Asterisk in DOE minitab software
Siavash
Hi every one I wish you have a great day, I need your help, i want to design an experiment but whatever I did i faced asterisks in my final job and I cannot get the answer, even I have increased the number of my replication and decreased the number of interaction factors to 2 but it does not work, I really appreciate if you can help me.
We need more detail. What type of experiment are you trying to design? Where do the asterisks appear? If you attach your Minitab project file, it would help. I can open Minitab 18 or lower.
Siavash
Firstly I made the regression equation, then I have designed the experiment and entered the answers by regression equation then I got the last picture answers
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
U What is the meaning of the Asterisk in Minitab distribution fitting? Using Minitab Software 1
A Uncertainties indicated with an asterisk are traceable, but not UKAS Accredited General Measurement Device and Calibration Topics 7
J Selecting factors for screening DoE design Statistical Analysis Tools, Techniques and SPC 8
J Including Repeats in DoE using Minitab Using Minitab Software 5
J DoE - Number of runs in Plackett-Burman (Minitab) Using Minitab Software 2
J DoE (Design of Experiments) - Multiple responses with different factors Using Minitab Software 2
K Power point training slides on DOE (Design of Experiments) Wanted Training - Internal, External, Online and Distance Learning 2
I DOE: High variance and small effects in Minitab Using Minitab Software 1
M I have 3 different factors - DOE help Statistical Analysis Tools, Techniques and SPC 3
N Do I need to approach galvanized steel sheet flatness issue with DOE? Problem Solving, Root Cause Fault and Failure Analysis 9
V Screening DOE with 7 Input factors and 4 responses - Significant factors Using Minitab Software 1
H Taguchi mixed model DoE [L16 (4^3 2^6): factors interaction and ANOVA calculation Using Minitab Software 3
R Is there any Excel .xls Spreadsheet available for DOE with 3 factors? Six Sigma 1
N DOE (design of experiments) in Minitab 16 Using Minitab Software 6
D Interpretation of DOE interaction plot Using Minitab Software 8
D Minitab - Design combinations (DOE) Using Minitab Software 4
C DOE - How to determine optimal settings and transposing data Statistical Analysis Tools, Techniques and SPC 2
N 3 factor - 3 level experiment with DoE and Minitab Using Minitab Software 10
M DOE: Significant factor or not Using Minitab Software 2
P When can we apply DOE (Design of Experiments)? Six Sigma 8
S DOE Analysis - Experiments with 5 Factors Statistical Analysis Tools, Techniques and SPC 11
R [Minitab] DOE Output vs. Actual Data Using Minitab Software 6
S Blocking In a DOE Six Sigma 1
P Screening DOE: A coming up headache story Quality Tools, Improvement and Analysis 4
Y Please help me solve a DOE problem - New Minitab User Using Minitab Software 36
P Cyclic Effect Factoring in DOE (Design of Experiments) Quality Tools, Improvement and Analysis 1
V Analysing Results after DOE Using Minitab Software 1
V Analysis of DOE Results and Model Finalization Using Minitab Software 4
J How to Estimate the Number of Replicates on a DOE (Design of Experiments) Six Sigma 5
R 4 Factors 3 Level DOE to determine which factors are significant Using Minitab Software 2
K Minitab Lack-of-Fit Test in DOE (Design of Experiments) Using Minitab Software 4
M Injection Moulding Minitab DOE - All P Values are 0 Using Minitab Software 7
G Setting up a 3 Factor, 2 Level,2 response DOE in Minitab Using Minitab Software 7
Z A DOE in Minitab - 3 factors and 3 levels for each factor Using Minitab Software 12
M Taguchi L4 Orthogonal Array Design of Experiments (DOE) in an Excel spreadsheet Excel .xls Spreadsheet Templates and Tools 3
V Linking the FMEA Causes & Action Plan with DOE Experiments or Experimentation Design FMEA and Control Plans 1
B DOE Question: 3 factors with 2 levels and 1 factor with 3 levels Six Sigma 2
Z Help with running 3 factor DOE factor optimization Using Minitab Software 2
H Minitab DOE Analysis of Data and Transforming Using Minitab Software 4
P Help Setting Up and Analyzing 3 Factor 2 Level Full Factorial Design for DOE Using Minitab Software 3
B Taguchi DOE (Design of Experiments) example using Minitab Using Minitab Software 3
C 3 Factor DOE (Design of Experiments) Template Document Control Systems, Procedures, Forms and Templates 0
P How to analyze DOE: 2 Factor, 4 Level Experiment Six Sigma 7
J DOE Analysis Experiment, 5 factors, 4 factors having 3 levels, and 1 factor having 5 Using Minitab Software 38
B Analyze 'Factorial Design' or 'Variability' - Difference when used for DOE Analysis? Using Minitab Software 1
L DOE (Design of Experiments) suggestions Using Minitab Software 7
L DOE (Design of Experiments) - Analyse Variation with Minitab Using Minitab Software 5
E 5^2 DOE (Design of Experiments) with 3 Replications, 5 Levels 2 Factors Statistical Analysis Tools, Techniques and SPC 6
T DOE Multi level Taguchi - I am doing a Capstone Project Using Minitab Software 10
