Aspect vs. Impact and Hazard vs. Risk - Short/clear explanation & example
saint77
Trying to conduct this assessment for IMS but first need to do the training on those.
So, wanted to write some short and clear explanations but could not.
So i THOUGHT that I undertood those concepts well enough (but that for myself) but explaining it to others is much more difficult.
Therefore, thinking about this question some time I've completely lost the vision ^-( I always try to think of questions of the most negative attitude people and think I will not be able to show them the difference. Please help!!!
saint77
Re: Aspect vs Impact and Hazard vs Risk. Who can give short and clear explanation&exa
Check this thread:link
Thank you for the reference but unfortunatly it's not quite what I needed. I understand everything at this level of discussion and see the difference between the 14001 and 18001 concepts.
The question really is about difference within a standard between
1. Aspect vs Impact
and only the second question about
2. Hazard vs Risk.
For example.
Transportation
14001
Aspect: Transportation
Impact Transportation air emission/oil spills and spots / depletion of natural resources / used tires and oil
compare
Aspect: Air polution
Impact transortation/production/kitchen/boiler/ etc
--- so Transportation is an aspect or impact? how to find out which is the primarily
= the same question then applies to 18001
Hazard: Transportation
Risk: collapse, driving abuse, speeding, drunk driving, etc.
compare
Hazard: Loss of man hours (loss of health, injury)
Risk: transportation at garage, transportation at production, transportation by subcontractors, etc.
harry
Re: Aspect vs Impact and Hazard vs Risk. Who can give short/clear explanation & examp
Refer to table A.1 of ISO 14004 - Examples of activities, products and services and their associated environmental aspects and impact for a good appreciation.
An example similar to what you quoted (delivery & transfer of heating oil) is given there. On the next page of the same table - Transportation and distribution of goods and products.
Transportation in your case is not an aspect but an activity or service.
saint77
thank you very much for the document
but please, what is the conceptual (in simple words) difference between the two concepts: aspect vs impact.
e.g.
as in that table
they use the word USE
use of resource/water/land but under different titles. In one case as an impact in another as an aspect (that's basically was my example with transportation. let's disregard the example with transportation and look into the example of the word USE i.e. why USE of something can be aspect and why impact)?
Randy
Aspects - Impacts, Hazards - Risks both have a cause and effect relationship but there is a slight difference.
There can be positive aspects, such as a well run recycling program, but there will never be a positive hazard.
Many times an aspect can be an impact and an impact can be an aspect. Think cause/effect - input/outut/input...All one needs to do is study bioaccumulation of mercury from a wastewater discharge or air emission along and the interaction in the food chain...Mercury is emitted into the air as a component of air pollution (Apsect is the mercury in the emission the impact is the pollution being caused)...Mercury falls into water sources either from rain or gravity and now becomes a water pollutant that can be absorbed by lower plant or animal life. The lower plant or animal life is eaten by higher life forms and the mercury is absorbed and retained in their body. As they eat more of the lower forms more mercury is ingested and retained by their bodies. Higher forms eat lower forms and the accumulated mercury is passed on until it reaches people in the form of fish or other aquatic foods.
Hazards and risks are slightly different but we still see a cause and effect relationship and we can have a compounding or hazards that can cause increase or greater potential lethality of risk.
But remember, while you can have a positive aspect with a positive environmental impact, you'll never have a positive hazard or positive risk
Now I'm going to really confuse you....Both ISO 14001 and OHSAS 18001 have, towards the front of both standards a Glossary of Definitions in Section 3, just apply the definitions as they are given, it makes things go a little smoother...ISO 14001 also has Annex "A"...it helps to refer to A.3.1. With OHSAS 18001 you need to get a copy of OHSAS 18002:2009 to provide further guidance
saint77
Randy,
thank you very much for such a simple explanation, it's what I needed!
One more question, if there is a long line of cause-effect relationship how do we built it into the 2 step formula aspect-impact
1. taking the first cause and giving the immediate effect
2. taking the furst cause and the last effect?
Randy
Randy,
Depending upon the aspect you can have a simple 1 - 2 method, but remember, your apect/impact process isn't meant to be a one-time shot, it's meant to be reviewed occasionally. When one looks at a mature EMS we should see that as the system matured the aspect/impact process has dug geeper and expanded outward at the same time....like a tree growing roots and branches. This is of course not true for all aspect/impact relation ships but it can happen for many of them
saint77
it seems to me you didn't answer the questions ^-) (at least I didn't get the answer)
- if there is more than 2 steps in teh process (several effects in the chain) which do we choose to control and document:
thank's a lot!!!
Randy
thank's a lot!!!
Oh, gotcha
You'd be most correct to try and manage the last one you identify (impact)....But remember, you only have to address the Significant Aspects and their impacts that you identify, not all aspects.
However, if you properly apply "Prevention of Pollution" in the way that it was intended and address Aspects at the "front-of-the-pipe" you would essentially be addressing all the potential subsequent impacts.
G Combining Aspect Impact and Hazard Risk Register Miscellaneous Environmental Standards and EMS Related Discussions 8
T New to ISO 14001 - Need example of Environmental Aspect/Impact for a HVAC Contractor ISO 14001:2015 Specific Discussions 3
A Aspect Impact Analysis & Risk Assessment Technique Miscellaneous Environmental Standards and EMS Related Discussions 8
A Identification of Environmental Aspects and Impacts - Aspect and Impact Study ISO 14001:2015 Specific Discussions 18
R Environmental impact and aspect for foundries Miscellaneous Environmental Standards and EMS Related Discussions 10
P Aspect & Impact Assessment For Electricity Consumption and water usage ISO 14001:2015 Specific Discussions 2
D Aspect & Impact list for Wire Harness Process Miscellaneous Environmental Standards and EMS Related Discussions 4
J ISO 14001 Clause 3.3, 3.4 - Or, which came first, the Impact or the Aspect? ISO 14001:2015 Specific Discussions 6
L ISO 14001 Aspect and Impact Assessment - Direct and Indirect Environmental Impacts ISO 14001:2015 Specific Discussions 18
L Practical ISO 14001 Aspect and Impact Assessment Miscellaneous Environmental Standards and EMS Related Discussions 8
K Capturing local government development/planning activities in aspect register ISO 14001:2015 Specific Discussions 2
D Software as risk control - Confused on one aspect of IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 20
S Gage Block Verification or buy a new set (cost aspect) General Measurement Device and Calibration Topics 1
S Gage R&R as a wider aspect of uncertainty budget Measurement Uncertainty (MU) 3
G ISO 14001 & Product Design Process Environmental Aspect Review Requirements ISO 14001:2015 Specific Discussions 7
C Tracking Spills as an Environmental Aspect Miscellaneous Environmental Standards and EMS Related Discussions 7
M Is a Significant Aspect always a Significant Aspect? Miscellaneous Environmental Standards and EMS Related Discussions 13
I Should chemical use within a semiconductor facility be an aspect? ISO 14001:2015 Specific Discussions 2
S Identify Environment Aspect by Activities Approach ISO 14001:2015 Specific Discussions 4
S Need Questionaire for Interested Parties on EMS Aspect Miscellaneous Environmental Standards and EMS Related Discussions 6
S Training Record Signatures Requirements - Software aspect Records and Data - Quality, Legal and Other Evidence 3
W Is it Legal for Printing CE Mark in Label? FDA Aspect 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 22
S Criteria for Determination of Significant Aspect/Hazard in IMS Miscellaneous Environmental Standards and EMS Related Discussions 3
M Environmental Aspect Significance Determination and Scoring Miscellaneous Environmental Standards and EMS Related Discussions 6
O Significant Environmental Aspect - Emissions to the Air (injection molding process) Miscellaneous Environmental Standards and EMS Related Discussions 8
S How to use the Aspect Register - Aspect register is not being used to its fullest Miscellaneous Environmental Standards and EMS Related Discussions 5
D HR (Human Resources): Matrix of Competence in USA - Education Level aspect ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
A "Element of" in ISO 14001:2004 (3.6 - environmental aspect)? ISO 14001:2015 Specific Discussions 4
G New environmental aspect(s) procedure - Acceptable? ISO 14001:2015 Specific Discussions 11
L What should we do if we can't Measure an Aspect? Measuring and monitoring Miscellaneous Environmental Standards and EMS Related Discussions 5
L Do we need to have a Significant Aspect? ISO 14001 Aspects and Impacts ISO 14001:2015 Specific Discussions 4
U Nonnormal vs. Normal Operating Condition Aspect for each Environmental Aspect? Miscellaneous Environmental Standards and EMS Related Discussions 4
P ISO 14001 Influenced Aspects? Does anyone have an influenced aspect in your EMS? ISO 14001:2015 Specific Discussions 13
Marc Definition A 'New' Aspect of the Cove - A Definitions and Acronyms page? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 74
K Running Change Drawing Control - Timing aspect of the release of these documents Document Control Systems, Procedures, Forms and Templates 1
M Aspect Indentification? Early stages of ISO 14001 implementation ISO 14001:2015 Specific Discussions 4
K EMS Auditing - Misunderstanding Aspect Significance Miscellaneous Environmental Standards and EMS Related Discussions 66
R 4.18 - Training - Customer requested information on each operator for each aspect ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N EU MDR and its impact on existing Registrations EU Medical Device Regulations 1
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 4
V Laser Welding Process - Impact on Electrical Properties Reliability Analysis - Predictions, Testing and Standards 4
L Impact on 510(k) to use an additional manufacture US Food and Drug Administration (FDA) 0
R Impact of changing manufacturer post clinical investigation CE Marking (Conformité Européene) / CB Scheme 3
Ed Panek Corona Virus impact on Supplier Audits and Received Parts ISO 13485:2016 - Medical Device Quality Management Systems 4
F Will the EU postpone 2017/745 MDR Implementation - COVID-19 Impact Medical Device and FDA Regulations and Standards News 11
R Revalidation machine line and Stability Studies impact. Medical Device and FDA Regulations and Standards News 3
M MDR Impact on MDSAP Countries Other Medical Device Regulations World-Wide 16
Watchcat Impact of MDR on Availability of Medical Devices in EU EU Medical Device Regulations 5
Judy Abbott Can any one help me with an urgent BIOCOMPATIBILITY Impact assessment? Internal Auditing 9
