Reaching out to the rest of the group for some ideas/concepts on how to measure perpendicularity in a thin-walled tube end.
I am currently measuring this feature using a (manual) CMM, and have identified that the R&R is a huge factor - analysis of this problem has indicated that this is inherent in the limitations of our equipment (manual operation vs NC operation), error in centralizing measurement points on the thin wall, etc.
As a temporary solution I have implemented an attribute gauge which is effective, however I would (ideally) like to be able to present variable data, to be able to show levels of improvement in the manufacturing process, rather than just 'better', 'worse', or 'the same'.
I would appreciate any suggestions as to how this could be better evaluated. The depth of the -A- datum cylinder is 25mm, tube OD is 60mm, and wall thickness is 1.2mm.
