Assignable causes rules clarification
rnsvasan
In control chart there is a rule that if 7 points continuously falls on either upper or below the average value, then it is assignable causes. Can any one clarify why 7 is taken as a guideline and why not 6, 5 or 4 etc.
Johnny Quality
The guideline depends on which rules you are using. The chart below is taken from here.
It seems you are using the AIAG rules, someone more experienced with SPC will hopefully post and show you where the numbers come from. I would say the numbers come from the % chance of the phenomenon coming from common causes, as a point beyond UCL or LCL is something like 99.8% from the top of my head.
“What are the odds of certain patterns occurring simply by chance?”
Many of the rules were deceptively derived through the use of PROBABILITY (Not inferential statistics of any theoretical distributional model, ie the NOT the Normal distribution or the central limit theorem). Some of the probability calculations are exact, some are based loosely on the empirical rule and Tchebycheff’s Theorem. Of course while the Probability calculation can be made exact or precise there is no precise or exact ‘cutoff’ of when to say that a ‘change’ is suspicious enough to warrant investigation. These rules have stood the empirical test of time and are based on the users 'risk' tolerance of a wrong answer. Remember the alarm doesn't mean that an assignable cause has created a change; it means you should investigate to see if a change has occurred. This is subtle but critical.
the calculations can be found at:
Western Electric, "Statistical Quality Control Handbook", 1956, 2nd Edition, 10th Printing, May 1984, Part B, pp. 23-30 and Part F, pp. 149-183 http://www.contesolutions.com/Western_Electric_SQC_Handbook.pdf
Lloyd S. Nelson, "Technical Aids," Journal of Quality Technology vol. 16, no. 4 (October 1984), pp.238-239
The western electric handbook is available for free
The Western Electric Handbook is available for FREE. I strongly recommend it.
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
V Corrective Action for a scenario where Assignable Cause is not confirmed Nonconformance and Corrective Action 4
O Is it an Assignable Cause only if the Control Chart says so? Statistical Analysis Tools, Techniques and SPC 16
W How to justify Widened Control Limits - No Assignable Cause scenario Statistical Analysis Tools, Techniques and SPC 26
qualprod The Perfect audit? External Audit causes a significant negative impact in a company General Auditing Discussions 9
T Root causes - operator's actions Problem Solving, Root Cause Fault and Failure Analysis 17
N The known set of all root causes Nonconformance and Corrective Action 11
Marc A special Supermoon comes—but what causes it? 14 November 2016 Coffee Break and Water Cooler Discussions 0
S Preparing a Root Cause Report - Possible Root Causes Document Control Systems, Procedures, Forms and Templates 11
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
M What are the major causes of Forklift Accidents? Occupational Health & Safety Management Standards 13
J Major Nonconformance on Stage 2 Audit causes to start over Stage 1? IATF 16949 - Automotive Quality Systems Standard 2
S FDA 483 Listing Observations - Mostly Corrective Action and Root Causes? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A Standard Root Causes in a process orientated engineering company Problem Solving, Root Cause Fault and Failure Analysis 17
E Corrective Actions Root Causes from Surveillance Audit Findings Nonconformance and Corrective Action 3
P What are the causes of painting defects? Manufacturing and Related Processes 2
V Linking the FMEA Causes & Action Plan with DOE Experiments or Experimentation Design FMEA and Control Plans 1
P PMMA IRK304 Resin and EVA (Ethylene Vinyl Acetate) Tape causes a Stain Mark Manufacturing and Related Processes 3
D Root Cause Analysis and "Comprehensive List of Causes" Nonconformance and Corrective Action 4
B Process FMEA (PFMEA) Same Multiple Causes for Different Effects FMEA and Control Plans 6
J Causes of Porosity of Die-Castings and How to Improve Die-Casting Manufacturing and Related Processes 10
A Resistance Welding Customer Complaints - Cracking and Pitting Root Causes Customer Complaints 4
N Causes of Disbond Defects in Composites Manufacturing Process Manufacturing and Related Processes 7
S On Time Delivery - Non conformance? Root Causes, Corrective Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R Lyophilization: Causes of process failure? Manufacturing and Related Processes 3
6 Possible Causes of Invert Sugar Recrystallising Manufacturing and Related Processes 1
V Failure Modes & Causes in dFMEA & pFMEA FMEA and Control Plans 3
M PFMEA (Process FMEA - Potential Causes and Failure) - Operator's Role FMEA and Control Plans 11
B Seeking advice on Recurring Findings with Different Causes Internal Auditing 13
A Common causes of Corrosion on Alm 7075 Material Annodized, Tumbled, and Plated Manufacturing and Related Processes 6
somashekar Wavelength Shift in Emitter Assemblies - Causes Manufacturing and Related Processes 1
M Cl 8.5.2 Corrective Action - "Cause" vs. "Causes" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Jim Wynne February 2010 Windows Update Causes BSOD for Alureon Rooted XP Users After Work and Weekend Discussion Topics 8
bobdoering Going "green" causes problem for public works crews in West Bend Coffee Break and Water Cooler Discussions 14
S External Audit - Nonconformance Root causes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
V Documenting the Root Causes for Internal Audit Non-Conformance Findings Problem Solving, Root Cause Fault and Failure Analysis 5
C Identifying Causes (book chapter 4 on problem solving) The Reading Room 26
K Should we rate according to the prob. a risk will occur or that risk causes hazards? ISO 14971 - Medical Device Risk Management 5
L How to distinguish two types of causes (common cause & special cause) Statistical Analysis Tools, Techniques and SPC 4
M Process FMEA (PFMEA) Assumptions Regarding Causes Identification FMEA and Control Plans 6
B Rational Subgroup and Estimation of Variability Due to Common Causes Statistical Analysis Tools, Techniques and SPC 7
C Quality causes business demise World News 10
J The Red Plague - Improper copper wire coating process causes oxidation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M System Level Root Causes for each individual CAR generated in the system? Problem Solving, Root Cause Fault and Failure Analysis 10
A How to organize DFMEA for Failures that have many Causes and Effects FMEA and Control Plans 2
M Problem resolution for Common Causes.. Misc. Quality Assurance and Business Systems Related Topics 4
Raffy TS 16949 Certificate - What are causes for which we can lose our certificate? IATF 16949 - Automotive Quality Systems Standard 22
A Removing the effect of special causes on Xbar-R chart - Centerless grinding process Statistical Analysis Tools, Techniques and SPC 6
Marc Definition Statistical Control - A stable process free of special causes Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
A FDA will not make a company comply with a regulation if it causes undue hardship ISO 13485:2016 - Medical Device Quality Management Systems 2
