ASME Y14.5M-2009 is on its way!
bobdoering
Stop X-bar/R Madness!!
Bob,
Good one! :lol:
I wish I had a $ for every time I've seen the Y14.5 standard reference missing in the title block; I could retire would not have to work as much....:D
Stijloor.
Most I have seen reference 1973 revision. :eek: I think that was based on two issues: 1) Drawing were made before the 1984 revision and 2) Nobody bothered to learn any of the rev updates. At least they were truthful...:notme:
Marc
2008 PROPOSED GD&T TIPS
Summary of Changes
by Gary Whitmire
A proposed new Y14.5 Geometric Dimensioning and Tolerancing Standard has just been officially released for comments. If past practice is any guide, this draft will become the new standard in a few months. This standard will replace the 1994 GD&T Standard. It is expected that all organizations which now use the 1994 Standard will eventually switch to this 2008 GD&T Standard. The proposed standard itself is 264 pages long, so following is a summary of a few of the changes from the 1994 Standard:
A. There are new symbols and dimensioning conventions for:
• All Over as used in Profile Control
• Continuous Features
• Independency
• Unequally-disposed Tolerance Zone
• Moveable Datum Target
• Datum Translation
B. There is a guide to the six degrees of freedom for datums
C. Non-perpendicularity of intersecting surfaces is addressed
D. There is a change under Spotface
E. Basic dimensions are clarified
F. There is a clarification on Limit of Size
G. There is a change to Rule 1
H. Tolerance of position has been reformatted
I. Dimensions defined by CAD data have been addressed
J. The effect of datum references in positional tolerances is explained in degrees of freedom
K. Control of coaxial features is addressed
L. There are new boundary methods
M. There are a number of new terms, including:
• Maximum Material Boundary (MMB)
• Least Material Boundary (LMB)
• True Geometric Counterpart (TGC)
• Regardless of Feature Boundary (RMB)
• Degrees of Freedom (DOF)
N. There are twenty (20) new definitions
O. A contoured surface can be a datum
P. There is a new datum symbol placement requirement
Q. There is a new leader line symbol
E
ewh3356
"O. A contoured surface can be a datum"
I thought that this was already the case, albeit not a primary datum (ASME Y14.5-1994 para 4.5.10.1) . :confused:
True Position
Just wait, they'll allow them to be secondary/tertiary datums with the contoured surface just having a profile of a surface tolerance. (to the solid model of course)
D ASME Y14.5M 1994 and 2009 Training Resources Training - Internal, External, Online and Distance Learning 2
G ASME Y14.5-2009 on tolerance limits Various Other Specifications, Standards, and related Requirements 1
P FAI Ballooning ASME Y14.5 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
GoKats78 ASME Y14.5 Dimensioning and Tolerancing - Is there a JIS equivalent to Y14.5? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
optomist1 ASME Y14.5 Irregular vs Regular Features of Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
O What does "Gap" and "Flush" in ASME Y14.5 mean? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
optomist1 Has anyone recently taken the GD&T ASME Y14.5M Certification Exam Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Positional Tolerance - Bonus / Datum Shift / ASME Y14.5M - Clarification Various Other Specifications, Standards, and related Requirements 9
M What Preceded ANSI/ASME Y14.5? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
L ASME Y14.5 Coaxial Feature Toleranced with Position w/o Reference Datum Design and Development of Products and Processes 2
T Dimensions Before or After Coating? Drawing states ASME Y14.100 and Y14.5 apply Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
D GD&T and "Fixed Fastener formula" (ASME Y14.5) Statistical Analysis Tools, Techniques and SPC 2
M ANSI-Y14.5M vs. ASME-Y14.5M - Does an ANSI-Y14.5M-1994 document actually exist? Various Other Specifications, Standards, and related Requirements 9
D Drafting Conventions per ASME Y14.5m - Three significant digits rule Various Other Specifications, Standards, and related Requirements 12
P Conflicting tolerances on the component pitch - ASME Y14.5M - 1994 General Measurement Device and Calibration Topics 14
Ron Rompen Does this print callout meet ASME Y14.5 1994 General Measurement Device and Calibration Topics 25
J I need a copy of ASME Y14.5m - 1994 - Geometric Dimensioning and Tolerancing Various Other Specifications, Standards, and related Requirements 3
Marc Definition Critical Characteristic Symbol - ASME Y14.100 Standard (Engineering Drawing Practice) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 8
C Budgetary cost to obtain ASME NQA-1 Quality Program Certification Quality Management System (QMS) Manuals 0
J Painted cut threads - ASME Pipe Suppliers Manufacturing and Related Processes 6
D New ASME B89.1.13-2013 Standard for Micrometers General Measurement Device and Calibration Topics 6
K ASME BPVC (Boiler & Pressure Vessel Code) Calibration Requirements General Measurement Device and Calibration Topics 6
L How to conduct a Quality Audit based on ASME BPVC VIII-1 requirements Various Other Specifications, Standards, and related Requirements 4
M ANSI/ASME B1.2 Revision Changes from the 2001 version Various Other Specifications, Standards, and related Requirements 1
G Dial Indicator Calibration Frequency - ASME/ANSI B89.1.10M-1987 Calibration Frequency (Interval) 4
R ASME of Sterilizers from China for the US Dental Industry China Medical Device Regulations 3
D Auxiliary View Fold Line convention in ASME standard? Manufacturing and Related Processes 5
optomist1 ASME GD&T Certification Test - Converting Coordinate Tolerances to Profile Tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
optomist1 Is ASME GD&T Technologist Certification worthwhile? Professional Certifications and Degrees 7
M ASME B1.13M Standard - Specification of a Plug Gage of Minor Diamateter Various Other Specifications, Standards, and related Requirements 3
G ANSI & ASME regardless of Maximum Material Condition when none is specified Various Other Specifications, Standards, and related Requirements 3
M ASME-NQA-1-2008 - Quality Assurance Requirements for Nuclear Facility Applications Other ISO and International Standards and European Regulations 8
R Distribution of Reference Documents and ASME Codes Document Control Systems, Procedures, Forms and Templates 1
N ASME B89.1.13 question regarding Resolution and Maximum Permissible Error General Measurement Device and Calibration Topics 3
R Standard Relevance & Updating - ASME B&PVC Various Other Specifications, Standards, and related Requirements 4
T ASME NQA-1-1994 Standard Supplement 17S-1: Dual Storage Various Other Specifications, Standards, and related Requirements 5
Q Dial Indicator Verification Procedure - ANSI/ASME B89.1.10M-2001 General Measurement Device and Calibration Topics 13
M ASME NQA-1 and Interface Control Various Other Specifications, Standards, and related Requirements 34
M ASME NQA-1-1994 Standards - Struggling with the supplement references Various Other Specifications, Standards, and related Requirements 16
T Nuclear Liability - Supplying construction materials - ASME under NCA 3800 Quality Manager and Management Related Issues 6
J Measurement Over Wires - Is there an ISO equivalent of ASME B1.16m Appendix B? General Measurement Device and Calibration Topics 12
I European Code (EN13445) vs. ASME VIII - Calculating Spherical Heads Other ISO and International Standards and European Regulations 1
K PED (Pressure Equipment Directive) Certification - We hold an ASME 'S' stamp CE Marking (Conformité Européene) / CB Scheme 11
M Is ASME B89.1.5 a standard? Measurement of master discs or cylindrical plug gages Various Other Specifications, Standards, and related Requirements 10
O Environmental conditions per ASME NQA-1 2000 QA records? Records and Data - Quality, Legal and Other Evidence 4
ScottK ASME B&PVC Section VIII Div 1 question regarding "Seal" Various Other Specifications, Standards, and related Requirements 0
M New Gage Block Tolerances - ASME B89.1.9 Tolerances and Grades General Measurement Device and Calibration Topics 9
A Rights of Access per ASME/NQA-1 2000 Misc. Quality Assurance and Business Systems Related Topics 17
ScottK The term "Quality Control Manual" - ASME B&PVC question Various Other Specifications, Standards, and related Requirements 2
A ASME Symbols (process Flow Diagrams) - GM-1805 (KCDS) shows different symbols APQP and PPAP 3
