ASME GD&T Certification Test - Converting Coordinate Tolerances to Profile Tolerances
optomist1
A Sea of Statistics
Hi To All,
Does anyone recall whether there were any questions regarding converting Coordinate Tolerances to Profile Tolerances?? No specifics requested, I'd just like to know if this topic was covered on the exam.
Thank you for your time...
Marty:thanks:
Stijloor
Re: ASME GD&T Certification Test - Converting Coordinate Tolerances to Profile Tolera
Hi To All,
Marty:thanks:
Can someone with ASME GD&T Certification experience help with this?
Thank you very much!!
Stijloor.
David DeLong
Hi To All,
Marty:thanks:
I can't remember but it could be. You should know how to convert since it is easy.
If one had a tolerance of +/- .4 mm in one axis and +/- .3 mm in the other one, obtain the distance to the corner which would be the hypotenuse. In our case it is .5 mm. That is now the radial tolerance about true position. Now, double it and we get a diametrical tolerance zone of 1 mm. There, you have it.
Paul F. Jackson
David and Marty,
I would say that it may be possible to convert coordinate tolerances applied to non-features of size... if they were equivalently referenced from datum features declared on the drawing by some means either in a note or via dimension origin symbols... as those declared in the profile tolerance control.
It would not be possible however to convert RFS position tolerances because position controls the point, axis, or center-plane not the surface as profile does.
Likewise it would not be possible with other geometric controls that do not constrain parameters of the feature's form, size, and location like profile does... like runout, total runout, concentricity, and symmetry.
It is hard to imagine a profile tolerance being converted from a form tolerance because form tolerances don't have coordinates... but that does not mean that form tolerances cannot have an equivalent profile tolerance such as flatness (form tolerances applied to non-features-of-size).
As far as variable-limit tolerances are concerned (those features-of-size specified for position @ MMC or LMC)... they have coordinates (implied or specified) and they have boundaries for their size (virtual and resultant conditions now called their MMB max-material-boundary and LMB least- material-boundary) so I believe it may be possible ---as long as--- the position callout was specified "zero at MMC". The conversion would consist of basic dimensions defining the location of the feature from the DRF, basic dimensions defining the shape of the feature, and profile boundaries reflecting the MMB and LMB. Those position tolerances specified other than zero at MMC/LMC have unequal proportions for size and location and could not be equivalently bounded.
After thinking about it over night you cannot even do variable tolerances equivalently because a tolerance specified "zero at mmc" would have an LMC limit for size that is not equivalent to the resultant condition or LMB.
As I have said before… if one was to think of a profile in terms of a variable position tolerance you could think of it as a position tolerance that is both zero at MMC and zero at LMC, having its greatest liberty for location its form is perfect and it resides at its median location.
I wouldn't look for any of this variable tolerance conversion stuff to be discussed in any context having to do with Y14.5... these are my own musings. Also I would be surprised if there were any questions about converting coordinate tolerances to profile tolerances other than "It cannot be done" for the reasons I cited in the first couple of paragraphs.
I cannot remember what was on the test; it has been a long time since I took it.
Paul
optomist1
A Sea of Statistics
Good Day David & Paul,
Thank you very much for your assistance....I'll scan an example and post later this afternoon. Hopefully, this will provide a bit more insight...
Regards,
Marty:thanks:
optomist1
A Sea of Statistics
Thanks for the prompt....Stijloor
optomist1
A Sea of Statistics
Hi To All,
Regarding my earlier post attached is an example problem....I get the concept and can translate Coordinate to Profile....just curious if similar type of problems were presented on the Technologist/Senior exam.
Thank you for oyour assistance...
Marty
Paul F. Jackson
Notice the prerequisite 1)Determine the datum features... limit tolerances do not typically have defined datum reference frames unless they are declared in a note or established by an origin symbol.
You can replace a limit tolerance with a surface profile tolerance applied to a non feature of size but it is not necessarily equivalent... The example you cited from Alex Krulikowski's materials uses the top surface as the datum feature... but he could have alternatively used the bottom surface as the datum feature.
Keep in mind that in the real world the surfaces are never perfectly parallel, using the larger would typically moderate the result and the smaller typically amplify it. I say tyypically because the three points determining the datum plane may not behave as predicted.
With the profile control one would expect that the inspection results would be more consistent because all would have measure according to the callout rather than choosing their own reference. I think that is Alexs' point in this illustration.
Paul
optomist1
A Sea of Statistics
Hi Paul,
Thank you for the thorough response, I get it. Alex's/ETI's text is a great study guide, this together with the Y14.5M - 1994 text is my study guide.
I am just completing ETI's Advanced Concepts of GD&T....then study study study study......
Thanks again for your input..
Marty
C Budgetary cost to obtain ASME NQA-1 Quality Program Certification Quality Management System (QMS) Manuals 0
optomist1 Has anyone recently taken the GD&T ASME Y14.5M Certification Exam Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
optomist1 Is ASME GD&T Technologist Certification worthwhile? Professional Certifications and Degrees 7
K PED (Pressure Equipment Directive) Certification - We hold an ASME 'S' stamp CE Marking (Conformité Européene) / CB Scheme 11
K ASME, ANSI, ASTM and similar specifications and their requirements for document control. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
P FAI Ballooning ASME Y14.5 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Painted cut threads - ASME Pipe Suppliers Manufacturing and Related Processes 6
GoKats78 ASME Y14.5 Dimensioning and Tolerancing - Is there a JIS equivalent to Y14.5? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
optomist1 ASME Y14.5 Irregular vs Regular Features of Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
O What does "Gap" and "Flush" in ASME Y14.5 mean? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Positional Tolerance - Bonus / Datum Shift / ASME Y14.5M - Clarification Various Other Specifications, Standards, and related Requirements 9
D New ASME B89.1.13-2013 Standard for Micrometers General Measurement Device and Calibration Topics 6
K ASME BPVC (Boiler & Pressure Vessel Code) Calibration Requirements General Measurement Device and Calibration Topics 6
L How to conduct a Quality Audit based on ASME BPVC VIII-1 requirements Various Other Specifications, Standards, and related Requirements 4
M What Preceded ANSI/ASME Y14.5? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M ANSI/ASME B1.2 Revision Changes from the 2001 version Various Other Specifications, Standards, and related Requirements 1
L ASME Y14.5 Coaxial Feature Toleranced with Position w/o Reference Datum Design and Development of Products and Processes 2
G Dial Indicator Calibration Frequency - ASME/ANSI B89.1.10M-1987 Calibration Frequency (Interval) 4
D ASME Y14.5M 1994 and 2009 Training Resources Training - Internal, External, Online and Distance Learning 2
R ASME of Sterilizers from China for the US Dental Industry China Medical Device Regulations 3
D Auxiliary View Fold Line convention in ASME standard? Manufacturing and Related Processes 5
G ASME Y14.5-2009 on tolerance limits Various Other Specifications, Standards, and related Requirements 1
M ASME B1.13M Standard - Specification of a Plug Gage of Minor Diamateter Various Other Specifications, Standards, and related Requirements 3
T Dimensions Before or After Coating? Drawing states ASME Y14.100 and Y14.5 apply Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
G ANSI & ASME regardless of Maximum Material Condition when none is specified Various Other Specifications, Standards, and related Requirements 3
M ASME-NQA-1-2008 - Quality Assurance Requirements for Nuclear Facility Applications Other ISO and International Standards and European Regulations 8
R Distribution of Reference Documents and ASME Codes Document Control Systems, Procedures, Forms and Templates 1
N ASME B89.1.13 question regarding Resolution and Maximum Permissible Error General Measurement Device and Calibration Topics 3
R Standard Relevance & Updating - ASME B&PVC Various Other Specifications, Standards, and related Requirements 4
T ASME NQA-1-1994 Standard Supplement 17S-1: Dual Storage Various Other Specifications, Standards, and related Requirements 5
Q Dial Indicator Verification Procedure - ANSI/ASME B89.1.10M-2001 General Measurement Device and Calibration Topics 13
M ASME NQA-1 and Interface Control Various Other Specifications, Standards, and related Requirements 34
M ASME NQA-1-1994 Standards - Struggling with the supplement references Various Other Specifications, Standards, and related Requirements 16
Stijloor ASME Y14.5M-2009 is on its way! Various Other Specifications, Standards, and related Requirements 10
T Nuclear Liability - Supplying construction materials - ASME under NCA 3800 Quality Manager and Management Related Issues 6
J Measurement Over Wires - Is there an ISO equivalent of ASME B1.16m Appendix B? General Measurement Device and Calibration Topics 12
D GD&T and "Fixed Fastener formula" (ASME Y14.5) Statistical Analysis Tools, Techniques and SPC 2
I European Code (EN13445) vs. ASME VIII - Calculating Spherical Heads Other ISO and International Standards and European Regulations 1
M ANSI-Y14.5M vs. ASME-Y14.5M - Does an ANSI-Y14.5M-1994 document actually exist? Various Other Specifications, Standards, and related Requirements 9
D Drafting Conventions per ASME Y14.5m - Three significant digits rule Various Other Specifications, Standards, and related Requirements 12
M Is ASME B89.1.5 a standard? Measurement of master discs or cylindrical plug gages Various Other Specifications, Standards, and related Requirements 10
O Environmental conditions per ASME NQA-1 2000 QA records? Records and Data - Quality, Legal and Other Evidence 4
ScottK ASME B&PVC Section VIII Div 1 question regarding "Seal" Various Other Specifications, Standards, and related Requirements 0
M New Gage Block Tolerances - ASME B89.1.9 Tolerances and Grades General Measurement Device and Calibration Topics 9
A Rights of Access per ASME/NQA-1 2000 Misc. Quality Assurance and Business Systems Related Topics 17
ScottK The term "Quality Control Manual" - ASME B&PVC question Various Other Specifications, Standards, and related Requirements 2
A ASME Symbols (process Flow Diagrams) - GM-1805 (KCDS) shows different symbols APQP and PPAP 3
P Conflicting tolerances on the component pitch - ASME Y14.5M - 1994 General Measurement Device and Calibration Topics 14
gard2372 Any websites or matrices to cross reference EN or DIN standards to SAE/ASME etc...? Other ISO and International Standards and European Regulations 3
D ASME standard - Format for Drawing (Print) Title Block Various Other Specifications, Standards, and related Requirements 7
