ASTM E-18 - We test our rockwell tester using calibrated test blocks
dbulak
I don't know if I am understanding ASTM E-18 correctly. Everyday we test our rockwell tester using calibrated test blocks. For example, the B and C scale get checked every morning. My question is, if we change from the B scale to the C scale during the course of the day do we have to retest the rockwell tester with the test block again? ASTM E-18 says when you check each scale, but nothing about using the rockwell tester for multiple scales. Anyone have any thoughts on this? As always many, many thanks in advance!
andygr
Para 13.5.1.5 has report by scale. I interpert this as you have to do it for each scale. If you do not change you machine over to each scale durring the verification process ( can be done with some digital units) and see what the actual is you are just performing interpolations for the other scales not verified with actuals as required by spec. I see it as covering all those pesky things called variables.
Maybe some of the calibration folks here can guide us?
K
Kevin H
What we did at the mechanical testing lab I ran in a steel mill was to test our Rockwell units at the start of each turn - most of the product we ran was on the "B" Scale, so we did an initial test on the B scale following the recomendations in section 14 for periodic checks by the User - if we had to change scales to either C or one of the superficial scales such as 15, 30, or 45 T or 15, 30, 45 N we would change the indenter if required, select the proper weight ranges on the machines, do two preliminary tests to ensure that the indenter was properly set and that the tester was working properly, and then check the test blocks per section 14 of ASTM E18. If we switched back to the B or other scale that we had already tested, we did not recheck that scale as described by section 14 again during that turn. However, we did do 2 preliminary tests to ensure that the indenter was properly seated and that the tester was working properly.
We'd log all of the periodic checks in a log book noting scale, date & turn, tester's initials, and actuall test results so that we could go back and troubleshoot if we had any test issues or complaints from a customer regarding Rockwell hardness test results. I never had any issues with our
A2LA assessor for ISO Guide 25 with our Rockwell testing in those areas. Only issue I ever had was to add to our procedure for Rockwell testing that the checks had to be 3 indentations apart and at least two indications in from the edge of the test block.
SteelMaiden
What he said...we did document training and reference the standards in our procedures for testing. Once we calibrated for a shift, we only did a couple of "seating" tests prior to the documented hardness tests. We did two seating tests on each sample, not just when changing the indenter.
W ASTM F1929 dye penetration test - Validation for in-house testing ISO 13485:2016 - Medical Device Quality Management Systems 16
M Package Integrity Test ASTM F 2096 or ASTM 1929 Quality Assurance and Compliance Software Tools and Solutions 1
M Accelerated Ageing Test for Orthopedic Implants -- ASTM F 1980 or ISO 11607 or both are applicable ? Other Medical Device and Orthopedic Related Topics 2
S ASTM F2179-02 Glass Scratch Test Procedure Requirements Manufacturing and Related Processes 1
J Galvanizing and ASTM A90 - Coating Weight Test Compliance Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D ASTM 684/A684M-10a Bend Test Method Manufacturing and Related Processes 2
S ASTM E515 - Leaking Test - What is a wetting agent? Manufacturing and Related Processes 1
S Predicate Device Test Results - ASTM F1717 Static and Dynamic Testing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Number of Test Samples - ASTM D2137 Method A 9.3.2 Various Other Specifications, Standards, and related Requirements 1
A Burst Test equipment to perform ASTM F1140 Manufacturing and Related Processes 6
M ASTM F88 Standard Test Method for Seal Strength - Designation F88-09/M88-09 ver 15.1 Reliability Analysis - Predictions, Testing and Standards 6
J Salt Spray Test on 3 year old Zinc Die Casting Chromed part per ASTM B 117-03 Manufacturing and Related Processes 2
G Definition ASTM D624 - Test Method for Tear Strength of Vulc. Rubber & Thermo. Elastomers Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
S Needs clarification on tensile test on SS class F 431 material as per ASTM A 473 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G Who can test to ASTM D808, ASTM D4327 and ASTM D1179 (Halide Ion) Reliability Analysis - Predictions, Testing and Standards 1
C Standard hardness test procedures for ASTM-E18-03 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M Packaging standards - ASTM vs ISTA Other Medical Device Related Standards 0
M Label Making & Printing Standards ISO / ASTM ISO 13485:2016 - Medical Device Quality Management Systems 5
M Packaging studies - ISTA vs ASTM CE Marking (Conformité Européene) / CB Scheme 0
N Database that lists labs accredited to ASTM / ANSI standards Various Other Specifications, Standards, and related Requirements 6
E ASTM F2118 - Fatigue testing of bone cement - Changes between the 2003 and the 2014? Other Medical Device Related Standards 1
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
P What ASTM std is EC 93/42 MDD EQUIVALENT TO CE Marking (Conformité Européene) / CB Scheme 1
D ASTM C1064 Temperature Measuring Device General Measurement Device and Calibration Topics 2
K Troubleshooting Salt Spray (ASTM B117) Manufacturing and Related Processes 2
P Average Peel Strength - Interpretation of BS EN 868-5:2018 and ASTM F0088/F0088M Other Medical Device Related Standards 2
B ASTM F2924-14 /ASTM F3001 - Room temperature classification criteria Other US Medical Device Regulations 0
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
B Stability testing of medical devices as per ASTM F1980-16 CE Marking (Conformité Européene) / CB Scheme 0
M ASTM A6 Material Standard - Section Nominal Sizes Manufacturing and Related Processes 1
M Real-time-aging Validation - ISO / ASTM Standard - Class 111 Orthopedic Implant Other Medical Device and Orthopedic Related Topics 1
D Non ASTM Partial Immersion LGT emergent stem correction General Measurement Device and Calibration Topics 3
2 ASTM or ISO Specifications on Prints Other US Medical Device Regulations 2
M ASTM F 75-12 - Tensile properties Product castings ( 7.1 ) vs Casting alloys ( 7.2) Other ISO and International Standards and European Regulations 1
X Heat Treat - Verifying mechanical properties on heat treated material per the ASTM Manufacturing and Related Processes 6
M ISO / ASTM standards for Sampling Plans for Medical Devices Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Are ASTM F745 & ASTM F75 still valid? EU Medical Device Regulations 5
Q M-282 - Engineering Standard for Tolerances - Is it ASTM, DIN? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Correlation between ASTM & China's GB (Guobiao) / YY Standards China Medical Device Regulations 4
Ron Rompen Water Immersion Testing ASTM D870 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
E ASTM D3951 Part Marking Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M ASTM Stainless Steel Density Table Various Other Specifications, Standards, and related Requirements 1
S ASTM-D4000 & FORD "ZW" Call-Outs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S ASTM-1965-98 (Reapproved 2009) has contradictory requirements? Other Medical Device Related Standards 2
P ASTM-F2096 Medical Package Testing Various Other Specifications, Standards, and related Requirements 1
T ISO 2409 / ASTM D3359 Paint Adhesion Other ISO and International Standards and European Regulations 8
T ISO/BS/DIN/EN/ASTM - Standards Equivalencies Other ISO and International Standards and European Regulations 3
Q ASTM Specification Revision Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
