Attribute Data - What is the required sample size (medical field)?
caveman123
Just curious to see what rationale people typically use to based their sample size on for attribute data? For the company I work for our procedure gets very involved for variable data, but for attribute there seems to be a disconnect (from statistic backing).
Is there a good approach to justify a sample size that is feasible (no 200, 300 pieces inspection) yet satisfies the statistic requirement?
N
Nancy Collins
Re: Attribute Data - What is the required sample size
I am trying to resolve the same questions myself; I would love to see further discussion on this. Many articles recommend the binomial direct calculation or the normal approximation to the binomial without describing the assumptions. Upon investigation, my process(es) do not meet the assumptions. When using AQL as a required performance level to choose the lot tolerance percent defective at which to evaluate, I get sample sizes that are larger than my lot size or close to lot sizes, but the binomial requires the sample to be a) small when compared to lot size and b) to be from a stream of production. Many of the processes under evaluation can be considered streams, but some are not; they are manufactured in the same sized lots and then may not be made again for weeks.
I think, because the desired LTPD or 'reject quality level' is so small, by desire and nature of the product and history (prior to validation of the particular processes that are within many in the manufacture of the product), that the Poisson approximation to the binomial should be used, but the quantities turn out to be very similar to the binomial.
Anybody else resolved these issues? Dodge-Romig tables based upon lot sizes and LTPD?
Thanks very much.
brahmaiah
Re: Attribute Data - What is the required sample size?
The most ideal method to inspect attribute data for a lot quantity of 200-300 nos. is 100% inspection.But if you are keen on sampling you may choose'0' AQL and follow sampling tables.In that case the possibilities of accepting your lot is there only if the process Cpk is >1.33.
If the part is not critical you may choose a higher AQL and go ahead with sampling plans.(But higher AQL is not acceptable in TS16949.)
V.J.Brahmaiah
Stijloor
V.J.Brahmaiah
That's incorrect!
From ISO/TS 16949:
7.1.2 Acceptance criteria
Acceptance criteria shall be defined by the organization and, where required, approved by the customer.
For attribute data sampling, the acceptance level shall be zero defects (see 8.2.3.1).
Emphasis mine.
Stijloor.
N
Nancy Collins
I should add that I am trying to establish sampling and sample sizes for estimating process yield based on attribute data for Process Validations.
caveman123
I am on a similar page. Not so much of attribute data for production lot acceptance, rather how to handle the acceptable sample size for Design Verification.
Sorry that wasn't clear before:)
Marc
That's incorrect!
From ISO/TS 16949: <snip>
Note that no one mentioned TS 16949 until your post, and the thread was originally started in the ISO 13485 forum, so TS 16949 requirements may not be applicable.
If I'm readign the questions correctly and the posters with questions are concerned about sample size for verification adn validation (or IQ, OQ, PQ)
We have had a few of these questions in the forum. and these situations are absolutely not addressable with AQLs, RQLs, mil-stds etc because this is not acceptance sampling.
Unfortunately the answer is more complex than can be handled with a general question. specific situations are much better to tease out the important subtleties...
The one general comment that can be made is that this situation will use sample size calcualtions that one would do for hypothesis and DOE type testing/experiments.
If we can get a few specific questions, We can help with that. Of course if I've missed teh mark and the questions really are related acceptance sampling of completed lots, let us know!
D Is Cpk required for all Attribute Data Special Characteristics? IATF 16949 - Automotive Quality Systems Standard 6
B How many Samples are required in Attribute Data MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
K Transform variable data into attribute data Reliability Analysis - Predictions, Testing and Standards 24
B Easy Software Needed for Recording Mainly Attribute Data Quality Assurance and Compliance Software Tools and Solutions 2
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
T Attribute vs Variable Inspection Data ISO 13485 Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P RQL/AQL from Attribute Data Six Sigma 1
M Population failure rate based on attribute data Statistical Analysis Tools, Techniques and SPC 4
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
B Bayes Success-Run on Attribute Data - Determining Sample Size Statistical Analysis Tools, Techniques and SPC 2
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Best Attribute Data Sampling Plan - Early Production Containment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Attribute Data MSA for more than 3 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
kedarg6500 Gage R&R for Attribute Data - Pump Noise Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
optomist1 Sample Size for Attribute Binary Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
C Process Capability - Attribute Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
M PFMEA (Process FMEA) for Attribute Data Inspection Process FMEA and Control Plans 2
V Sample Size for Attribute Data - Large Production Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C MSA on Attribute Data - Can use Different Parts with Different Cosmetic Issues? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Hami812 Attribute Data Gage R&R - Managing Data Sets - Minitab Using Minitab Software 2
C Analyzing Attribute Data - Mechanical Pull Testing of Joint Statistical Analysis Tools, Techniques and SPC 15
W Sampling Plan problem - Determining Sample Size for both Attribute and Variables Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
optomist1 Binary & Attribute Data Measures - Electrical Field Failures or Opens Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Attribute Data and Capability Study of Holes in Parts Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Binary logistic regression for attribute/discrete data Using Minitab Software 7
O Capability Studies: Can I combine Attribute Data and Variables Data Capability, Accuracy and Stability - Processes, Machines, etc. 2
G Attribute Data Inspection Sampling Matrix Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T Advice on PPAP Attribute Data Capability - Go/No-Go APQP and PPAP 3
B Visual Inspection (Attribute Data) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
T Sorting Out Attribute Data - What is this data telling me? Statistical Analysis Tools, Techniques and SPC 7
kedarg6500 Process Capability for Attribute Data - Excel .xls spreadsheet wanted Capability, Accuracy and Stability - Processes, Machines, etc. 5
L Process controls on attribute data - Chrome plating manual buffing line Capability, Accuracy and Stability - Processes, Machines, etc. 10
R Method to compute Cpk for Attribute Data? Capability, Accuracy and Stability - Processes, Machines, etc. 3
A Sampling - Measuring and Inspecting a part with both Variable & Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
B Visual Inspection - Capability Study on Attribute Data Capability, Accuracy and Stability - Processes, Machines, etc. 13
Q Is DPM defective parts per million a form of Attribute Data Sampling? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q ISO/TS 16949 Questions About clause 7.1.2. Attribute Data Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
J Gage R&R on Attribute Data Using Minitab 14 - Data from Automated Test Systems Quality Tools, Improvement and Analysis 2
H Attribute Data Gage R&R - Queries of data from a system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
G Customer is requesting Variable Data for Attribute Gages in Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
L MSA 3rd Edition - Attribute Data - Page 134 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Excel .xls Template for Attribute Gage R&R with ORDINAL Data needed Excel .xls Spreadsheet Templates and Tools 10
Antonio Vieira Gage R&R Studies for Attribute Data? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D MSA for Attribute Data System - We have a gauge called ?Focus? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Finding Sample Size - Data Type is Attribute Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
N Determining Sample Size for Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Do we need to perform Stability, Linearity & Bias study for Attribute data? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Graphing a Defect Chart in Excel .xls using Attribute Data Excel .xls Spreadsheet Templates and Tools 6
