Attribute Gage R&R analysis - Automated test system
rigole_f
We have an automated test system that measures pass/fail criteria in a sequential way on electronic board assemblies.
We want to evaluate and validate this new software and test station now, using gauge r&r. As this project is still in the development phase, we're not able to select good or bad parts (as it is unknown yet).
The system also measures to many parameters (pass/fail) to have a range of samples for every measurement taken.
How should we organize the gauge r&r on such a kind of test equipment?
Has anybody some experience on doing gauge r&r on JTAG stations?
justncredible
Re: Attribute gauge r&r analysis
Make 5 to 10 known bad units, then have it sort 50 total parts with 40 known good and see how many it can find. Page 125 of the MSA 3rd ed.
You could swap out the resistors or caps with the wrong ones and see if it finds them. At least that is what I would do. That way when it test the circuit it would return the wrong values. What matters is that the test finds bad units.
But since you do not have testing units yet, maybe you can validate with a bench test. You will not be able to do a GR&R until you have units.
P
Palt88
Up for this topic!
I'm currently close to issue an attribute GRR for an automated pass/fail measurement (will be force and distance).
Did someone has a rational about how many parts we have to assess? as the machine is considered as 1 appraiser and we will do only 1 trial, do we have to take, let's say 60 parts minimum?
P.S: in minitab 16 they are mentioning:
"It is good practice to have a fairly balanced mix of Good and Bad items. Your data shows that you have 50% Good items and 50% Bad items. If you have a small percentage of items of one type, you reduce your ability to assess how well the appraisers rate that type of item."
So I assume in any cases it's better to have close to 50/50 of good/bad pieces
Rand T
What can be really challenging on an attribute R & R is that you need pieces that are barely good and barely bad to determine if your measurement system is adequate enough to discriminate between them. Knowing that your system will fail parts that are out a "mile" doesn't really give you the confidence you need.
In order to select samples are "barely good or barely bad" you probably should not use the attribute gage you are evaluating, but need to use a variable measurement device with good R & R.
For items that require a visual inspection only you may need to use samples with a strong consensus that they are good or bad.
P
Palt88
In my case it is almost impossible to define devices which are barely good or bad.
The machine is testing a pass / fail on a force specifications, which is a result of an assembly of different plastic parts, so no way. Moreover some tests are destructive.
J Attribute Gage Studies - What gages are required to have Measurement Systems Analysis IATF 16949 - Automotive Quality Systems Standard 4
J Attribute Gage R&R MSA (Measurement Systems Analysis) on Pin Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
Y Attribute Gage R&R - MSA 3rd Edition - 'Hypothesis Test Analysis - Cross Tab Method' Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Attribute Gage R&R study according to "Charbonneau" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Gage Blocks: Attribute or Variable Gage? General Measurement Device and Calibration Topics 3
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
D attribute gage RR in a unique way Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
V Minitab - Attribute Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Example of how to perform a Visual Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K MINITAB 16 - Attribute gage study (Analytic method) and Gage R&R Study (Expanded) Using Minitab Software 2
J Minimum number of parts to do an attribute gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Survey about Attribute Gage and Sight Checking R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
kedarg6500 Gage R&R for Attribute Data - Pump Noise Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA Gage R&R and Attribute Forms Attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Correct Sample Size for Attribute Gage R&R (Good / Bad parts) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
D "GM Method" Gage R&R for Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Destructive Attribute Gage R&R without LSL/USL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Practicality of Metal Stamping Attribute GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Attribute Gage MSA - What is the width of the gray area of ​​doubt? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J GR&R (Gage R&R) Sample Setup for Attribute Inspection Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Hami812 Attribute Data Gage R&R - Managing Data Sets - Minitab Using Minitab Software 2
J Gage R&R Study by Attribute (ACCEPT-REJECT-INVESTIGATE) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Attribute GR&R (Gage R&R) using a CMM (Coordinate Measuring Machine)? General Measurement Device and Calibration Topics 3
L Tools in Gage R&R - Acceptability of an Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
B Visual Inspection (Attribute Data) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
J Attribute GRR (Gage R&R) - How to get Kappa Software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Procedure for Attribute R&R Gage Study?? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Destructive Attribute Gage Studies - inserted/pressed in parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
H Known non-conforming samples in attribute GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Attribute GR&R (Gage R&R) Studies for Metal Stampers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Attribute Gage R&R on Torque Wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Percent defective in Attribute GR&R (Gage R&R) General Measurement Device and Calibration Topics 3
S Attribute Gage R&R - Automated Test Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C How to Determine Attribute Gage Uncertainty Measurement Uncertainty (MU) 1
R Attribute GR&R (Gage R&R) for Continuous Processes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Gage R&R on Attribute Data Using Minitab 14 - Data from Automated Test Systems Quality Tools, Improvement and Analysis 2
H Attribute Data Gage R&R - Queries of data from a system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
K Gage R&R on a special go/no-go attribute gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Attribute Gage Study using MiniTab Using Minitab Software 2
T Wind Turbine Blade Attribute Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Customer is requesting Variable Data for Attribute Gages in Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
J Audit Finding for this section - Min and Max for measurements - Attribute Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
M Excel .xls Template for Attribute Gage R&R with ORDINAL Data needed Excel .xls Spreadsheet Templates and Tools 10
T Gage R&R Yearly Frequency Acceptance - Attribute gages - ISO/TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
