Search the Elsmar Cove!
ASME Symbols (process Flow Diagrams) - GM-1805 (KCDS) shows different symbols
ALFINSA
Hi to everyone, I am brand new user of this forum. I have been around for a little while but never set a new threat. Now I am here!
I am very confuse just because after read the GM-1805 (KCDS) they shows a different symbols inthe flow diagram example. Now I am wondering if I should use the synbologu shown at the GM-1805 ) just because it is a GM's CSP or keep using the one that I have been using the last six years.
Can anybody help me clearing this issue? Or anyone have a document with the current symbols? Thanks in advance. :bonk:
Coury Ferguson
Moderator here to help
Re: Asme Symbols (process Flow Diagrams)
Welcome and thanks for your first post.
Usually in my opinion , you would use the Flow Chart Symbols that are recognized, but than if this is a specifc requirement of GM then that would need to be considered.
How much work/jobs represent GM's? (Just to get further clarification)
Coury Ferguson
ALFINSA
Coury,
Thanks for your sooner response. I really appreciate it!!.
GM is our biggest client. I want to be sure if any change have been made. I already found the ASME symbology and the problem is that there is an inconsistency egarding the FAB symbol. The example uses a diamond and the ASME uses a circle. What I suppoust to use?
Howard Atkins
Forum Administrator
Welcome from me as well.
If you have been using your version with no problem up till now, I would continue unless there is a specific requirement from GM.
But are you sure that what you have from ASME is in fact the current document
All I could find at ASME is
Y32.11 - 1961 Graphic Symbols For Process Flow Diagrams In Petroleum And Chemical Industries
This standard is no longer an American National Standard or an ASME approved standard as of February 11, 2003. It is available for historical reference only.
Graphic Symbols Standards
