Attribute gage in stamping press as poke yoke
L
lday38
We recently have begun putting an attribute checking gage in our stamping press. If the part is undersize , the part is diverted to the reject chute.
My question is , I am trying to verify that this gage will do what it says it will. They are checking it with a defective part at the start of the shift. I have asked them to define with parameters the piece checked. The dimension is .449 min and .446 max diameter. Tight now, they are saying the tool or gage is doing its job if it catches an undersize part. They are not concerned over an oversize part. Also, we spoke about if there is a need for claibrating this device. The tool is tapered . Has anyone gotten into this type of poke yoke? How do you do a Gage R&R on such a device.
Caster
An Early Cover
Gage vs poka yoke
Is the gage manual? Does the operator have to use that gage to make a decision? If so, this would not be a poka yoke in the usual sense. At best, a very weak poka yoke.
If this is an automatic device that automatically diverts the bad part, it would be a strong poka yoke.
Poka yokes need to be checked with a known bad master part frequently. Looks like that is what you are doing. This master needs to be calibrated/verified.
Do you have the AIAG MSA manual? It completely explains how to do GR&R on such a device. Also search the Cove for attribute gage studies.
Good luck, hope this helps. Please ask for more specific help if needed.
M Practicality of Metal Stamping Attribute GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Attribute Gage R&R study according to "Charbonneau" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Gage Blocks: Attribute or Variable Gage? General Measurement Device and Calibration Topics 3
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
D attribute gage RR in a unique way Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
V Minitab - Attribute Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Example of how to perform a Visual Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K MINITAB 16 - Attribute gage study (Analytic method) and Gage R&R Study (Expanded) Using Minitab Software 2
J Minimum number of parts to do an attribute gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Survey about Attribute Gage and Sight Checking R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
kedarg6500 Gage R&R for Attribute Data - Pump Noise Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA Gage R&R and Attribute Forms Attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Correct Sample Size for Attribute Gage R&R (Good / Bad parts) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
D "GM Method" Gage R&R for Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Destructive Attribute Gage R&R without LSL/USL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Attribute Gage MSA - What is the width of the gray area of ​​doubt? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J GR&R (Gage R&R) Sample Setup for Attribute Inspection Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Hami812 Attribute Data Gage R&R - Managing Data Sets - Minitab Using Minitab Software 2
J Gage R&R Study by Attribute (ACCEPT-REJECT-INVESTIGATE) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Attribute GR&R (Gage R&R) using a CMM (Coordinate Measuring Machine)? General Measurement Device and Calibration Topics 3
L Tools in Gage R&R - Acceptability of an Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
B Visual Inspection (Attribute Data) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
J Attribute GRR (Gage R&R) - How to get Kappa Software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Attribute Gage Studies - What gages are required to have Measurement Systems Analysis IATF 16949 - Automotive Quality Systems Standard 4
M Procedure for Attribute R&R Gage Study?? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Destructive Attribute Gage Studies - inserted/pressed in parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
H Known non-conforming samples in attribute GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Attribute GR&R (Gage R&R) Studies for Metal Stampers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Attribute Gage R&R on Torque Wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Percent defective in Attribute GR&R (Gage R&R) General Measurement Device and Calibration Topics 3
S Attribute Gage R&R - Automated Test Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Attribute Gage R&R analysis - Automated test system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C How to Determine Attribute Gage Uncertainty Measurement Uncertainty (MU) 1
R Attribute GR&R (Gage R&R) for Continuous Processes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Gage R&R on Attribute Data Using Minitab 14 - Data from Automated Test Systems Quality Tools, Improvement and Analysis 2
H Attribute Data Gage R&R - Queries of data from a system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
K Gage R&R on a special go/no-go attribute gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Attribute Gage Study using MiniTab Using Minitab Software 2
T Wind Turbine Blade Attribute Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Customer is requesting Variable Data for Attribute Gages in Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
J Audit Finding for this section - Min and Max for measurements - Attribute Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
M Excel .xls Template for Attribute Gage R&R with ORDINAL Data needed Excel .xls Spreadsheet Templates and Tools 10
T Gage R&R Yearly Frequency Acceptance - Attribute gages - ISO/TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
