Attribute , for example C chart
Achim
How can I eliminate the lower control limit in Jump?
sometimes I just want to control defect count and want my lower control limit to be zero.
Achim
Hello Jim,
Jump or Minitab are statistical programs.
You chose a chart type, upload your data and the programs plot your charts. In this case I want to track particles and use a C chart for it.
I am not interested to show any auditor the lower control limit! Iam only interested tracking the upper.
But the programs always shows also the lower control limit.
Therefore, does anyone know how to turn off the function to calculate the LCL in the program JUMP?
Or better, is there any Attribute chart not showing the LCL.
Or what chart types do you use for Particle charts?
Or how do you guys explain out of control points under LCL to auditors, and what actions should that drive, when just simply lower particles are better!
It’s JMP, pronounced jump. JMP actually stands for Just another Mac Program...it is like MINITAB.
I thought JMP automatically set the lower limit to zero if it was negative for ‘attribute’ charts. I’m not at work until Tuesday so I can’t check right now. You can set the lower limit to zero manually.
Out of control low for count charts is good. it means something good happened. That is waht you explain to auditors. If hte auditor leant’ understand this absolutely basic chart concept then they are not very competent.
Achim
Achim
Thank you,
Iam new in JMP, and have version 5.0.1 to play with right now.
I have a ticket in to get the new version.
I did not see the functionality to manually set LCL to zero.
And the data is all positive.
Let me know once you are at work, I would greatly appreciate the help!!
JMP 5 is ancient. You will probably see what you are looking fo when you get the most recent version (I am on 15).
However a second comment is warranted. Particle counts can be quite ‘high’ and there is probably a legitimate lower control limit. If JMP calculates a lower control limit (greater than zero - as it should if the counts are high enough) then you should leave the limit. To set it a zero would be wrong and any knowledgable auditor would question this and your competence/knowledge of SPC.
Again a properly calculated LCL > 0 for counts of things is appropriate and useful.
Achim
Consider the process, if you are looking at an EPI reactor, on every run you are creating more particles.
You are depositing dopant, so it is part of the process.
This particle data may be ‘dependent’ data.
This is why I am looking for a chart just having an upper limit.
Granted with MY SPC knowledge and in Minitab I would do the following:
Prove independence first. I have not found this functionality in JMP.
I believe dependent data should not have any LCL and UCL, therefore again my question, what is the right way to chart with just an upper limit and out of control action plan to react to too much particles.
Any EPI grower out there, what chart are you using?
Second I would transform the data ( if independence is proven) then I am fine with the C chart and lower LCL.
Do you agree Bev?
I also struggle to find the BOX COX transformation in my old JMP version. Maybe you can also point me to Independence and normality assumptions when you are back in front of your version 15.
Are you looking for ‘particles’ or stacking faults?
NEVER EVER transform your data. EVER. Transformations require that you know what the actual distribution is os that you select right transformation formula AND that the data are homogenous. Count data is usually Poisson but not always. and depending on what you are actually counting it is rarely homogenous.
Particles!
But in a process which creates particles, the EPI process, the dopants waste product are creating particles every process run.
So, I more and more think this data is for sure dependent data, my books tell me not to make statistical conclusions from dependent data....
N Example of how to perform a Visual Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Attribute MSA-CrossTab Study Example in MSA Manual:How to compute the Expected Count? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Comparing Two Test Variables Using Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
F Attribute sampling plan ISO 13485:2016 - Medical Device Quality Management Systems 7
D Question: How to analyze numerical and attribute data Reliability Analysis - Predictions, Testing and Standards 11
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 11
A Attribute Analysis for colour matching scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K Transform variable data into attribute data Reliability Analysis - Predictions, Testing and Standards 24
K IATF & Attribute Study requirements IATF 16949 - Automotive Quality Systems Standard 9
O Examples of Critical process parameter (CPP) and Critical quality attribute (CQA) Manufacturing and Related Processes 2
C Applying Weibayes to Attribute sampling Reliability Analysis - Predictions, Testing and Standards 0
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Easy Software Needed for Recording Mainly Attribute Data Quality Assurance and Compliance Software Tools and Solutions 2
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Attribute Gage R&R study according to "Charbonneau" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Can a Attribute Study be considered a Visual Inspection? Reliability Analysis - Predictions, Testing and Standards 6
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
L Gage Blocks: Attribute or Variable Gage? General Measurement Device and Calibration Topics 3
T Attribute vs Variable Inspection Data ISO 13485 Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
R Visual Attribute Inspector Capability and KAPPA Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D attribute gage RR in a unique way Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P RQL/AQL from Attribute Data Six Sigma 1
M Population failure rate based on attribute data Statistical Analysis Tools, Techniques and SPC 4
V Minitab - Attribute Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Attribute G&R for all Visual Controls in Control Plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Attribute Test Method Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Attribute Sampling Plans with Switching Rules - Software Recommendations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
B Bayes Success-Run on Attribute Data - Determining Sample Size Statistical Analysis Tools, Techniques and SPC 2
A Attribute Inspection P Chart Statistical Analysis Tools, Techniques and SPC 9
Chennaiite Do Attribute Control Charts really help? Statistical Analysis Tools, Techniques and SPC 9
S Visual Inspection Galvanized Attribute Study Quality Tools, Improvement and Analysis 2
K MINITAB 16 - Attribute gage study (Analytic method) and Gage R&R Study (Expanded) Using Minitab Software 2
J Minimum number of parts to do an attribute gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
S Cross Tab Attribute Gauge Study form Excel .xls Spreadsheet Templates and Tools 3
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J Attribute MSA - Number of samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Manix MSA - How to Approach a Gauge R&R Go/NoGo Attribute Study Statistical Analysis Tools, Techniques and SPC 2
B Best Attribute Data Sampling Plan - Early Production Containment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
E MSA of Attribute Gauges Signal Detection Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C MSA-4 Attribute Kappa Template - Verification Check Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
