Assessing Hazard-Related Use Scenarios where control measures exist through standards
ThatSinc
#11
To understand whether I'm on the right track, for the use scenario of "acknowledgement of alarm signals" the following:
It seems redundant to include one for every potential alarm condition as the causes are the same, and therefore recommendations and subsequent control measures are relevant to all - however the effect and severity would differ between a low battery alarm, and an over-delivery alarm.
In my 60601-1-8 documentation for assignment of alarms each alarm condition is designated by the potential harm the condition could cause and onset etc. so it again feels like double documenting everything.
As a side note, as this has gone off of my original subject, Is it possible for a moderator to change the title to something more appropriate such as "Usability integration with DIRs and RMF"
indubioush
#12
This looks good, but hard to know if you are fully on the right track without looking at all documentation. I think maybe don't worry about doing things in the hypothetical right way. Just know the requirements of the standards and try to think about compliance to ALL risk-related standards as you are creating these documents.
I get your worry about double documenting things. For me, hazard-related use scenarios ARE hazardous situations. I just ensure that I provide the detail needed to be compliant with IEC 62366-1. At the same time, these hazard-related use scenarios are analyzed, evaluated, and controlled just like any other risk per ISO 14971. Same scoring and connected to the hazard analysis in the same way as other FMEA documents.
Considering your example of the alarms, each of these is a unique risk. Therefore, each unique risk should go through the ISO 14971 process. This means that either in your uFMEA or hazard analysis, you need to add in associated harms, risk control measures, occurrence, risk level, etc. Example: Do you really need a "recommended actions" column, or could this instead be "risk control measures"?
Also, I'm not familiar with 60601-1-8, but if possible, you should integrate this into your existing documentation. You can set up an easy way to extract the 60601-1-8 information if needed.
Just my OPINION.
ThatSinc
#13
Thanks for the feedback, it's given me a lot to think about.
Agreed on recommended actions, the uFMEA could incorporate the same elements as the hazard analysis and then be summarised with the hazard analysis in the risk report, rather than being rolled up into the hazard analysis.
That removes a decent amount of double documenting, whilst simultaneously allowing the uFMEA the freedom to document the analysis of use hazards clearly.
I'll attempt to sleep on it and see how it goes tomorrow.
Tobias_HF
#14
So for your uFMEA you use different scoring criteria to your "main" risk file?
Yes, but its only one kind of scoring. Either its a risk --> goes to the RA. In there, the RA scoring criteria apply.
Or its not a risk --> stays in there for further observation and proove we had thought about that. And it may become a risk in the future, for example when during a formative study / Post Market surveillance one of these Ooops! moments happens... :-/
...enter the harsh reality of usability tests... ;-)
Is this criteria documented as a part of your usability engineering process?
Yes, but its a 2021 goal for me... still needs some alignment.
As any identified hazard/hazardous situation from a hazard use scenario is mapped forward/upward into the 14971 risk file and assessed there for probability and severity, is there any requirement to document an occurrence rate within the uFMEA?
I would do severity only, in the uFMEA, like risk/no risk.
Have seen this probability (and detectability!!) as well, I don`t like it. Someone tried to argue "but it happened only twice in the formative study!" but yeah, definitely no.
However, I might use PMS data in the future, if its trustworthy, to raise something up to a risk level. We all know if something small, annoying happens frequently, users will somehow find a workaround. And this might be bad, so it could lead to a hazardous situation. In this case, I would have a look at probability / occurence, but only in our PMS usability review (yes we do that annualy).
Tobias_HF
#15
Another thing to consider: we should also document known use errors from previous / competitor devices. I found this helpful to be in the uFMEA (written) report. It somehow never really fit into the RA.... because especially the competitor devices use errors come in all different formats, I have no idea how they were classified by the competitors... so the uFMEA report gives me a bit more freedom to document, analyse them and draw our conclusions.
For my cases, this really prooved to be very practical.
levatorsuperioris
#16
Willful negligence -> if the user understands the meaning of the alarm and purpose fully ignores it is not a use risk-it is intended misuse and you don't have to control for intended misuse, unintentional misuse is what you need to control for...
But you are going on long cause effect chains that may best be described by a fault tree analysis, I don't know if you have already done. Using a FMEA for this type of activity will almost certainly cause issues, the output of the FTA usually ties into the FMEA and you would describe failure pathways defined in the fault tree in the FMEA for controls. That level of risk control is usually done within design iterations and not at an outset. Otherwise if you are remediating a file, you already have a design and you can then start with hazards and FTA them move to the FMEA describing the full failure chain.
levatorsuperioris
#17
You would normally start with a PHA preliminary hazards analysis for phase 1 those would populate into the FMEA. These should include a documented search of hazards modes from MAUDE, other reporting databases and literature. The PHA feeds into your phase 1 (requirements phase) FMEA, Phase 2 (design phase) you design, here you can come out with a FTA (is what I would use for a device with a user interface that has alarms) and input that into uFMEA, then based on risk (I would consider redundant protections) some of these user tasks are defined as critical. These critical flagged tasks then need to match 1 to 1 with test cases in usability testing in phase 3 (V&V).
indubioush
#18
Just to provide clarification, intended misuse can be considered "reasonably foreseeable misuse," which must be accounted for in the risk management documentation per ISO 14971, and the risk must be controlled to an acceptable level. However, if the risk fits in the category of "abnormal use" per IEC 62366, the manufacturer is not required to mitigate the risk through the usability engineering process.
From ISO 14971
Reasonably foreseeable misuse is defined as use of the medical device in a way not intended by the manufacturer.... This can relate to use error (slip, lapse or mistake), intentional acts of misuse, ....
From IEC 62366
While the USABILITY ENGINEERING PROCESS can be used to identify ABNORMAL USE, this International Standard does not require the USABILITY ENGINEERING PROCESS to be used to assess or mitigate RISKS associated with ABNORMAL USE.
levatorsuperioris
#19
ISO 14971 2018 defines reasonably foreseeable misuse this way:
3.15 reasonably foreseeable misuse use of a product or system in a way not intended by the manufacturer, but which can result from readily predictable human behaviour.
But to be clear intentional misuse would be if the operator disables all alarms knowing they have disabled the alarm that warns of "X", and doing so could result in "Y" harm to the patient. This scenario the operator could be purposefully putting the patient at risk or cause harm to the patient. You do not have to list out all the scenarios that this could occur as they are infinite. For example, janitorial staff purposefully cutting the lines, or facilities maintenance purposefully shutting off the oxygen system in the building. This is willful negligence and it is not expected to be controlled by the manufacturer. At a large company, where the devices are sold in the million's you will have all sorts of wild misuse stories get reported.
R FOD Risk Assessment - What tools would you recommend for assessing FOD risk? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R Assessing Pipette Calibration Failures General Measurement Device and Calibration Topics 5
B Interpreting "misuse" when assessing Hazardous Situations ISO 14971 - Medical Device Risk Management 2
A Escalation to CAPA - Assessing if an NC warrants a CAPA Nonconformance and Corrective Action 4
A Assessing Risk for Medical Device Software ISO 14971 - Medical Device Risk Management 7
A Assessing/Mapping Employee Attitude during Competency Mapping (Assessment) IATF 16949 - Automotive Quality Systems Standard 15
J Assessing compliance with ISO 13485 Section 6.1 ISO 13485:2016 - Medical Device Quality Management Systems 10
A Assessing a Preventive Maintenance Strategy - Reliability or Maintenance Statistics Reliability Analysis - Predictions, Testing and Standards 2
D Assessing the Validity of Previous Measuring Results? General Measurement Device and Calibration Topics 8
L Assessing Corrosion Damages on Steel finished externally with Epoxical Paint Various Other Specifications, Standards, and related Requirements 1
Mikey324 Assessing Potential Field Failures (TS 16949 Requirements) Quality Manager and Management Related Issues 5
G Assessing Process Capability on Variation (Hardware Adjustment Mean Shift) Capability, Accuracy and Stability - Processes, Machines, etc. 4
B Assessing a Suppliers Technical Capabilities Supplier Quality Assurance and other Supplier Issues 6
S Objectives and Targets - Assessing a rate of achieving a goal Reliability Analysis - Predictions, Testing and Standards 7
J Assessing the understanding of occupational health and safety requirements Occupational Health & Safety Management Standards 3
T Assessing actuality to apply ISO 14001 ISO 14001:2015 Specific Discussions 12
Douglas E. Purdy Storage & Inventory - Assessing Stock for Deterioration at Planned Intervals 7.5.5.1 IATF 16949 - Automotive Quality Systems Standard 9
B ISO10012:2003 Question - Choosing or assessing the capability of a piece of equipment Other ISO and International Standards and European Regulations 1
A Assessing and managing monopolist suppliers Supplier Quality Assurance and other Supplier Issues 6
J Discrepancies - Determine the Magnitude and Assessing the Risk Nonconformance and Corrective Action 2
L Internal Auditing & Assessing Effectiveness Internal Auditing 8
T Assessing Customer SPECIFIED Suppliers Supplier Quality Assurance and other Supplier Issues 9
M Informational Work in progress at the FDA for biological evaluation – Color Hazard and RISk calculator (CHRIS) Medical Device and FDA Regulations and Standards News 0
A Fire hazard classification - Clause in IEC 60601 about gauze and electricity ISO 14971 - Medical Device Risk Management 0
N Should it even be on the hazard analysis (software)? FMEA and Control Plans 2
S ISO 14971 Risk Management - Questions for Hazard identification ISO 14971 - Medical Device Risk Management 2
A Moving and positioning of patient - Mechanical hazard IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
A Risk-benefit Analysis - Hazard Analysis (HA) and FMEAs ISO 14971 - Medical Device Risk Management 18
S The Severity of a Medical Device Hazard - Risk Analysis Clarification ISO 14971 - Medical Device Risk Management 6
D Hazard analysis for our medical device - Hazards seem to overlap 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
F Medical Device HACCP (Hazard Analysis and Critical Control Point) Risk Management ISO 14971 - Medical Device Risk Management 2
L No entanglement hazard of applied parts cables? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
D Biological and Chemical Risks to the user in the Hazard Analysis ISO 14971 - Medical Device Risk Management 1
E EN/UL/CSA 61010 -1 (ed3) Safety and use of Software to Prevent Electrical Hazard CE Marking (Conformité Européene) / CB Scheme 3
M Hazard Identification for Pest Control Activities Other ISO and International Standards and European Regulations 9
N Hazard Probability of Occurrence Definition ISO 14971 - Medical Device Risk Management 11
A ISO 14971 Figure E.1 that starts with Hazard and ends with Risk ISO 14971 - Medical Device Risk Management 3
R Risk Analysis and Hazard Identification concerning Clinical Decision Support Systems ISO 14971 - Medical Device Risk Management 1
M IVDD ER 8.3 Vs. Hazard Labelling Regulations - Which outranks? EU Medical Device Regulations 2
G Combining Aspect Impact and Hazard Risk Register Miscellaneous Environmental Standards and EMS Related Discussions 8
R Risks which must be Distinctly Identified - Harm, Hazard, Severity ISO 14971 - Medical Device Risk Management 7
S Hazard Identification and Risk Assessment - Can Risk Assessment be "Grandfathered"? Occupational Health & Safety Management Standards 4
2 Medical Device Hazard Risks - Normal Use Risks vs. Faulty Use Risks ISO 14971 - Medical Device Risk Management 4
K Regarding ISO 62304 Clause 7.3.3 - Hazard and Risk Controls IEC 62304 - Medical Device Software Life Cycle Processes 9
S PMA Submission Software Hazard Analysis Document vs. Product Hazard Analysis doc ISO 14971 - Medical Device Risk Management 5
V FMEA vs. Process Hazard Analysis (PHA) FMEA and Control Plans 2
S Aspect vs. Impact and Hazard vs. Risk - Short/clear explanation & example Miscellaneous Environmental Standards and EMS Related Discussions 11
K When, whom, how to conduct hazard analysis of PRP?s, OPRP?s and CCP?s? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
K Seeking guidance on Preliminary Steps to enable Hazard Analysis Food Safety - ISO 22000, HACCP (21 CFR 120) 1
