Assigning the Correct Procedures Applicable to Job Titles
krapow
I'm the management rep for a small (35 employees) job shop. The previous rep kept a skills matrix and assigned specific procedures for all the different job titles in the shop. We have 17 procedures and 15 different job titles. I find it very confusing as to which specific procedures to assign to each job title. Is this at all even necessary? I'm not sure if it is an ISO requirement or not? Any opinions, suggestions? Thanks.
Bill
bkirch
Bill
There is such a thing a over documentation. Without knowing the specifics of your process I am not sure if this is the case or not at your facility. Assuming you are talking about ISO 9001, there are a few requirements that you might want to think about which are ISO 7.2(Competence) and ISO 8.5.1(Control of production and service provision). For ISO 7.2, how do you ensure that person(s) doing the work are competent? For ISO 8.5.1, how do you ensure that you are operating under controlled conditions as is described in section 8.5.1?
Bill
I think you need to be concerned not with procedures (written documents) but with processes. Presumably you've identified the QMS processes, and responsibility and authority has been assigned for each of them. In a company of 35 people it shouldn't be difficult to document those things. Please remember both parts of "responsibility and authority." Much fear and loathing can result from assigning responsibility without the necessary authority.
krapow
Thanks for the suggestions. Yes, we are ISO 9001:2015 certified. It was Clause 7.2 and competence/training that got me to delve into my predecessor's web of procedures welded to job descriptions in the first place. We have 4 or 5 machine programmers (Mastercam) who are responsible for overseeing the machine operators of the mills and lathes. I guess you could say the procedures are "linked to the processes" which is why the job titles are "linked to the procedures." I just couldn't figure out the logic behind an office assistant and say, "Monitoring & Measurement of Product." Almost like he thought, when in doubt, just add the procedure to the job description.
Ninja
Looking for Reality
Howdy,
FWIW...my old company did the same thing. It started with a matrix in XL, then moved to a database for Doc Control and Initial Training needs.
For initial training on hire...it was quite helpful (for our 1500 documents). A simple find for position and out pops a list.
After initial training, it was so useless no one looked at it again. We cross-trained to processes, not positions.
After 5yrs...no one used it at all since it was not kept up to date.
For only 17 procedures...assuming 17 processes...I would pitch the title matrix. It's easy enough to just use my brain.
A side note: Linking processes to job titles starts falling apart pretty quickly if you value cross-training. Either that or everyone will have a different job title. I found it easier to simply identify the employee, and the processes...then simply log which processes (including associated docs) each employee was trained to. Job titles were linked to salary ranges and "feel good" stuff. HTH
krapow
So what you are saying Ninja, is identify the employee and state his or her skills. When you say processes, would that be all-encompassing like, lathe, mill, grinder operator, or in general, just list manufacturing? The deeper one goes into ISO it seems like the nearer one is to crush depth.
John Broomfield
krakow,
Competence is the sum of abilities, skills and knowledge to do the work well; more that just skills so think ASK.
The work itself is the process. Processes though, usually comprise connected tasks so manufacturing is one of your processes.
For each order, manufacturing will comprise a specified combination of tasks completed by operators who have demonstrated their competence.
A competent lathe operator, for example, needs no documented procedure; their procedure ican remain undocumented but it’s useful for everyone to be familiar with what happens before and after their work.
So, apportioning documented procedures according to job title may insult the intelligence of competent workers. Hive off any over documentation to your training manual.
krapow
krakow,
krapow
OK all thank you. I just want to keep it simple. But should processes be listed like so:
sales - planning - receiving - manufacturing - inspection - shipping
T Formal Q Self Assessment - Problem with assigning Product and Process Customer and Company Specific Requirements 1
K IEC 62304 Amd 1 2015 - Figure 3 – Assigning Software Safety Classification IEC 62304 - Medical Device Software Life Cycle Processes 11
Q Corrective Action - Assigning KPIs to Non-Guilty Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V What is the criteria for assigning the new-revision number for an FMEA? FMEA and Control Plans 6
Q Assigning Responsibilities - Responsible Department or positions? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
P Assigning Occurrence level in FMEA ISO 14971 - Medical Device Risk Management 7
AnaMariaVR2 Method or System for Assigning Project File Names US Food and Drug Administration (FDA) 10
J Determining the Appropriate Sampling Regime when Assigning Values to an IVD Device Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Assigning a PDF for Analog Resolutions - OIML R49-2 Test Methods for Cold Water Meter Measurement Uncertainty (MU) 3
B Assigning Targets for Programs in a New Company Miscellaneous Environmental Standards and EMS Related Discussions 16
ScottK Assigning yourself more power and authority. Career and Occupation Discussions 4
S Assigning Internal Part Number Document Control Systems, Procedures, Forms and Templates 4
D Assigning numbers to control plans etc. FMEA and Control Plans 7
G How to ensure dimension of tapping hole before plating is correct? Manufacturing and Related Processes 2
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
R What is the correct way to refer to NIST? Calibration Frequency (Interval) 4
M NANDO codes of products - These are not the GMDN codes, correct? EU Medical Device Regulations 4
K The correct way of doing a 2 Sample T test Reliability Analysis - Predictions, Testing and Standards 7
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
JoshuaFroud How important is using the "correct" GMDN? Other Medical Device Regulations World-Wide 14
M Specifications Aerospace - Who is responsible for providing the correct specification(s) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
supadrai OEM Changing the name of the manufacturer - length of process? Is 1-3 months correct? Other Medical Device Regulations World-Wide 0
J How long should I have to correct an audit finding? VDA Standards - Germany's Automotive Standards 7
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
C UDI Label Verification - How do we ensure the barcode is correct and prove it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
J How to measure process quality? Is DPPM the correct metric? Capability, Accuracy and Stability - Processes, Machines, etc. 5
P The correct way to do a Linearity and Stability Study on a Critical Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
L Choosing the correct Distribution for Acceptance Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
A Safety Shoes & Temporary Workers - Is it correct to reuse again or not? Occupational Health & Safety Management Standards 11
S Definition MTBF and MCBF Correct Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
T What is the correct UMDNS Code for Tracheostomy Tube? Other Medical Device Regulations World-Wide 2
E Correct Statistical Test comparing 2 Groups Statistical Analysis Tools, Techniques and SPC 14
N What is the easiest way to verify we have the correct customer supplied materials? Misc. Quality Assurance and Business Systems Related Topics 5
D The correct way to analyze Skewed Data using Minitab Using Minitab Software 3
C Rolling the correct M8 1.25 Pin Thread Manufacturing and Related Processes 2
E Database search is correct to capture medical device ISO 13485:2016 - Medical Device Quality Management Systems 2
S Choosing the correct Elisa Test Food Safety - ISO 22000, HACCP (21 CFR 120) 1
J TS 16949 - Which definition of Automotive is correct? IATF 16949 - Automotive Quality Systems Standard 3
L Correct Sample Size for Attribute Gage R&R (Good / Bad parts) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R Correct Cable Ports After Work and Weekend Discussion Topics 2
S Is it gramatically correct to say Singapore people or Singaporeans ? Coffee Break and Water Cooler Discussions 12
H Determining the Correct Sample Size when AQL points to two Sample Sizes AQL - Acceptable Quality Level 7
J How IAQG plans to ensure that correct PEAR level determination is done by Auditors? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K AS9102 Form 3 for Assemblies - Verification that the Assembly is Correct AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
