Attribute Data and Capability Study of Holes in Parts
jimmccafferty
Hi everyone,
I have been asked to find out if the process of putting in the holes on one of our parts is capable. This part has 810 (that’s right 810) 0.030” +/-0.002” holes in it. These holes are put in with a laser and the customer want to know if it is a capable process. I’m being told that when this job started we sent 10 parts out and had the holes checked for diameter and location and all was good, but now no-one can find the reports.
We have the hole locations as “Program Controlled”, and we do random go/nogo checks for the diameter. Now the customer wants to know if the hole diameter is capable. What do I do?
We have decided to use the go/nogo gage and check 10 parts. 810 holes X 10 parts = 8100 holes. Ok now what. I’ve been reading a lot about np-charts but I’m not sure. Also, I have been reading about defect rates and simulated cpk values. What is the best approach to this?
Thanks,
Jim
bobdoering
Stop X-bar/R Madness!!
Re: Attribute Data and Capability of Holes in Parts
Is the customer's question of capability on the location or the size? If the location - how is the hole location called out? Are the holes punched out? Do the care about the roundness (go/no go only checks MMC).
jimmccafferty
They are only interested in size. The holes are put in with a laser. roundness is not an issue. The qeustion from the customer is "Is the hole size capable?" The only way management wants to do this is with a go/nogo pin and a body! go figure! Thanks Jim
Rand T
Is there anything special about 1 hole that makes it likely to have more variation than any other?
I would think just performing the capability on a handful of holes on different areas of the part would be sufficient instead of doing every single one of the 810 holes.
been there done that! my condolences...
however, this isn't all bad.
a few clarifying questions:
how are the individual holes created: a single laser and incremetning the part? a single laser, incrementing the laser? multiple lasers and incrementing the lasers or part?
how long does it take to create the holes in a single part?
how many parts do you make in a day?
are there other parts run on this machine - I'm poking at hwo many set-ups are done in a day or week...
how exactly does the go/no-go gage work?
can you use a set of pin gages to categorize the hole size? If so I think we can get your sample size down. (I would recommend random sampling of various holes across the part and over more than 10 parts)
David DeLong
Hi everyone,
Thanks,
Jim
Here is a case where the customer does not seem to have common sense. On a hole diameter this small, a go/no go gauge is appropriate. If someone wanted capability of size, one would have to take 1 hole on at least 30 different parts and measure the diameter in the same orientation (direction) on each. It is just too small to perform so I would ask the customer how they would suggest performing hole size capability and then only perform reflecting the capability on 1 hole and not 810.
Location of holes - If the location on each of the 810 holes is shown in GD&T with a positional tolerance, the job become colossal & I would not perform it unless it was written into the contract. Just imagine, 810 holes a at least 30 parts = 24,300 measurements. I have a web site shown why capability of positional tolerances is not practical
http://www.qmsi.ca/capabilityindex.html
If co-ordinate tolerance are used, then we would have to double the number of measurement since we need 2 (length and width) for each hole giving us a result of 48,600 - We would need capability results on 1620 measurements. This is madness.
I don't think its a question of 'madness'. It is a reasonable request for a customer to ask for the capability of the process to manufacture hole size to spec. 'madness' would be if they dictated how the capability was to be measured, calculated and reported if that approach involved a 'traditional' calculation of Cpk assuming a Normal distribtuion and they specified the sampling plan without regard/lnowledge of the process by which the parts are manufactured...
The OP didn't say the custoemr asked for a Cpk value, only capability. there are smart ways to do this - but we would need to understand the answers to the questions I posted as there are many ways and I would hate to randomly guess and throw out different scenarios, none of which may fit the OP's need.
jimmccafferty
Answer: Laser fires in the center, then moves out the radius, cuts the hole, moves out and the table indexes 1.3333degs, repeat. Only one laser but it is a 5 axis laser head.
Answer: One hour
Answer: ten, then maybe none for a week (except other part numbers)
Answer: Many different parts are cut or drilled on this machine.
Answer: Operators sketch tells him to check a row of holes at 12, 3, 6, & 9 O' clock. No charting is done. Before the next operation a worker uses a pin to make sure that there are no blockages or burrs in each hole. This is only a stiff peice of wire
Yes we do have pin gages. but as stated above we make these ten at a time and then maybe ten more within two days or it could be two weeks, two months, it all depends on the orders from the customer JIT.
And yes you are correct, customer asked if the process is capable not for a Cpk.
Thanks everyone,
Jim
bobdoering
That would be my approach. Get a set of gage pines that divide your tolerance into at least 10 divisions. Poke the hole until one goes in and the consecutive one does not. Report the pin size that went in, it is variable data, and you should be able to calculate the Cpk from that.
jimmccafferty
The above may be the direction we take, unless you guys can help me make this less of a big PIMA.
Yes, thank heavens the person before me had the sence to do this part up front and then talk the customer into "Program Controlled" for the life of the part.
Thanks,
Jim
C Process Capability - Attribute Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
O Capability Studies: Can I combine Attribute Data and Variables Data Capability, Accuracy and Stability - Processes, Machines, etc. 2
T Advice on PPAP Attribute Data Capability - Go/No-Go APQP and PPAP 3
kedarg6500 Process Capability for Attribute Data - Excel .xls spreadsheet wanted Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Visual Inspection - Capability Study on Attribute Data Capability, Accuracy and Stability - Processes, Machines, etc. 13
C Is X-Ray Data Variable or Attribute? How to do a capability study? Statistical Analysis Tools, Techniques and SPC 3
K Transform variable data into attribute data Reliability Analysis - Predictions, Testing and Standards 24
B Easy Software Needed for Recording Mainly Attribute Data Quality Assurance and Compliance Software Tools and Solutions 2
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
T Attribute vs Variable Inspection Data ISO 13485 Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P RQL/AQL from Attribute Data Six Sigma 1
M Population failure rate based on attribute data Statistical Analysis Tools, Techniques and SPC 4
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
B Bayes Success-Run on Attribute Data - Determining Sample Size Statistical Analysis Tools, Techniques and SPC 2
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Best Attribute Data Sampling Plan - Early Production Containment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Attribute Data MSA for more than 3 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
kedarg6500 Gage R&R for Attribute Data - Pump Noise Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Is Cpk required for all Attribute Data Special Characteristics? IATF 16949 - Automotive Quality Systems Standard 6
optomist1 Sample Size for Attribute Binary Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
M PFMEA (Process FMEA) for Attribute Data Inspection Process FMEA and Control Plans 2
V Sample Size for Attribute Data - Large Production Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B How many Samples are required in Attribute Data MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C MSA on Attribute Data - Can use Different Parts with Different Cosmetic Issues? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Hami812 Attribute Data Gage R&R - Managing Data Sets - Minitab Using Minitab Software 2
C Analyzing Attribute Data - Mechanical Pull Testing of Joint Statistical Analysis Tools, Techniques and SPC 15
W Sampling Plan problem - Determining Sample Size for both Attribute and Variables Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
optomist1 Binary & Attribute Data Measures - Electrical Field Failures or Opens Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Binary logistic regression for attribute/discrete data Using Minitab Software 7
G Attribute Data Inspection Sampling Matrix Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Visual Inspection (Attribute Data) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
T Sorting Out Attribute Data - What is this data telling me? Statistical Analysis Tools, Techniques and SPC 7
C Attribute Data - What is the required sample size (medical field)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
L Process controls on attribute data - Chrome plating manual buffing line Capability, Accuracy and Stability - Processes, Machines, etc. 10
R Method to compute Cpk for Attribute Data? Capability, Accuracy and Stability - Processes, Machines, etc. 3
A Sampling - Measuring and Inspecting a part with both Variable & Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
Q Is DPM defective parts per million a form of Attribute Data Sampling? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q ISO/TS 16949 Questions About clause 7.1.2. Attribute Data Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
J Gage R&R on Attribute Data Using Minitab 14 - Data from Automated Test Systems Quality Tools, Improvement and Analysis 2
H Attribute Data Gage R&R - Queries of data from a system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
G Customer is requesting Variable Data for Attribute Gages in Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
L MSA 3rd Edition - Attribute Data - Page 134 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Excel .xls Template for Attribute Gage R&R with ORDINAL Data needed Excel .xls Spreadsheet Templates and Tools 10
Antonio Vieira Gage R&R Studies for Attribute Data? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D MSA for Attribute Data System - We have a gauge called ?Focus? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Finding Sample Size - Data Type is Attribute Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
N Determining Sample Size for Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Do we need to perform Stability, Linearity & Bias study for Attribute data? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
