Assigned value for fixed single-value devices
When you use a fixed single-value standard, what value do you use as the reference?
  • The most recent certificate value and uncertainty
    Votes: 1 33.3%
  • The mean of the most recent few values, and the standard deviation of the mean (how many?)
    Votes: 1 33.3%
  • The mean of all values in the device's history, and the standard deviation of the mean
    Votes: 0 0.0%
  • Values taken from a SPC chart of the device history
    Votes: 0 0.0%
  • The manufacturer's original certified value and uncertainty
    Votes: 0 0.0%
  • The manufacturer's nominal value and uncertainty specification
    Votes: 0 0.0%
  • Some other value (please explain)
    Votes: 0 0.0%
  • I don't know
    Votes: 1 33.3%
  • I don't have any fixed single-value standards
    Votes: 0 0.0%
  • Total voters
    3
  • Poll closed .
G
Graeme
Some calibration standards are fixed devices with a single nominal value. Examples are DC voltage sources, standard resistors and so on. When calibrated, the report should include the measured value and the calibration uncertainty.
There are several methods of determining the reference value to be used (the "assigned value"). I need to develop a defined process for my lab, but first I would like to benchmark what others are doing.
The poll lists a number of different ways I can think of, and I am interested in other ways that may be used. Also, of course, the method may vary based on the nature of the device.
It would also be interesting to discuss the good and bad points of various methods.
(I hope this works - it's my first attempt at a poll!)
G
Graeme
Marc said:
What? No takers on this?
Maybe I should vote myself -- but I don't want to risk biasing it.
Maybe it's because this is summer holiday month in Europe. :biglaugh: But hey, I'm headed back to England at the end of the week for my summer holiday ...
Ryan Wilde
Graeme,
Actually, it varies. For things like DC Voltage Sources and standard resistors, the variation over time is basically linear, and I use the value that it "should" be today with the uncertainty of that trend. For things like gage blocks, which don't tend to have a linear degradation, I use the last calibration value with uncertainty.
Ryan
G
Graeme
Is being a generalist a specialty?
Ryan Wilde said:
Graeme,
Ryan
Thanks, Ryan - being an electronics person I had not given much thought to the behavior of physical/dimensional standards. If I had thought of it I should have checked to see if the poll engine could handle multiple responses (pick the top 3, for example). But I suspect that trying to cover all possible combinations would overload its ability.
On using "today's" estimated value and uncertainty - I have a couple of questions.
  1. How does a typical bench technician get the values to use?
  2. If you use an automated measurement system, how does that system get the current estimated value of the standard?
Thanks again
Ryan Wilde
Thanks again
All devices that show a linear trend are actually marked with a label on the unit showing that trend, usually in "x ppm/yr", with the corresponding uncertainty of the trend on the label. The technician takes:
(the last calibrated value)+((# days since last cal/365)*(ppm/yr trend))
For automated measurement systems, we write into the datafile for the standard the trend and have the software do the calculations for us, but we normally write our own software with that in mind. We always make accuracy/actual value files separate from the program, and always in a plain text format for ease of editing when necessary. The datafiles are stored in a protected folder to ensure that they aren't tampered with.
Ryan
L
lhiga
Fixed Value Standards
Graeme,
We project the value monthly on the certificate. On our automated system the technician makes a change to the reference number at the beginning of the month.
G
Graeme
Thank you all!
This poll is closed now, and I want to thank everyone for their input. Now I have to find the time to hide out with the data, study it and see what comes out. I will put results here when available, hopefuly by the end of the year.
THANK YOU :thanx: :applause: :agree1: :thanx: to everyone who voted and/or posted.
Q How is Medical Device Number (MDL) assigned to companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
M IATF 16949 - Who should be assigned as the Product Safety Officer? IATF 16949 - Automotive Quality Systems Standard 3
alonFAI AGILE PLM - Deviation - What is the "Assigned Owner" Field Quality Assurance and Compliance Software Tools and Solutions 3
B Lead Auditor Assigned to Effectiveness Check - CAPA Internal Auditing 14
Q I was assigned as Kaizen Leader for our MRB Area - Your advice appreciated Quality Tools, Improvement and Analysis 5
J O & D can not be predetermined, assigned or limited by the customer, only the S. FMEA and Control Plans 1
A What do you call the person who is assigned a Corrective Action Request? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J ?Current Process Controls? and the ?Detection Rank? assigned to them FMEA and Control Plans 16
P Why do you get assigned an auditor from a registrar (that sticks with you) Registrars and Notified Bodies 10
Q Does a Procedure need to have a metric assigned to determine its effectiveness? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S I have been assigned to implement ISO 14001 - Please Advise ISO 14001:2015 Specific Discussions 11
Douglas E. Purdy Personnel performing specific assigned tasks shall be qualified - Interpretation IATF 16949 - Automotive Quality Systems Standard 6
A When should part numbers be assigned? Customer and Company Specific Requirements 13
D Do I need metrics (or numbers) assigned to every QMS process I have identified? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R 4.18 - Defining 'Specific Assigned Tasks' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Proud Liberal Improving low p-value Statistical Analysis Tools, Techniques and SPC 13
BeaBea Registrars with VAR (Value Added Reseller) experience Registrars and Notified Bodies 8
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
F Missing value of Uncertainty B Measurement Uncertainty (MU) 10
F Calibration certificate content - Average Value and True Value ISO 17025 related Discussions 6
S In BAC5300 we have machining mismatch allowed is 3tau, what is the value of tau? Document Control Systems, Procedures, Forms and Templates 1
S Change value of target during a batch Capability, Accuracy and Stability - Processes, Machines, etc. 0
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Torque Value for Different types of Fasteners (Socket Head, Button Head, CSK) Manufacturing and Related Processes 2
M IATF 16949 - 8.5.6.1.1 Providing a list of process controls: Does this requirement add value to QMS? IATF 16949 - Automotive Quality Systems Standard 4
qualprod Cycle times, value stream mapping, inventory, average values? Lean in Manufacturing and Service Industries 1
Ashok sunder What are the criteria for setting a target KPI value against a quality objective? Benchmarking 7
S Adding Value prior to signing EASA Form 1 EASA and JAA Aviation Standards and Requirements 5
M Creating a Plant Level Value Stream Map Process Maps, Process Mapping and Turtle Diagrams 1
A IMDS - Changing the Locked Weight Value RoHS, REACH, ELV, IMDS and Restricted Substances 1
T Value Chain Map for Food Services Industry Service Industry Specific Topics 1
O P-Value less than 0.05. but everything else in control Statistical Analysis Tools, Techniques and SPC 19
qualprod P x I = Value interpretation for residual risk? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
G What degrees of freedom means in uncertainty budget and how do I set the value Measurement Uncertainty (MU) 2
Q Really do they add value (Vision, Mission, Values)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D What is the exact Temperature Coefficient Value to be set on a Conductivity Meter? General Measurement Device and Calibration Topics 2
M Value Stream Mapping Calculations Process Maps, Process Mapping and Turtle Diagrams 5
L How to interpret the average R bar Value shown in the R Chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Non Value Added Corrective Actions IATF 16949 - Automotive Quality Systems Standard 15
R How To Calculate & Print CDF and Lower Bound CDF value for some t(time) with Minitab? Using Minitab Software 1
P Purpose of calculating Uncertainty value in calibration study Measurement Uncertainty (MU) 5
J Agenda of Value Stream Mapping workshop required Quality Tools, Improvement and Analysis 1
M What is the value of documenting in-process rework for easily-detectable issues? Quality Manager and Management Related Issues 4
R VSM - Value Stream Mapping (catheter manufacturing unit) Customer Complaints 10
W Quality for value adding or certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
dubrizo Internal Audit Value - What is the point of conducting internal audits to a checklist Internal Auditing 40
