Attribute Measurement System Questions
chenkozou
I have some questions about Attribute Measurement System.
1. I want to know what is the definition of Attribute Measurement System.
Note: I haven't the English version MSA Manual. I come from China.:)
2. Where does Attribute Measurement System apply?
3. For Attribute GR&R of visual quality inspection, What is the assess criteria?
The %Score vs. Attribute need to >90%? or the Screen % Effective Score vs Attribute>80%?
Any input will be highlighted appreciated. Thanks!:thanx:
Re: Some questions about Attribute Measurement System
There are people here in the US who think the MSA manual is written in Chinese :D. "Attributes" are characteristics for which acceptance criteria are based on simple good/not good, or go/no go decisions, as opposed to variables, for which actual measurement values form the acceptance criteria.
See the answer to #1. One example of an attributes measurement system is use of thread gages to verify screw threads, or threaded holes.
The acceptance criteria will depend on the risk involved, customer requirements, or both. Generally speaking, it's expected that an attributes gage will always differentiate between "good" and "bad" parts. When there are subjective visual criteria, GR&R is not appropriate. In order for GR&R to be useful, the acceptance criteria must be objective.
reynald
OK let's anwer 1 by 1:
1. Attribute Measurement System is also known as Assesement Agreement Analysis. It is a study of whether 2 or more appraisers are given sets of items will agree each other with thier judgment of GO/NO, or PASS/FAIL. Usually appraisers are given 2 or more trials.
2. Mostly during inspection where judgment is by attribute data (go/no go; pass/fail; small/medium/large) and measurement is not used.
3. Depends on the criticality of your product. Ours is 95% sine there is a relability issue involved.
Try to use the Search function for more info or refer this weblink for whole lot of information:
Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
You may check this site for some samples:
http :// cpd .ogi.edu/seminars05/DonLewisSeminar.pdf - OBSOLETE BROKEN 404 LINK(s) UNLINKED
Hope that helps:D
>>rey
chenkozou
http://elsmar.com/Forums/forumdisplay.php?f=91
http://cpd.ogi.edu/seminars05/DonLewisSeminar.pdf
Hope that helps:D
>>rey
I am a new guy to this forum;) .Thanks your help!
BTW, Our company is a PCB manufactory.
I would like to set up the standard procedure for Attribute GR&R in our company.
"3. Depends on the criticality of your product. Ours is 95% sine there is a relability issue involved."
What is the mean of 95%? It is %Appraiser? %Score vs.Attribute? Screen %Effective Score? Screen %Effective Score vs. Attribute?
Msamike
Another question?
If I have a automatic visual inspection, but it does not sent any numerical data, It criticizes as go no go test.
Pass or fail, is Attribute studies the right method to evaluate our measurement system?
Thanks!
chenkozou
I think so. The score also should be 100% for automatic visual inspection machine.
K
kualititaj
I think a more effective mathod to evaluate a vision system is by Machine verification.
If you have an automated inspection system for PCB, you may want to verify the capability of the machine to recognize by putting thru test boards which have actual units that are good, marginal and defectives and see if the equipment is able to detect appropriately. It would be far more effective then using an attribute GR&R. I believe that the attribut GR&R was originally intended to help determine inspection consistency and accuracy between 'human inspectors' who perform a 'gaging' function.
regards
the "Attribute Gage R&R" approach was designed for any 'judgement system' that categorized results as opposed to a system that returns continuous measurement data. This includes human visual inspection and machine vision systems.
If you cannot get continuous data (which would be unusual for a vision system), the attribute approach is appropriate.
see my attachment on "Verification and validation of measurement systems" for helpful approaches for how to do this:
http://elsmar.com/Forums/attachment.php?attachmentid=12094&d=1266255721
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
C Attribute Measurement System Analysis (MSA) Template Document Control Systems, Procedures, Forms and Templates 0
S Sample Size for Attribute MSA (Measurement System Analysis) in 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
automoto Attribute MSA (Measurement System Analysis) - .xls Form attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
V MSA (Measurement System Analysis) Doubt on Analytic Method (Attribute Study) IATF 16949 - Automotive Quality Systems Standard 8
J Attribute Measurement System Analysis Excel spreadsheet Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
R Destructive Attribute MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
B Attribute Measurement System Study on Aesthetic Characteristics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Measurement System Analysis - Attribute GRR - How kappa is calculated Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Attribute Gage Studies - What gages are required to have Measurement Systems Analysis IATF 16949 - Automotive Quality Systems Standard 4
P Attribute or Variable Measurement? Outer Diameter of a Tube Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
W Attribute MSA (Measurement Systems Analysis) for Low Volumes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M Cpk for attribute data? Performing SPC on capacitors - Capacitance measurement Statistical Analysis Tools, Techniques and SPC 9
Y Attribute Measurement Systems Study---Risk Analysis Methods & Analytic Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Attribute Gage R&R MSA (Measurement Systems Analysis) on Pin Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
A Attribute Analysis for colour matching scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K Transform variable data into attribute data Reliability Analysis - Predictions, Testing and Standards 24
K IATF & Attribute Study requirements IATF 16949 - Automotive Quality Systems Standard 9
O Examples of Critical process parameter (CPP) and Critical quality attribute (CQA) Manufacturing and Related Processes 2
C Applying Weibayes to Attribute sampling Reliability Analysis - Predictions, Testing and Standards 0
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Easy Software Needed for Recording Mainly Attribute Data Quality Assurance and Compliance Software Tools and Solutions 2
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Attribute Gage R&R study according to "Charbonneau" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Can a Attribute Study be considered a Visual Inspection? Reliability Analysis - Predictions, Testing and Standards 6
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
L Gage Blocks: Attribute or Variable Gage? General Measurement Device and Calibration Topics 3
T Attribute vs Variable Inspection Data ISO 13485 Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
R Visual Attribute Inspector Capability and KAPPA Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D attribute gage RR in a unique way Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P RQL/AQL from Attribute Data Six Sigma 1
M Population failure rate based on attribute data Statistical Analysis Tools, Techniques and SPC 4
V Minitab - Attribute Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Attribute G&R for all Visual Controls in Control Plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Attribute Test Method Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Attribute Sampling Plans with Switching Rules - Software Recommendations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Bayes Success-Run on Attribute Data - Determining Sample Size Statistical Analysis Tools, Techniques and SPC 2
A Attribute Inspection P Chart Statistical Analysis Tools, Techniques and SPC 9
Chennaiite Do Attribute Control Charts really help? Statistical Analysis Tools, Techniques and SPC 9
S Visual Inspection Galvanized Attribute Study Quality Tools, Improvement and Analysis 2
N Example of how to perform a Visual Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K MINITAB 16 - Attribute gage study (Analytic method) and Gage R&R Study (Expanded) Using Minitab Software 2
