AS9120B Clause 8.4.1.1 External Providers Scope of Approval
QualityStandardsGirl
We just went through our AS9120B upgrade audit and got a non-conformance on Clause 8.4.1.1 The organization has not fully maintained a register of external providers that includes the scope of approval.
We had our approved external providers listed as Supplier (distributors), Vendor (repair vendors), Both (Supplier & Repair Vendor) or Non-Aviation. The auditor said that didn't break it down far enough. We are wondering how far you need to break down the scope of approval. Would it be ok to say the vendor is approved for Engine repairs or airframe repairs or does it need to be more in depth than that?
I tried looking at some of our customer's AVL and I am finding all different things.
Perspicuity
An AS9120 QMS system should have supplier categorizations that are second to none; after all, supply chain management and inventory control are undoubtedly your core competencies. This said, I would not look to my customers’ AVL’s for guidance since they are probably not AS9120.
Commodity/service type approval scopes are probably the most common; however, dependent upon the needs of your business you may opt for something different. Maybe you can expand upon what you already have (e.g. Surplus Distribution, ASA100 Distribution, AS9120 Distribution, FAA Repair, AS9110 Repair, Nadcap Processor, etc.).
Remember, an auditor may gig you for sending a flight control to a supplier you have approved for “Engine Repair” even if that supplier has an FAA approval for both propulsion and airframe.
I would stay away from scopes such as Full Approval, Conditional Approval, or the like. These pertain to approval status and not scope.
doctall41
Full Disclosure, I think QualityStandardsGirl and I had the same auditor, a couple of weeks apart. My auditor also said the Scope of my External Providers was not broken down enough. I actually agree with her on that. For example, on my outside processors for Penetrant, anodize, prime, cad plate, topcoat, etc, I have them listed as Finishes.
For something like that, how do you guys have the scope listed for your outside processors? Do you list everything they are approved to do?
Thanks in advance for your help!
doctall41
Perspicuity
I think listing “everything they are approved to do” is not required, misleading, unmanageable and risky. It is important to step back and understand the dynamics of an ASL/AVL. Is it your list? Does it contain directed sources? Are you a prime? Do you build-to-print? Do you design? What about fixed processes?
Some of the biggest companies have it easy; they make a list of suppliers and include a basic listing of what these suppliers provide.
A build-to-print company (for example) must be attentive to their own suppliers, the suppliers of their customer(s), and suppliers unique to their industry. If customer A says you can use Acme Finish Inc for penetrant and anodize, while customer B says Acme Finish Inc can only be used for chem-film, whose supplier scope listing are you managing? Your own or your customers’? To me, this may be a “Special Process Source” or may be a “Directed Source”.
Requisitions, purchase orders, MRP systems (item master listings) are intended to control procurement (when coupled with competent buyers)! “Approval scopes” are rightfully intended to be abbreviated. To merely state a source is approved for penetrant inspection can be misleading? Are they approved for ASTM-E-1417, MIL-I-6866, BAC 5423, or another of the myriads of penetrant specs? Are they competent with titanium castings or do they just use visible dye on structural steel? Are they capable of pre-penetrant etch and if so will they scrap your expensive assembly because they don’t really understand when not to etch?
The key is to make your approval scope work for you and arguably effective without the introduction of misleading risk. Also, I stand by my original statement: An AS9120 system should have a procurement system second to none.
Sidney Vianna
Post Responsibly
While I agree with the opinion in theory, the reality is: most pass-through aerospace distributors are small organizations without the resources and knowledge to perform in-depth supplier assessments.
If one were to expect a small aerospace distributor to have a robust supplier quality function to the level of an OEM, most AS9120 certificates would have to be revoked.
C Need help in determining applicable clause for an audit finding (based on AS9120B) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W AS9120B - How to meet clause 7 Support that covers 7.1., 7.1.1, 7.1.2, & 7.1.3? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M AS9120B annual recert AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
F AS9120B - Exclusions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S AS9120B - 8.5.2 Delivering Split Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Q AS9120B flow down to external providers: Records Retention AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q AS9120B - ESD monitoring devices part of 7.1.5 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
P AS9120B Control of External Providers for Franchised Distribution AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
W AS9120B 8.5.1 Control of Production and Service Provision AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Failed the AS9120B Exam Twice.....Need Help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
C Are zero defect sampling plans relevant to AS9120B Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q Customer Requirements - AS9120B Audit Finding AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
E AS9120B 8.4.2a Ensuring external providers remain within control of the QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
W AS9120B QMS and its process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
E Online training for an internal auditor to AS9120B AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
W AS9120B 8.4.3 Information for External Providers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
W AS9120A to AS9120B transition AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D AS9100D vs AS9120B differences AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
L Clause related to Failure to fulfill delivery date of critical item ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Z How to interpret and apply IEC60601-2-54, clause 203.6.4.3.104.3 Accuracy of X-RAY TUBE VOLTAGE, second para. IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
G ISO 17025.2017 Clause 7.8.4.3 Certificate of Calibration Label ISO 17025 related Discussions 5
M IEC 60601-1-8 clause 6.4.1 (statistics of the distribution of the sum of the maximum ALARM CONDITION + SIGNAL GENERATION DELAY) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Clause 7.4 Communication Compliance Evidence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
F IATF 16949 Clause 8.5.1.5 - OEE, MTTR, and MTBF Calculation IATF 16949 - Automotive Quality Systems Standard 2
B ISO 9001Exclusion of clause 8.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
B Clause 4.4.1 c) vs. Clause 9.1.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
R Can an organization be ISO certified if it doesn't comply with each clause? ISO 13485:2016 - Medical Device Quality Management Systems 1
M Feedback process ISO 13485:2016 clause 8.2.1 ISO 13485:2016 - Medical Device Quality Management Systems 2
G Clause 8.5.1 -- Is non Identification evidence of ineffective control of production ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
G Clause 7.5.3 and Required Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 41
LincolnQA AS9100D, Clause 8.4.1.1d - actions to take when external providers do not meet requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
H IEC 61010-1:2010/A1:2016 - Clause 10.5.3 - (b) - Interpretation CE Marking (Conformité Européene) / CB Scheme 6
E Clause 15.4.2.1 d) - Loss of ESSENTIAL PERFORMANCE IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Clause 7.5.2 of ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
S Is design and development clause 8.3 applicable for laboratory ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Clause for use of expired quality alerts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
H DIN 12880:2007-05 Clause 7.2 Test Equipment Description CE Marking (Conformité Européene) / CB Scheme 0
D API Q1 clause (1.0) Scope Oil and Gas Industry Standards and Regulations 1
D API Q1 clause (5.6.3) Verification of Purchased Products or Activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R 9001 and 9004 clause misalignment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
L 60601-2-10 clause 201.12.4.103 Output Indicator (itself in SFC?) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B IATF 16949 clause 10.2 - requirements following a customer complaint. IATF 16949 - Automotive Quality Systems Standard 9
R Clause 8.5.1.2 - Y1 Capacitors in Series IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
eule del ayre Clause 7.1.5 Monitoring and measuring resources IATF 16949 - Automotive Quality Systems Standard 14
P AS9100D clause 8.6 - Documentation required to show evidence of conformity AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
H IEC 61010-1 Clause No. 10.5 Resistance to Heat - Sub Clause 10.5.3 Insulating Material CE Marking (Conformité Européene) / CB Scheme 6
H Does this clause mean i must be in compliance with AS9100 or is 9001 enough? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Iso 9001 Clause 7.1 - Advice needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
T Need help understanding AS6174 clause 3.1.5. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
H Required explanation of sub clause 7.2.101.2 (Exception) of IEC 61010-2-020:2006 CE Marking (Conformité Européene) / CB Scheme 5
