Attribute Data Gage R&R - Queries of data from a system
#11
Until it's known that the same queries will return the same responses every time (if that's what's supposed to be happening), there's no point in looking at what operators are doing. Some part of this has to be controlled in order for any type of experiment to yield useful results.
it all depends on the data, the databases and what a priori knowledge you have. I have started several projects with the 'operator entry' side since I knew their was considerable judgment to the categories and so if the categorization was unreliable it didn't matter if the queries were reliable...
on the other hand I've also had projects where the database was redundant and queries were 'ad hoc' and 'known' to not match but the data was not judgment based and so was more likely to be relatively reliable. In these cases I started at the query end...
it all depends.
#12
Which was my point, at least indirectly. Nonetheless, there still must be an element of control somewhere. If we know that a properly-formed query will return consistent results, then we can look at the effect of operators. On the other hand, if we know that operators are well-trained in constructing queries we can test for the quality of the database and/or the programming. One or the other must be controlled before results will make any sense. We need to identify the null hypothesis, in other words.
Benjamin28
#13
"screwed up"? I guess you haven't been following the threads on operator error and their causes...
I like the referral to operator error threads :lol: you're right, it's process error;)
The sentence was just my way of being facetious and saying I would try and keep it simple. It would seem that the areas where variation could occur are relatively limited and so I would attempt to locate where that variation is coming from, or if it exists, before trying to measure how much variation there is between users.
H
hom_er
#14
Thank you all.
Maybe a Gage R&R isn't the appropriate word for the study. Based on the study set up, I hope to find 2 things...1) can I consistenly get the same results from the database and 2) are the operators well-trained to create queires and pull data.
#15
controlling one of the factors, hmmm. but doesn't a properly designed R&R study provide you information on both of these separately and combined just liek any full factorial experiment? Aren't we as a profession trying to get away from holding factors constant and varying one thing at a time? the challenge as always to design the factors and levels appropriately but *most* R&R studies are pretty easy to design that way.
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
kedarg6500 Gage R&R for Attribute Data - Pump Noise Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Hami812 Attribute Data Gage R&R - Managing Data Sets - Minitab Using Minitab Software 2
B Visual Inspection (Attribute Data) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
J Gage R&R on Attribute Data Using Minitab 14 - Data from Automated Test Systems Quality Tools, Improvement and Analysis 2
G Customer is requesting Variable Data for Attribute Gages in Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Excel .xls Template for Attribute Gage R&R with ORDINAL Data needed Excel .xls Spreadsheet Templates and Tools 10
Antonio Vieira Gage R&R Studies for Attribute Data? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J How to do attribute data GR&R (Gage R&R)? Do a Kappa study or follow the MSA book? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Transform variable data into attribute data Reliability Analysis - Predictions, Testing and Standards 24
B Easy Software Needed for Recording Mainly Attribute Data Quality Assurance and Compliance Software Tools and Solutions 2
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
T Attribute vs Variable Inspection Data ISO 13485 Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P RQL/AQL from Attribute Data Six Sigma 1
M Population failure rate based on attribute data Statistical Analysis Tools, Techniques and SPC 4
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
B Bayes Success-Run on Attribute Data - Determining Sample Size Statistical Analysis Tools, Techniques and SPC 2
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
B Best Attribute Data Sampling Plan - Early Production Containment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Attribute Data MSA for more than 3 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Is Cpk required for all Attribute Data Special Characteristics? IATF 16949 - Automotive Quality Systems Standard 6
optomist1 Sample Size for Attribute Binary Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
C Process Capability - Attribute Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
M PFMEA (Process FMEA) for Attribute Data Inspection Process FMEA and Control Plans 2
V Sample Size for Attribute Data - Large Production Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B How many Samples are required in Attribute Data MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C MSA on Attribute Data - Can use Different Parts with Different Cosmetic Issues? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Analyzing Attribute Data - Mechanical Pull Testing of Joint Statistical Analysis Tools, Techniques and SPC 15
W Sampling Plan problem - Determining Sample Size for both Attribute and Variables Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
optomist1 Binary & Attribute Data Measures - Electrical Field Failures or Opens Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Attribute Data and Capability Study of Holes in Parts Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Binary logistic regression for attribute/discrete data Using Minitab Software 7
O Capability Studies: Can I combine Attribute Data and Variables Data Capability, Accuracy and Stability - Processes, Machines, etc. 2
G Attribute Data Inspection Sampling Matrix Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T Advice on PPAP Attribute Data Capability - Go/No-Go APQP and PPAP 3
T Sorting Out Attribute Data - What is this data telling me? Statistical Analysis Tools, Techniques and SPC 7
kedarg6500 Process Capability for Attribute Data - Excel .xls spreadsheet wanted Capability, Accuracy and Stability - Processes, Machines, etc. 5
C Attribute Data - What is the required sample size (medical field)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
L Process controls on attribute data - Chrome plating manual buffing line Capability, Accuracy and Stability - Processes, Machines, etc. 10
R Method to compute Cpk for Attribute Data? Capability, Accuracy and Stability - Processes, Machines, etc. 3
A Sampling - Measuring and Inspecting a part with both Variable & Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
B Visual Inspection - Capability Study on Attribute Data Capability, Accuracy and Stability - Processes, Machines, etc. 13
Q Is DPM defective parts per million a form of Attribute Data Sampling? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q ISO/TS 16949 Questions About clause 7.1.2. Attribute Data Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
L MSA 3rd Edition - Attribute Data - Page 134 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
D MSA for Attribute Data System - We have a gauge called ?Focus? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Finding Sample Size - Data Type is Attribute Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
N Determining Sample Size for Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Do we need to perform Stability, Linearity & Bias study for Attribute data? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
