Attribute GR&R (Gage R&R) for Continuous Processes
rmf180
I am looking for advice regarding setting up an attribute GR&R study in a continuous process. The actual set up is a vision system (VS) mounted on an injection molding machine. The VS is being validated for its ability to detect a short shot. The VS does not have sufficient resolution to detect defectives by variables data, but by attribute, the VS should work. We are programming the VS with a master (golden part). Anything "smaller" than the golden part will be rejected. We can make shorts by machine adjustment, but how do we indicate the ability of the system to repeat its decision?
Here are my thoughts:
1) Establish acceptance criteria based upon alpha and beta errors. We want 100% of all non-conforming parts rejected, but we can accept 5% of the product to be classified as non-conforming when it is actually conforming.
2) Run the machine and make short shots by machine adjustment. We should keep track of how many "shorts" we have introduced by design.
3) Dimensionally inspect all product (good and bad) using variables data in the lab.
4) Evaluate % agreement between the attribute system compared to the variables system.
5) Compare findings to 100% / 95% criteria.
The variables gage system has been assessed for GR&R and is acceptable at < 20% of tolerance. Because this cannot be replicated, the sample size will be large (N >= 300).
Does anyone see any problems with this approach or perhaps suggest a better method?
Thanks in advance!
Kales Veggie
People: The Vital Few
Looks OK to me.
One addition, once you have established the VS settings for accept/reject, you should run a "rabbit" through the VS regularly to make sure the VS detects "shorts".
VS settings can be easily changed and influenced (ambient lighting, focus, color difference in background, stray lights (day vs. night), vibration, gloss level, etc).
The short shot will always be in certain locations (or one location). Your camera should be looking at that area only. Positioning/orienting your piece is critical.
Running a rabbit should be easy. You should set the frequency based on how much risk you are willing to take.
Let us know your progress.
rmf180
Thanks for your input. We do have a "rabbit" which will be programmed for periodic "reverification". The robot will simply grab the rabbit and present it during the run.
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Attribute Gage R&R study according to "Charbonneau" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Gage Blocks: Attribute or Variable Gage? General Measurement Device and Calibration Topics 3
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
D attribute gage RR in a unique way Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
V Minitab - Attribute Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Example of how to perform a Visual Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K MINITAB 16 - Attribute gage study (Analytic method) and Gage R&R Study (Expanded) Using Minitab Software 2
J Minimum number of parts to do an attribute gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Survey about Attribute Gage and Sight Checking R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
kedarg6500 Gage R&R for Attribute Data - Pump Noise Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G MSA Gage R&R and Attribute Forms Attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Correct Sample Size for Attribute Gage R&R (Good / Bad parts) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
D "GM Method" Gage R&R for Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Destructive Attribute Gage R&R without LSL/USL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Practicality of Metal Stamping Attribute GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M Attribute Gage MSA - What is the width of the gray area of ​​doubt? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J GR&R (Gage R&R) Sample Setup for Attribute Inspection Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Hami812 Attribute Data Gage R&R - Managing Data Sets - Minitab Using Minitab Software 2
J Gage R&R Study by Attribute (ACCEPT-REJECT-INVESTIGATE) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Attribute GR&R (Gage R&R) using a CMM (Coordinate Measuring Machine)? General Measurement Device and Calibration Topics 3
L Tools in Gage R&R - Acceptability of an Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
B Visual Inspection (Attribute Data) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
J Attribute GRR (Gage R&R) - How to get Kappa Software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Attribute Gage Studies - What gages are required to have Measurement Systems Analysis IATF 16949 - Automotive Quality Systems Standard 4
M Procedure for Attribute R&R Gage Study?? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Destructive Attribute Gage Studies - inserted/pressed in parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
H Known non-conforming samples in attribute GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Attribute GR&R (Gage R&R) Studies for Metal Stampers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Attribute Gage R&R on Torque Wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Percent defective in Attribute GR&R (Gage R&R) General Measurement Device and Calibration Topics 3
S Attribute Gage R&R - Automated Test Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R Attribute Gage R&R analysis - Automated test system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C How to Determine Attribute Gage Uncertainty Measurement Uncertainty (MU) 1
J Gage R&R on Attribute Data Using Minitab 14 - Data from Automated Test Systems Quality Tools, Improvement and Analysis 2
H Attribute Data Gage R&R - Queries of data from a system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
K Gage R&R on a special go/no-go attribute gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Attribute Gage Study using MiniTab Using Minitab Software 2
T Wind Turbine Blade Attribute Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Customer is requesting Variable Data for Attribute Gages in Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
J Audit Finding for this section - Min and Max for measurements - Attribute Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
M Excel .xls Template for Attribute Gage R&R with ORDINAL Data needed Excel .xls Spreadsheet Templates and Tools 10
T Gage R&R Yearly Frequency Acceptance - Attribute gages - ISO/TS 16949 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Antonio Vieira Gage R&R Studies for Attribute Data? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
