AS9120 to AS9100 due to value added activities
I just joined a small company that has been AS9120. They provide barstock and coil and plate material for machine shops etc. Our last audit, the auditor suggested that we move to AS9100 since we are performing value added activities.
The value added activities we provide are mostly special processes provided by our vendors and some grinding to size. All of it is done by vendors and processors.
For example, Our customer will order 15-5 material to H1075. We will order the 15-5 material from a vendor and send it to a heat treater to be heat treated to H1075 and then ship to the customer. if they require a non standard diameter, we will send it to a grinder to be ground to size. All vendors are controlled per AS9120 External Provider requirements.
Our registrar is saying that this means we take control of the process and are therefore a manufacturer and need to go to AS9100. I tend to agree with this, but our upper management is in WTF mode.
My questions.
What differentiates a distributor from a manufacturer when it comes to value added activities.
Is our registrar correct in their evaluation that we should be AS9100?
Sidney Vianna
Post Responsibly
I agree with your CB auditor's take. Your organization is performing value-added activities and the fact that they are outsourced is irrelevant, and your organization is still responsible for ensuring the special processes are properly validated and re-validated and the product conforms to requirements. In Rev. A of AS9120, the following paragraph applied:
Having said that, I know for a fact (as I was a member of the AAQG Leadership Team for a number of years) that some people within the IAQG would disagree with your auditor's stance and allow you to remain in the AS9120. If you want more than just "opinions", contact the IDR for AS9120 via IAQG/OASIS and post your question to the individual and s/he will provide you with an "authoritative" answer.
Also look at #19 of the AS9120:2016 FAQ Document
Good luck.
Good luck.
Thanks for the quick and helpful reply
Randall Beck
Sidney is certainly more qualified than I am, but as a AS9100 and NADCAP commercial heat treater (we don't perform any manufacturing/machining processes) that performs both in house and outside heat treat services we take the same responsibility for both so I would certainly agree that AS9100 sounds applicable and proper for your organization.
I think something was missed in the commentary about the application.
"This standard is intended for use by organizations that procure parts, materials, and assemblies and resell these products to a customer in the aviation, space, and defense industries. This includes organizations that procure products and split them into smaller quantities, including those that coordinate a customer or regulatory controlled process on the product."
It looks like this line opens the door for value added work as long as it is done under the direction of the customer.
I had a client that changed registrars from one that insisted that they had to move to 9100 because they were coordinating heat treating required by the customer. They move to a registrar that permitted them to be 9120 based on this line. I will not comment further on the customer or the registration bodies involved.
Thanks Jim. This is where it gets confusing, and surprisingly, this hadn't come up in 5 years of previous audits before I arrived. I guess I'm just lucky.
In our case I don't think we are coordinating heat treating with the customer. Instead we are providing product that is heat treated.
If we were a distributor of stainless steel and a customer ordered a bar of 17-4 and added a HT requirement, then we would be coordinating, but if they just order 17-4 H900, and we purchase 17-4 and then send to a heat treater, we are not coordinating. Instead we are producing the product to the customer requirement.
Its a very subtle difference, but I think our (Current) auditor is correct in this case.
But i agree it's subject to interpretation and could change from auditor to auditor. Some creative wording on our companies part in regard to Order acknowledgement and requiring customer agreements that value added will be coordinated etc could help us, but that just gets complicated.
It is a matter of semantics. It is subtle. It requires the sales force to understand what you can and can't do and present it to the customer accordingly. What you can't do is buy metal, send it out for heat treating, then keep it in stock until someone asks for it. What you can do is heat treat it for your customer according to their direction AFTER the order.
Kevin Walters AS9100 and AS9120 AATT Course and Test AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C AS9120 or AS9100 Cert pertaining to inventory? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T Was Just told we could ONLY buy material for AS9100 customers if the DISTRIBUTION house is AS9100 / AS9120 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
TrivialSublime TUV Rheinland voluntarily suspending their ANAB accreditation to AS9100/AS9120. Registrars and Notified Bodies 19
N Do I need to certify to AS9100 or AS9120? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
V Can anyone explain the extra requirements of AS9120 vs. AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
P EN/AS9100 vs. EN/AS9120 - Can we be both? EN/AS9100 Requirements Exceed EN/AS9120? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Inventory prior to AS9120 certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S AS9120 Store QMS packages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
N AS9120 9.2.2 Objectivity? Dispute AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
N From 0 to AS9120 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Q AS9120 7.5.3.2 Control of Documented Information - Audit Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
Q AS9120 Vendor of ESD Monitoring Equipment needs to be in the Approved Supplier List? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A AS9120 External Provider Registry Scope of Approvals AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
howste AS9120 Rev B has been released and is available for purchase - November 2016 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
B AS9120 Internal Audit Scheduling & Planning AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Does AS9120 (aerospace first article inspection) apply to all customers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
H AS9120 stockist now able to work with Airbus sub contractors? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
G AS9120 Purchase Department Performance Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
G AS9120 - What should we be expecting once we set forth into becoming certified? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
J Verification of AC0056A requirement during AS9120 audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P Parts Salvage, Overhaul and Resale - AS9120 Registration question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
L Registration to AS9120 Rev. A timeline AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C As9120 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Purchasing Process - AS9120 Clause 7.4.1 - What do they want?! AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Sidney Vianna AS9120 Revision A has been released AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M AS9120 Requirements for for Freight Forwarders (eg no batch splitting) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M AS9120 Certification Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
A New AS9120 Questions - Distributor - Is 7.5.1 applicable? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
F Should I remove references to AS9120 / ISO 9001 from my Quality Manual and QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S AS9120 Request AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
V Interesting quiz, case studies or exercises for AS9120 needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
V Has AS9120:2002 been replaced by AS9120:2005? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
V What Training is Required to be a Qualified AS9120 Internal Auditor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
Sidney Vianna AS9120 - Should planning of product realization be excluded? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Upgrading from ISO9001:2000 to AS9120 - Difficulties? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
Marc AS9120 - Designed for aerospace suppliers known as "stockist distributors" Design and Development of Products and Processes 3
Sidney Vianna AS9003 and AS9120 - First Accredited Registrars for AS9003 and AS9120. Various Other Specifications, Standards, and related Requirements 5
Sidney Vianna AS/EN/SJAC AS9120 - Aerospace Requirements for Stockist Distributors - Now available AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9100 Calibration Register AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Crusader ASQ AS9100 Lead Auditor Training Career and Occupation Discussions 27
9 AS9100 Friendly ERP Recommendations Misc. Quality Assurance and Business Systems Related Topics 1
dpenbert AS9100 7.5.3 - Manual Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Can I exempt products/services from my AS9100 QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P AS9100 and CAMO - Continuing Airworthiness Management Organization AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
K AS9100 - Looking for advice on how to become a CB Auditor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D AS9100 Rev D - Clause 8.7 Control of Non conforming outputs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
W AS9100 Shelf Life Extension or Exemption AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Merging two AS9100 Companies: how to manage interim period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
