ASQ/ANSI Z1.4–2003 (R2018) Change Log?
Is there a change log available for the ASQ/ANSI Z1.4-2003 (R2018) "Reaffirmation" or does anyone know of any changes off hand?
The R2013 version's was nice enough to have the changes on the product page and these were included in the "Foreword" of the standard, but the latest version has no such log and does not even contain a "Foreword" at all. The standard does state that ASQ needs to reaffirm the standard no later than 5 years, but it would be nice if there was SOME type of indication of even the LACK of changes within...
Either way the tables my organization uses doesn't seem to have any changes (No surprise).
Jean_B
TLDR; don't worry too much about reaffirmations. If it would have made a difference in decisions you would make, it would (should) have been a revision.
I don't know about that specific standard, but I've never worried too much about Reaffirmations. If it was important in their eyes, it would have been a revision. I'd be hard pressed to push anyone on putting in more effort then looking at the summary, and simply consider it an indication of the date that the most recent review for suitability has occurred. Some use review/stability dates for this (often outside of the document, such as ISO), while this way amends/apends the actual document revision identifier (which introduces some referencing problems), and might account for errata/corrigendums without being clear on it (ISO uses a to me inconsistently applied system of amendments and corrigendum, with strange numbering (sometimes starting at 11).
Pro's and con's can be stated for either case, and are specific to an organization's needs. The biggest burden with all these different approaches to what is in essence document control is communication with a third party on what differences between versions, revisions (in all their kinds) are and are not material, and making why a test report/process etc is or is not valid.
For example: our national standards body on occasion accepts a standard's main text as is, adds its 'container sheets' at the beginning and end, sometimes publishes this in a different year (the main characteristic that people use to distinguish revisions) and yet provides the non-national version for a different price as well). Lately ISO has been adding both year of issue and an edition number again (good), but not every standard organization applies this at their container level, or provisions to distinguish national deviations.
Their documentation (https://share.ansi.org/Shared Documents/Standards Activities/American National Standards/Procedures, Guides, and Forms/2019_ANSI_Essential_Requirements.pdf) states:
4.2.1.2 Reaffirmation of an American National Standard
The due process and consensus requirements defined herein apply to reaffirmations as they do to all approval
actions related to American National Standards (ANS). The procedures used for reaffirmation of an American National
Standard by an accredited standards developer shall be implemented according to the developer’s ANSI
accredited procedures. Reaffirmations shall provide an opportunity for public comment.
Reaffirmations shall be accomplished without any substantive change to the main text of the standard. All nonsubstantive
changes in the main text of the standard shall be explained, or noted, in a foreword
. An American
National Standard undergoing an update of references to standards necessary to implement the American
National Standard shall be processed as a revision unless the updated reference is only a reaffirmation of the
referenced standard. Any substantive changes in such references require processing as a revision.
The ANS shall clearly indicate on its cover or title page that it is a reaffirmation.
(I really enjoy document control, my apologies for the long text).
Default
J AQL Inspector Ruler based on ANSI/ASQ Z1.4-2003 AQL - Acceptable Quality Level 2
J ANSI/ASQ Z1.4-2003 Sampling with Skip Lot Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Steve McQuality ANSI/ASQC Z1.4-1993 vs. ANSI/ASQ Z1.4-2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L ANSI/ASQ Z1.4-2003 - Page 13 in reduced sampling code "M" sample size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
T Where to find ANSI/ASQ Z1.4-2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S Sampling Plans - Inspection Levels I, II, III - I'm looking at ANSI/ASQ Z1.4-2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
Douglas E. Purdy ANSI/ASQ Z1.4-2003 - 1993 version vs. the 2003 - What changes were made? Various Other Specifications, Standards, and related Requirements 2
M What is the Risk of Using Obsolete Versions of C=0 & ANSI/ ASQ Z1.4 Sampling Plans? ISO 13485:2016 - Medical Device Quality Management Systems 8
R ANSI/ASQ Z1.4. for CQE Exam Professional Certifications and Degrees 9
S Is using ANSI/ASQ Z1.4-2008 the correct sampling plan to determine Pass/Fail of Apparel measurements? AQL - Acceptable Quality Level 8
C AS9100 rev D 8.5.1 c 2 - Defining the Machine in-process frequency per ANSI/ASQ Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
F ANSI ASQ Z1.4 - Is the following process acceptable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
WCHorn AS9100 and Sampling - ANSI ASQ Z1.4 C=0 Conflict AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S Using ANSI/ASQ Z1.4 to Reduce Impact of Field Service Campaign AQL - Acceptable Quality Level 17
A Where to obtain ANSI/ASQ Z1.9 C-1 and D-1 tables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S ISO 2859-1 or Ansi ASQ Z1.4 in using AQL or AOQL - Need Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A ANSI/ASQ Z1.4 tables for C=0 - Setting up a robust Sampling Inspection Scheme Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection AQL - Acceptable Quality Level 2
A New version of ANSI/ASQ Z 1.4-2008? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P ANSI/ASQ tables (Z1.4) / OC Curves - Percent accepted, how'd I do? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
howste ANSI/ISO/ASQ QE19011S-2008 - information on 2008 version? General Auditing Discussions 6
L ANSI/ISO/ASQ Q10005-2005: Quality management ? Guidelines for quality plans Other ISO and International Standards and European Regulations 2
Hershal ACLASS purchased by ANSI-ASQ General Measurement Device and Calibration Topics 3
R ANSI/ASQ Z1.9 on-line acceptability calculator Other ISO and International Standards and European Regulations 4
Wesley Richardson ASQ has posted ANSI/ISO CD1 9001:2009, ANSI/ISO CD1 9004:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
C Ansi/ASQ Z1.4 C=0 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
4 ANSI/ASQ Z1.4, Section 6.2 Nonconforming Units Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T AQL for Laymen - ANSI/ASQ Z1.4 - MIL-STD-105 AQL - Acceptable Quality Level 15
D Need to purchase ANSI/ASQ Z1.4 & 1.9 - Sampling Procedures and Tables - Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Designing a Mil-Std-105 or ANSI/ASQ Z1.4 Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 49
M ASQ certification study material Professional Certifications and Degrees 1
normhowe ASQ Storytime Event - Tell Us a Story ASQ - American Society for Quality 15
Crusader ASQ AS9100 Lead Auditor Training Career and Occupation Discussions 27
Steve Prevette Informational ASQ Video about Dr. Deming's work Philosophy, Gurus, Innovation and Evolution 0
G Medical Device Auditor (CMDA) certification exam by ASQ - looking for input Career and Occupation Discussions 3
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
O ASQ CQE Exam Experience, Home versus Exam Center ASQ - American Society for Quality 0
Y ASQ CQE and CSSGB; What next? Career and Occupation Discussions 1
L ASQ's Biomedical Auditor Course Test ASQ - American Society for Quality 1
E Preparing for the ASQ CPGP (GMP professional exam), how to revise and remember the vast syllabus? ASQ - American Society for Quality 2
T ASQ CQE vs CMQ/OE Professional Certifications and Degrees 2
Sidney Vianna Continual decline of ASQ - can it be saved? Nov 2019 ASQ - American Society for Quality 29
L ASQ CBA biomedical auditor - CBA primer material is enough to study? ISO 13485:2016 - Medical Device Quality Management Systems 6
J Getting training either from ASQ or from SAI Global - ISO 9001 Lead Auditor training Training - Internal, External, Online and Distance Learning 1
P ASQ Certified Biomedical Auditor (CBA) Certification Preparation 2019 ASQ - American Society for Quality 3
R ASQ reference material clarification - Spiral bound materials allowed in ASQ Exam? Professional Certifications and Degrees 1
andika_untoro ASQ CQE Exam Group for Dec 2019 / Jan 2020 Preparation ASQ - American Society for Quality 18
A Any recommendation for ASQ's CPGP (Pharmaceutical GMP Professional) Certification exam questions? ASQ - American Society for Quality 2
J ASQ Chicago Training Institute - If any of you are interesting in teaching ASQ Certification preparation ASQ - American Society for Quality 1
D ASQ CMQ/OE Certification - Share your thoughts ASQ - American Society for Quality 3
