ASTM E2309-05 Classification Table - Fixed to Relative Errors
E
edge540
I am looking into this standard to verify some things we are doing and am having a hard time to understand the classification table and how to apply the fixed error for resolution & % of reading or % of displacement and if there is some cross over from Fixed to Relative error as there is in E83.
Can someone explain it? The standard is not giving any examples and I'm having a hard time to get my head wrapped around this (maybe because it's Monday...)
For instance, I have a machine with a 0.1um resolution.
To meet class B what is the allowable +/- tolerance for displacement error at 100mm.
I am making up an excel sheet so I can just make simple inputs to get the correct allowable error for any give set point based on the class table.
Marc
I'm giving this one another 'Bump' in case someone here can help with this one. My Thanks in advance!
N
NTAinc
I reviewed this standard recently myself. The classification table basically means that at any displacement your measurement has to meet two different criteria to be classified within that class. For your example, to meet class B at 100mm your resolution, at that displacement, can not be greater than 0.5mm and the allowable error in the measurement is +/-1.0mm. For all readings from your lower limit (resolution times 200) to 7.5mm the allowable error is +/-0.075mm, above that will be +/-1.0% of displacement. The resolution has to be less than 0.038mm for all measurements 7.6mm and below and less than 0.5% of the reading over that. Simply put it is very similar to the classifications table in E83. Hope this helped.
Tessa
E
edge540
I actually went to Gary directly (author / contact for the standard) and got pretty much the same answer.
For what ever reason I could not wrap my head around that one... I understand E83 quite well but with the absence of a gauge length I was kind of stumped how to put the math together... I am making up a little excel sheet to give tolerances based on the variables and classifications for our field techs to use and getting it right the first time is the best way.
Thanks for the answer and help with this.
Hershal
Metrologist-Auditor
OK guys, maybe I misread.
We have 100mm total, 0.1micrometer resolution. Exactly WHAT is being used for this measurement?
What is the uncertainty?
Is this in the field or in a higher level lab?
Help me out here.
Hershal
M Packaging standards - ASTM vs ISTA Other Medical Device Related Standards 0
M Label Making & Printing Standards ISO / ASTM ISO 13485:2016 - Medical Device Quality Management Systems 5
M Packaging studies - ISTA vs ASTM CE Marking (Conformité Européene) / CB Scheme 0
N Database that lists labs accredited to ASTM / ANSI standards Various Other Specifications, Standards, and related Requirements 6
E ASTM F2118 - Fatigue testing of bone cement - Changes between the 2003 and the 2014? Other Medical Device Related Standards 1
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
P What ASTM std is EC 93/42 MDD EQUIVALENT TO CE Marking (Conformité Européene) / CB Scheme 1
W ASTM F1929 dye penetration test - Validation for in-house testing ISO 13485:2016 - Medical Device Quality Management Systems 16
D ASTM C1064 Temperature Measuring Device General Measurement Device and Calibration Topics 2
K Troubleshooting Salt Spray (ASTM B117) Manufacturing and Related Processes 2
P Average Peel Strength - Interpretation of BS EN 868-5:2018 and ASTM F0088/F0088M Other Medical Device Related Standards 2
B ASTM F2924-14 /ASTM F3001 - Room temperature classification criteria Other US Medical Device Regulations 0
M Package Integrity Test ASTM F 2096 or ASTM 1929 Quality Assurance and Compliance Software Tools and Solutions 1
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
M Accelerated Ageing Test for Orthopedic Implants -- ASTM F 1980 or ISO 11607 or both are applicable ? Other Medical Device and Orthopedic Related Topics 2
B Stability testing of medical devices as per ASTM F1980-16 CE Marking (Conformité Européene) / CB Scheme 0
M ASTM A6 Material Standard - Section Nominal Sizes Manufacturing and Related Processes 1
M Real-time-aging Validation - ISO / ASTM Standard - Class 111 Orthopedic Implant Other Medical Device and Orthopedic Related Topics 1
D Non ASTM Partial Immersion LGT emergent stem correction General Measurement Device and Calibration Topics 3
2 ASTM or ISO Specifications on Prints Other US Medical Device Regulations 2
M ASTM F 75-12 - Tensile properties Product castings ( 7.1 ) vs Casting alloys ( 7.2) Other ISO and International Standards and European Regulations 1
X Heat Treat - Verifying mechanical properties on heat treated material per the ASTM Manufacturing and Related Processes 6
M ISO / ASTM standards for Sampling Plans for Medical Devices Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Are ASTM F745 & ASTM F75 still valid? EU Medical Device Regulations 5
Q M-282 - Engineering Standard for Tolerances - Is it ASTM, DIN? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Correlation between ASTM & China's GB (Guobiao) / YY Standards China Medical Device Regulations 4
Ron Rompen Water Immersion Testing ASTM D870 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
E ASTM D3951 Part Marking Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M ASTM Stainless Steel Density Table Various Other Specifications, Standards, and related Requirements 1
S ASTM-D4000 & FORD "ZW" Call-Outs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S ASTM-1965-98 (Reapproved 2009) has contradictory requirements? Other Medical Device Related Standards 2
P ASTM-F2096 Medical Package Testing Various Other Specifications, Standards, and related Requirements 1
T ISO 2409 / ASTM D3359 Paint Adhesion Other ISO and International Standards and European Regulations 8
T ISO/BS/DIN/EN/ASTM - Standards Equivalencies Other ISO and International Standards and European Regulations 3
Q ASTM Specification Revision Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Coke Reactivity Index (CRI) Testing Code Interpretation: ASTM D5341-99 (2004) Various Other Specifications, Standards, and related Requirements 2
P ASTM Standard, Stainless Steel angle that has been rejected because it is not ?square Manufacturing and Related Processes 2
N Protein content limit in condom according to ASTM standard Other ISO and International Standards and European Regulations 3
S Magnetic Resonance ? Testing to ASTM F2503-08 Other Medical Device Related Standards 6
L Product numbers & sources for ASTM D3359 adhesive tape Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R ASTM A967 Testing Interpretation - No Customer Requirements Manufacturing and Related Processes 3
E Withdrawal of ASTM F-745 07 CE Marking (Conformité Européene) / CB Scheme 5
J Salt Spray Failure Question (ASTM B 633 and B 117) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
D ASTM E165 Liquid Penetrant Equivalent Other ISO and International Standards and European Regulations 6
S ASTM F2179-02 Glass Scratch Test Procedure Requirements Manufacturing and Related Processes 1
G Free ASTM Standards? Recent Court Ruling making their standards free? Various Other Specifications, Standards, and related Requirements 10
S ASTM Standard for Hardness Spec for 6063 T6 Aluminum Extrusions Various Other Specifications, Standards, and related Requirements 1
N FDA vs ASTM - Limitations of Powder Content in Gloves Other Medical Device Regulations World-Wide 3
