Asking for e-coat inspection plan
X
xn58xn58
Dear all,
I first time work with e-coating process. I hope anyone to provide me a process inspection plan, such as when to inspect, what stage to inspect, how frequent to inspect, what need to be inspected.etc.
Also, if you know the common drfects and root reasons, please also advise.
thank you very much.
Jen Kirley
Quality and Auditing Expert
Hi xn58, welcome to The Cove! :bigwave:
An inspection process for e-coating is spelled out as a part of the overall quality control plan in manufacturing trailers in this document. Look in Section 4:
http://contracting.tacom.army.mil/comveh/ltt/ATPD 2171 R16Sep.doc
I am referencing you to a comprehensive example that you may find way too complex for your needs. That's fine, you can examine the document to see how the process is called out and apply the concept to your own needs.
Notice the plan identifies defect types and their criticality. It outlines, among other things: how many will be sampled, at what process points and to what standard (it points to tables within the document where MIL-specs are not called out) the output will be comforming to.
To some degree the coating's acceptance criteria are specifically called out in this sample document, but I also like to see samples of acceptance/rejectability at inspection stations. They can increase consistency in the inspection process and work to ensure the customer's wishes are conformed to precisely.
In the end, a document must be designed to fit your organization's QMS, product needs and design, extent of regulation and other considerations that you know and I do not. I hope this example gives you what you need to develop your own effective process plan.
xn58xn58 said:
Dear all,
If you have any contacts in automotive, they may be able to help. In a former life, I worked for a Tier 1 supplier to automotive. We first purchased, then e-coated internally weldments to automotive. Mazda had an excellent specification for e-coat testing.
I don't have access to a control plan anymore, but I can provide some from memory. First, your cleaning operations are critical. Temperature, dwell time, concentration of cleaner, cleanliness (conductivity) of rinse are a few.
In the coating process, total surface area to be coated, voltage (based on surface area), concentration, temperature, dwell time.
Bake process is basically time and temperature.
Some quality tests are salt spray corrosion, scratch test (test in heat zone areas if welded; use tape to test adhesion), visual (orange peel, color), thickness.
Coat rack design is critical. You need good conductivity to coat the correct thickness. If your parts are heavy, they can hang on the edge of a triangular cross-section hook. If they are light, there is atendency to float off when submerged, so you will need a springlike retainer. The hook/retainer will leave a mark, so these need to be located in a non-critical/visible area.
Randy Stewart
Appearance was the biggest issue I can remember. Looking for drips, runs, even coverage, misses, etc. We also tested for coating thickness and adhesion.
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M OEM asking for NC report after certification audit. IATF 16949 - Automotive Quality Systems Standard 3
N Customer asking if their notified body can audit us ISO 13485:2016 - Medical Device Quality Management Systems 5
P Automotive Customer asking PPAP for catalogue parts IATF 16949 - Automotive Quality Systems Standard 16
B GM GP-12 Pre-Launch - They asking for a I chart Statistical Analysis Tools, Techniques and SPC 2
M AS9100 D 8.3.4.1 a - Parameters to be recorded" - What is this asking for? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S AS9102 - Clarification - PO asking for an Assembly at Rev B (Print at Rev C) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Defect Rate for asking for an RMA - Company wants an RMA for every defect found Supplier Quality Assurance and other Supplier Issues 10
J Potential Customers Asking for EIRs / 483s when evaluating a CRO for future work US Food and Drug Administration (FDA) 2
V Customer is asking for a Bottlenecks and Contingency Plan for our Mfg Processes APQP and PPAP 5
C DCMA (Defense Contract Management Agency) asking for Inspection Schedule Dates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J How I should format a SCAR Cover Letter? SQE asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
G Supplier Quality Questionnaire - Asking who our customers are Quality Manager and Management Related Issues 10
J Sourcing a Sterile Product - Asking for supplier for too much regulatory stuff? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Jim Wynne Employers asking Job Candidates for Facebook Passwords Career and Occupation Discussions 11
K External Auditor asking for other Audit Findings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
A Does anyone know what a SRVA is? Chrysler is asking for this for tooling Customer and Company Specific Requirements 7
S French Customer asking for an NFL 00-015C Certificate - Statement of Conformity Other ISO and International Standards and European Regulations 3
S EOQ (Economic Order Quantity) - Use for managing Customer Orders - asking help Lean in Manufacturing and Service Industries 5
M Two Industry Regulations Asking For Opposite Standards Other ISO and International Standards and European Regulations 2
G Customer asking for CPK 1.5 Quality Level IATF 16949 - Automotive Quality Systems Standard 3
B Delivery Transportation - Asking about outsourced process clause 4.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Print asking for Straightness of 0.013 and it has a note "Any Radial Element" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
D Outsourced Material - Customer who is asking us for a level 3 PPAP APQP and PPAP 8
L Client asking for us to perform VDA 275 - VDA questions VDA Standards - Germany's Automotive Standards 1
BradM Wikipedia asking for financial assistance World News 5
L Asking for AQL for checking 5 liters can AQL - Acceptable Quality Level 5
S Employer asking me to compromise on integrity Career and Occupation Discussions 46
K Asking for a Raise and Justifying a Raise Career and Occupation Discussions 30
T Venezuela government is asking for "GMP Certification" - Huh? ISO 13485:2016 - Medical Device Quality Management Systems 7
C Asking an Auditor's Advice on different systems at different laboratories General Measurement Device and Calibration Topics 8
D How to conduct The Presidential Quality Audit? (Asking a question) General Auditing Discussions 4
M Supplier audit - Are they asking for too much documentation? ISO 13485:2016 - Medical Device Quality Management Systems 12
Z Customer asking about the Japan Green Initiative / China RoHS activities Sustainability, Green Initiatives and Ecology 1
V OEM is asking for a specific FMEA to produce first articles IATF 16949 - Automotive Quality Systems Standard 5
samer Are your employees asking for a salary increase? Coffee Break and Water Cooler Discussions 2
V Ford 2nd Tier info - Ford is asking us for a list of all of our suppliers Customer and Company Specific Requirements 29
B Measurement System Manufacturer specs - Customers have been asking about our Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Preparing for External Audits - Asking Registrar for their Audit Check List(s) Document Control Systems, Procedures, Forms and Templates 19
H Confirmation of software - Exactly what the last paragraph of 7.6 is asking for? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Yet another design question - Customer is asking for a print but we do not do design Design and Development of Products and Processes 19
Marc Registrar Asking Customer to complete QMS Audit Matrix Registrars and Notified Bodies 16
E What is the PPAP date my customer is asking me for? APQP and PPAP 4
B GQAS - We have a customer asking for certification - What is it? Various Other Specifications, Standards, and related Requirements 4
A Environmental Impact Study - Customer is asking for a copy Miscellaneous Environmental Standards and EMS Related Discussions 10
R Customer Letter Asking for TS 16949 IATF 16949 - Automotive Quality Systems Standard 8
T Asking Suppliers about Statistical Techniques they use Supplier Quality Assurance and other Supplier Issues 4
1 Capability Study for Level 3 PPAP - They are asking for a 100 peice capability study APQP and PPAP 4
P Powder Coat Painting Jigs (Hangers) for Shafts and Joints Manufacturing and Related Processes 3
L CQI-12 2nd Edition - Table D, question 2.1 - Powder Coat Painting IATF 16949 - Automotive Quality Systems Standard 2
