ASTM E165 Liquid Penetrant Equivalent
dickgent
I have many customers and many international standard requirements. Are ANY the following equivalent for detecting flaws, cracks, inclusions in steel and welds? I s anyone aware of a matrix for comparative analysis? Or let's start a discussion, can one be created?
This from WIKI:
Wikipedia reference-linkDye_penetrant_inspection
Standards
International Organization for Standardization (ISO)
ISO 3059, Non-destructive testing - Penetrant testing and magnetic particle testing - Viewing conditions
ISO 3452-1, Non-destructive testing. Penetrant testing. Part 1. General principles
ISO 3452-2, Non-destructive testing - Penetrant testing - Part 2: Testing of penetrant materials
ISO 3452-3, Non-destructive testing - Penetrant testing - Part 3: Reference test blocks
ISO 3452-4, Non-destructive testing - Penetrant testing - Part 4: Equipment
ISO 3452-5, Non-destructive testing - Penetrant testing - Part 5: Penetrant testing at temperatures higher than 50 °C
ISO 3452-6, Non-destructive testing - Penetrant testing - Part 6: Penetrant testing at temperatures lower than 10 °C
ISO 12706, Non-destructive testing - Penetrant testing - Vocabulary
ISO 23277, Non-destructive testing of welds - Penetrant testing of welds - Acceptance levels
European Committee for Standardization (CEN)
EN 571-1, Non-destructive testing - Penetrant testing - Part 1: General principles. May be replaced by EN ISO 3452-1.
EN 1371-1, Founding - Liquid penetrant inspection - Part 1: Sand, gravity die and low pressure die castings
EN 1371-2, Founding - Liquid penetrant inspection - Part 2: Investment castings
EN 2002-16, Aerospace series - Metallic materials; test methods - Part 16: Non-destructive testing, penetrant testing
EN 10228-2, Non-destructive testing of steel forgings - Part 2: Penetrant testing
EN 10246-11, Non-destructive testing of steel tubes - Part 11: Liquid penetrant testing of seamless and welded steel tubes for the detection of surface imperfections
ASTM International (ASTM)
ASTM E 165, Standard Practice for Liquid Penetrant Examination for General Industry
ASTM E 1417, Standard Practice for Liquid Penetrant Testing
American Society of Mechanical Engineers (ASME)
ASME Boiler and Pressure Vessel Code, Section V, Art. 6, Liquid Penetrant Examination
ASME Boiler and Pressure Vessel Code, Section V, Art. 24 Standard Test Method for Liquid Penetrant Examination SE-165 (identical with ASTM E-165)
All Help is appreciated:bigwave:
michaelrm
NDT code PT
see the following link for a few more details:
http://www.airliners.net/aviation-forums/tech_ops/read.main/235694/
These tests are normally carried out by 3rd party Inspection service providers, looks for surface defects and weld defects as well - depending on the dye penetrate used.
I can discuss/assist you if required in this area if needed, my responses may be slow and coming but will try and assist.
Question to you -
do you have welders working for your organisation?
which industry type is your organisation in?
Cheers
dickgent
Thanks for the reply... sorry for the response delay. I too don't get many opportunities to visit the site.
Yes we have certified welders on site with WPS; PQR; and material certifications. We engineer Large processing lines for a worldwide client base. I do not want to create a separate set of standard requirements for each client in their own country of origin (JIS; EN; DIN; CE; SAE; etc. etc. ) This test (minimum requirement for piping) is just one of many examples of why I need an authority to provide equivalent international standard recommendations. Thank You for your response.
michaelrm
We operate in the same industry sector, I would recommend a 3rd party inspection service that can provide the expertise required to guide you in creating and maintaining your standards, for example http://www.ndeglobal.com/home.html is one of many in operation (I have nothing to do with NDE but have used them in past).
What I have done is to concentrate on all the global standards and build up a library over time, ignoring the client to point and just concentrating on the global standard, this way a template is created that can be adjusted to fit any clients requirements.
Does your organisation have a procedure/process to track each weld in regard to the weld traceability, and the allocation and tracking of materials consumed in the manufacturing process. As well as the maintaining of the welder qualifications to ensure that all welders are qualified to perform to the clients standard?.
dickgent
Yes, We have certified welders, WPS's, PQRs, and My QC Inspector will be certified to ASNT Level II in the fall. I have many of the standards and have done comparisons between some international standards but I would more confident with some outside agency providing the analysis rather than my own interpretation. Some standard organizations specifically reference compatibility (CE to ASME; ASME to AWS; etc ) but not in any great detail. I guess my hope for an all inclusive comparison and compatibility matrix is just that .... A HOPE. Thanks for all of the replies
Best Regards
dickgent
michaelrm
Hope is all we ever have, what I have done is like I said created a full library over time for all specification and use that as a reference.
Screen dump of the weld specification library system - attached
All the best
M Packaging standards - ASTM vs ISTA Other Medical Device Related Standards 0
M Label Making & Printing Standards ISO / ASTM ISO 13485:2016 - Medical Device Quality Management Systems 5
M Packaging studies - ISTA vs ASTM CE Marking (Conformité Européene) / CB Scheme 0
N Database that lists labs accredited to ASTM / ANSI standards Various Other Specifications, Standards, and related Requirements 6
E ASTM F2118 - Fatigue testing of bone cement - Changes between the 2003 and the 2014? Other Medical Device Related Standards 1
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
P What ASTM std is EC 93/42 MDD EQUIVALENT TO CE Marking (Conformité Européene) / CB Scheme 1
W ASTM F1929 dye penetration test - Validation for in-house testing ISO 13485:2016 - Medical Device Quality Management Systems 16
D ASTM C1064 Temperature Measuring Device General Measurement Device and Calibration Topics 2
K Troubleshooting Salt Spray (ASTM B117) Manufacturing and Related Processes 2
P Average Peel Strength - Interpretation of BS EN 868-5:2018 and ASTM F0088/F0088M Other Medical Device Related Standards 2
B ASTM F2924-14 /ASTM F3001 - Room temperature classification criteria Other US Medical Device Regulations 0
M Package Integrity Test ASTM F 2096 or ASTM 1929 Quality Assurance and Compliance Software Tools and Solutions 1
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
M Accelerated Ageing Test for Orthopedic Implants -- ASTM F 1980 or ISO 11607 or both are applicable ? Other Medical Device and Orthopedic Related Topics 2
B Stability testing of medical devices as per ASTM F1980-16 CE Marking (Conformité Européene) / CB Scheme 0
M ASTM A6 Material Standard - Section Nominal Sizes Manufacturing and Related Processes 1
M Real-time-aging Validation - ISO / ASTM Standard - Class 111 Orthopedic Implant Other Medical Device and Orthopedic Related Topics 1
D Non ASTM Partial Immersion LGT emergent stem correction General Measurement Device and Calibration Topics 3
2 ASTM or ISO Specifications on Prints Other US Medical Device Regulations 2
M ASTM F 75-12 - Tensile properties Product castings ( 7.1 ) vs Casting alloys ( 7.2) Other ISO and International Standards and European Regulations 1
X Heat Treat - Verifying mechanical properties on heat treated material per the ASTM Manufacturing and Related Processes 6
M ISO / ASTM standards for Sampling Plans for Medical Devices Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Are ASTM F745 & ASTM F75 still valid? EU Medical Device Regulations 5
Q M-282 - Engineering Standard for Tolerances - Is it ASTM, DIN? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Correlation between ASTM & China's GB (Guobiao) / YY Standards China Medical Device Regulations 4
Ron Rompen Water Immersion Testing ASTM D870 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
E ASTM D3951 Part Marking Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M ASTM Stainless Steel Density Table Various Other Specifications, Standards, and related Requirements 1
S ASTM-D4000 & FORD "ZW" Call-Outs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S ASTM-1965-98 (Reapproved 2009) has contradictory requirements? Other Medical Device Related Standards 2
P ASTM-F2096 Medical Package Testing Various Other Specifications, Standards, and related Requirements 1
T ISO 2409 / ASTM D3359 Paint Adhesion Other ISO and International Standards and European Regulations 8
T ISO/BS/DIN/EN/ASTM - Standards Equivalencies Other ISO and International Standards and European Regulations 3
Q ASTM Specification Revision Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Coke Reactivity Index (CRI) Testing Code Interpretation: ASTM D5341-99 (2004) Various Other Specifications, Standards, and related Requirements 2
P ASTM Standard, Stainless Steel angle that has been rejected because it is not ?square Manufacturing and Related Processes 2
N Protein content limit in condom according to ASTM standard Other ISO and International Standards and European Regulations 3
S Magnetic Resonance ? Testing to ASTM F2503-08 Other Medical Device Related Standards 6
L Product numbers & sources for ASTM D3359 adhesive tape Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R ASTM A967 Testing Interpretation - No Customer Requirements Manufacturing and Related Processes 3
E Withdrawal of ASTM F-745 07 CE Marking (Conformité Européene) / CB Scheme 5
J Salt Spray Failure Question (ASTM B 633 and B 117) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
S ASTM F2179-02 Glass Scratch Test Procedure Requirements Manufacturing and Related Processes 1
G Free ASTM Standards? Recent Court Ruling making their standards free? Various Other Specifications, Standards, and related Requirements 10
S ASTM Standard for Hardness Spec for 6063 T6 Aluminum Extrusions Various Other Specifications, Standards, and related Requirements 1
N FDA vs ASTM - Limitations of Powder Content in Gloves Other Medical Device Regulations World-Wide 3
S Followups to ASTM F2554-10? Surgical Navigation System Accuracy Other Medical Device Related Standards 1
