:
AS9110 Rev C said:
8.5.1 Control of Production and Service Provision
The organization shall implement production and service provision under controlled conditions.
Controlled conditions shall include, as applicable... f. the validation, and periodic revalidation, of the ability to achieve planned results of the processes for production and service provision, where the resulting output cannot be verified by subsequent monitoring or measurement;
NOTE: These processes can be referred to as special processes (see 8.5.1.2) complying with the requirements of the applicable technical data issued by the type certificate holder or acceptable to the competent authority.
For processes where the resulting output cannot be verified by subsequent monitoring or measurement, the organization shall establish arrangements for these processes including, as applicable:
a. definition of criteria for the review and approval of the processes;
b. determination of conditions to maintain the approval;
c. approval of facilities and equipment;
d. qualification of persons;
e. use of specific methods and procedures for implementation and monitoring the processes;
f. requirements for documented information to be retained.
The short answer is, if all of these requirements are met by using the tech data provided by the Type Certificate Holder, then you don't need more procedures. If only some of these requirements are addressed in the TC Holder's documents, then you will need to define, document, and implement your own requirements to cover the missing ones.
For example, let's say you have a process with a document from the TC Holder that specifies criteria for the review and approval of the process, conditions to maintain approval, methods and procedures for implementing and monitoring the process, and required records. You would then need to determine and define requirements for approval of facilities and equipment and personnel qualification. You will need to look at each process and ensure that each process for each TC Holder has all bases covered.
An alternative would be to develop your own comprehensive procedures that meet all TC Holder requirements. These would need to be updated whenever TC Holder requirements are updated. It would be a lot of work, but would avoid confusion if you have different customers with different requirements for the same type of process.
Mark_N
:thanks: I agree with you.
I had idea to get the list of special processes that are performed in maintenance from TH Holder. I asked Airbus to provide us such list (if they have it) or explain their policy regarding special processes in maintenance. However, they didn't understand what I ask. I know that Airbus has his special Rep in NADCAP and I asked Airbus to send this request to people/department who are responsible for special processes in Airbus - no reaction. I know, that some TC Holders have such list of special processes for old aircraft that still have old "Overhaul" philisophy.
I was hoping that if Airbus provided us with such list, it would greatly reduce the number of processes that we will consider as special.
K Comparison: AS9110C vs. C.A.S.E. 1-A AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
N 60601-2-2 Ed 6 Clause 201.8.8.3.102 - HF instrument leakage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
A ISO 13485 Sterilization Clause Applicability ISO 13485:2016 - Medical Device Quality Management Systems 7
A AS9100D - Clause 8.1 Operation - Coating service company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
H AS9100D clause 8.5.1 f) & 8.5.1 g) - Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
C ISO/IEC 17021-1 clause 7.1.2 - Determination of competence criteria Document Control Systems, Procedures, Forms and Templates 2
S API Spec. Q1 clause 5.6.1.2 On site evaluation Oil and Gas Industry Standards and Regulations 10
K ISO 13485 clause 8.5.2 'Any necessary CA shall be taken without undue delay' ISO 13485:2016 - Medical Device Quality Management Systems 11
lanley liao How to understand the term 3.1.21 'Servicing' and the clause 5.7.1.2 'Servicing' of API Spec Q1? Oil and Gas Industry Standards and Regulations 19
D Layered Process Audits - FCA 9.2.2 - Exemption Clause? IATF 16949 - Automotive Quality Systems Standard 5
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S MDR GSPR Clause 17 - Software Requirements EU Medical Device Regulations 2
K Contamination Control - Class Is medical devices (Clause 6.4.2 ISO 13485:2016 (E)) ISO 13485:2016 - Medical Device Quality Management Systems 12
R Clause 7.7 Replicate, Recalibration and Intermediate checks using Artifact ISO 17025 related Discussions 1
A ISO 13485 - Clause 8.3.3 appropriate actions in response to nonconforming product ISO 13485:2016 - Medical Device Quality Management Systems 2
M Description of the requirements of clause 9.2.2.3 manufacturing process audit- needs your feedback IATF 16949 - Automotive Quality Systems Standard 0
A ISO 41001:2018 - Clause No.8 Operations Part Quality Management System (QMS) Manuals 2
L AS5553 Clause 3.1.7 e "Control packaging material ..................reused" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
R What is meant by Use of COMPONENTS WITH HIGH-INTEGRITY CHARACTERISTICS in ME EQUIPMENT (clause no 4.9) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
P Definition of production tooling in IATF16949 clause 8.5.1.6 IATF 16949 - Automotive Quality Systems Standard 4
K ISO 13485:2016, Clause 4.2.3 Medical Device File ISO 13485:2016 - Medical Device Quality Management Systems 4
B Clause 5.1.12 of Technical Standard IEC 62304/A1 IEC 62304 - Medical Device Software Life Cycle Processes 5
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
O How can I justify excluding the R&D group and the design and development clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V IS/ISO/IEC 17025:2017 Clause 4.1 Impartiality ISO 17025 related Discussions 3
P SOUP anomaly evaluation for MMA (Mobile Medical Application) IEC 62304 clause 7.1.3 IEC 62304 - Medical Device Software Life Cycle Processes 6
F ISO 17025:2017 Clause 7.7 Ensuring the validity of results - Threshold ISO 17025 related Discussions 9
F ISO 17025:2017 Clause 7.4.1 - Requirements for Procedures ISO 17025 related Discussions 4
F Measurement Audit and ILC for ISO 17025 Clause 7.7.2 - Comparison with results of other laboratories ISO 17025 related Discussions 0
