Attribute Data MSA for more than 3 Operators
jovoga
hello friends,
I am looking for form in xls format for judgement of MSA for attribute data for more than fre 3 operators.
But on the intrenet is forms only for 3 people.
Do you have a form for judgement of MSA atribute for more than 3 people?
Or idea how to do it?
Tha?nks in advance,
Kales Veggie
People: The Vital Few
hello friends,
Tha?nks in advance,
it is not common at all to have more than 3 operators. What additional information are you looking for that 3 operators will not give you? What are you concerned about?
My suggestion would be to do a 3 operator study and repeat it with replacing operators for the 2nd study.
jovoga
M tasks is to know experiences of visual inspection operators. Our production have 8 visual operators per shift = 8*4shifts=32 operators.
I would like make something like a certification of visual inspection operators.
And current forms are only for 3 operators.
Do you have idea how to evalute results of so many operators?
Kales Veggie
MSA studies is about the system, not about certification of the individual operators.
Visual inspection is only 80% effective. If your company relies on visual inspection, your company will not be effective in finding / containing issues.
If you are using to certify inspectors then you should analyze each inspector separately against a set of known 'true' values.
I have attached a spreadsheet that will help you.
the group kappa ta will accompdate as many operators (only assessed against each other) as you want,
the first tab is for a single operator against either themselves or against a standard.
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
B How many Samples are required in Attribute Data MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C MSA on Attribute Data - Can use Different Parts with Different Cosmetic Issues? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
L MSA 3rd Edition - Attribute Data - Page 134 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
D MSA for Attribute Data System - We have a gauge called ?Focus? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J How to do attribute data GR&R (Gage R&R)? Do a Kappa study or follow the MSA book? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
V To formulate an Excel .xls worksheet for MSA on attribute data using Kappa Analysis Excel .xls Spreadsheet Templates and Tools 14
D MSA for Attribute data - Automatic Hy-pot test machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T MSA Manual revision 3 Attribute Data - Signal Detection Formula Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
K Transform variable data into attribute data Reliability Analysis - Predictions, Testing and Standards 24
B Easy Software Needed for Recording Mainly Attribute Data Quality Assurance and Compliance Software Tools and Solutions 2
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
T Attribute vs Variable Inspection Data ISO 13485 Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P RQL/AQL from Attribute Data Six Sigma 1
M Population failure rate based on attribute data Statistical Analysis Tools, Techniques and SPC 4
B Bayes Success-Run on Attribute Data - Determining Sample Size Statistical Analysis Tools, Techniques and SPC 2
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Best Attribute Data Sampling Plan - Early Production Containment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
kedarg6500 Gage R&R for Attribute Data - Pump Noise Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Is Cpk required for all Attribute Data Special Characteristics? IATF 16949 - Automotive Quality Systems Standard 6
optomist1 Sample Size for Attribute Binary Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
C Process Capability - Attribute Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
M PFMEA (Process FMEA) for Attribute Data Inspection Process FMEA and Control Plans 2
V Sample Size for Attribute Data - Large Production Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Hami812 Attribute Data Gage R&R - Managing Data Sets - Minitab Using Minitab Software 2
C Analyzing Attribute Data - Mechanical Pull Testing of Joint Statistical Analysis Tools, Techniques and SPC 15
W Sampling Plan problem - Determining Sample Size for both Attribute and Variables Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
optomist1 Binary & Attribute Data Measures - Electrical Field Failures or Opens Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Attribute Data and Capability Study of Holes in Parts Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Binary logistic regression for attribute/discrete data Using Minitab Software 7
O Capability Studies: Can I combine Attribute Data and Variables Data Capability, Accuracy and Stability - Processes, Machines, etc. 2
G Attribute Data Inspection Sampling Matrix Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T Advice on PPAP Attribute Data Capability - Go/No-Go APQP and PPAP 3
B Visual Inspection (Attribute Data) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
T Sorting Out Attribute Data - What is this data telling me? Statistical Analysis Tools, Techniques and SPC 7
kedarg6500 Process Capability for Attribute Data - Excel .xls spreadsheet wanted Capability, Accuracy and Stability - Processes, Machines, etc. 5
C Attribute Data - What is the required sample size (medical field)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
L Process controls on attribute data - Chrome plating manual buffing line Capability, Accuracy and Stability - Processes, Machines, etc. 10
R Method to compute Cpk for Attribute Data? Capability, Accuracy and Stability - Processes, Machines, etc. 3
A Sampling - Measuring and Inspecting a part with both Variable & Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
B Visual Inspection - Capability Study on Attribute Data Capability, Accuracy and Stability - Processes, Machines, etc. 13
Q Is DPM defective parts per million a form of Attribute Data Sampling? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q ISO/TS 16949 Questions About clause 7.1.2. Attribute Data Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
J Gage R&R on Attribute Data Using Minitab 14 - Data from Automated Test Systems Quality Tools, Improvement and Analysis 2
H Attribute Data Gage R&R - Queries of data from a system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
G Customer is requesting Variable Data for Attribute Gages in Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Excel .xls Template for Attribute Gage R&R with ORDINAL Data needed Excel .xls Spreadsheet Templates and Tools 10
Antonio Vieira Gage R&R Studies for Attribute Data? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
