Attribute MSA-AIAG 4th How to calculate sample size
tada22689
Hello guys,
For Attribute GRR according to AIAG 4th edition, they mention the sample size determination as follows (pages 140, 141):
// Sample Size:
The question always arises: “How many samples should be used in the study?” To the dismay of most people, the answer is “enough”. The purpose
of any measurement study (variables or attribute) is to understand the properties of the measurement system.. A sufficient number of samples should be selected to cover the expected operating range (see also Chapter II Section C). With attribute measurement systems, the area of interest are the Type II areas (see Chapter I, Section B). If the inherent process capability is good (i.e., large Cp, Cpk or Pp, Ppk) then a small random sample may not have many (or any) samples in this area. This means that as the process capability improves , the required random sample for the attribute study should become larger).
In the example above, the indices were Pp, Ppk = 0.5 (i.e. an expected process performance of approximately 13% nonconformance), the sample selected was 50.
An alternate approach to large samples is a “salted sample” where parts are selected specifically from the Type II areas to augment a random sample to ensure that the effect of appraiser variability is seen.
Can anyone explain the way they calculate 50 samples from ppk =0.5?
And in the alternate approach, what is "salted sample", how they select sample size with this?
Thank you guys in advance for your great help.
Sorry for the late response. I thought @Miner would respond as he is an expert in the AIAG manuals. I am not, having burned them in a Wiccan ceremony upon leaving the automotive industry A few decades ago.
I really don’t know how they calculated a sample size of 50, my guess is that they used the formula for estimating a %defective of a process using a random sample with a target defect rate of 13%. Although I have no idea how they got a defect rate of 13% from a Ppk of 0.5
What I do for standard attribute inspection is to use a 2 phase - or more - approach. First I create a sample set of parts that are clearly good and bad and parts that are marginally good and bad to test teh ability of the inspector to make correct calls. If they are struggle with the marginal parts I will investigate why and try to improve the inspection conditions. (Lighting, time to view, training on what to look for, sample prep if involved, etc.) This sample size is usually fairly moderate for attribute samples as it is important to increase the number of clearly good units and marginal units such that the inspector isn’t always looking for bad units. As teh standard says this is really about usign ‘enough’. There is no real sample size calculation here. And I don’t use random samples - which is probably what the sample size of 50 is about. (Randomly collect 50 units hoping that you wil get a decent collection of good, marginal, and bad samples. I refer to not leave this to chance). Once I am confident that the inspectors have good conditions, I may create another sample set that is much larger and contains roughly the same number of good, marginal and bad units as normal production. I will have the inspectors inspect this sample set twice (3 times is overkill) under normal speed and conditions and then assess the results. If the defect is new this all might happen concurrent with startup of the inspection. I also assess the number of false rejections and passes against the severity of the defect and what I am able to tolerate.
I almost forgot the ‘chicken and egg’ dilemma: how do you know what the process capability is if you don’t know how much error is in your inspection? MSA is intended to be an iterative engineering task, not a statistical mathematics exercise…
@Bev D Funny, as I was waiting for you to respond as you are more of an expert in the Attribute MSAs.
The answer lies in the Concerns section, item 1), of page 141, which states "There are no theory-based decision criteria on acceptable risk. The above guidelines are heuristic and developed on individual "beliefs" about what will pass as "acceptable". This is a subject matter decision - not a statistical one. (Emphasis mine)
Heuristic, or heuristic technique, is any approach to problem solving or self-discovery that employs a practical method that is not guaranteed to be optimal, perfect, or rational, but is nevertheless sufficient for reaching an immediate, short-term goal or approximation (Wikipedia).
In other words, AIAG cannot justify the sample size statistically, but believes that it is sufficient for this purpose.
If only I could like this a thousand times!
MValdes
Thank you Miner and Bev, saying this and if the nonacceptable part is detected as bad part for the go no go gage, the sample size for the MSA can be smaller?
If you've already done the study and found that there is 100% agreement between the operators, why would you need to change the sample size after the fact?
Since you are not the OP and you apparently have a very different situation, you will need to elaborate on what you are doing before we can provide a reasonable answer…
C AIAG Attribute MSA - Analytical Method - Page 135 of MSA manual 3rd edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
T TS 16949 - AIAG's MSA Manual - Thread Inspection Gage - Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J AIAG's MSA Manual 3rd Edition Attribute Gage Study - Calculating the UCI and LCI Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
V AIAG's MSA III Edition - Forms and Formulas - Attribute Gage R&R Document Control Systems, Procedures, Forms and Templates 3
M Attribute Gage R&R Form - Long Version - AIAG's MSA Manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 35
Q Attribute MSA with limited test samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 11
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Attribute MSA - Number of samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Manix MSA - How to Approach a Gauge R&R Go/NoGo Attribute Study Statistical Analysis Tools, Techniques and SPC 2
E MSA of Attribute Gauges Signal Detection Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C MSA-4 Attribute Kappa Template - Verification Check Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
D Requiring a "bad" part for attribute MSA studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Attribute Agreement Analysis - MSA - False Negative/Positive IATF 16949 - Automotive Quality Systems Standard 3
N How to make a MSA for an Attribute Gauge if the Pp=Ppk=1.33 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Attribute Data MSA for more than 3 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J MSA for Attribute Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G MSA Gage R&R and Attribute Forms Attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Designing an attribute MSA for a new piece of metrology equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
C Attribute Measurement System Analysis (MSA) Template Document Control Systems, Procedures, Forms and Templates 0
J The appropriate Attribute MSA for Automatic Visual Inspection Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Attribute Gage MSA - What is the width of the gray area of ​​doubt? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Attribute MSA Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B How many Samples are required in Attribute Data MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C MSA on Attribute Data - Can use Different Parts with Different Cosmetic Issues? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Cross Tabulation in Attribute MSA - Help Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Rameshwar25 Acceptance Criteria for Attribute MSA Study Effectiveness Summary Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
S What is the Reference Value when we do Attribute MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
S Sample Size for Attribute MSA (Measurement System Analysis) in 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Attribute MSA for Visual Inspection via Camera Automatic Inspection Tool Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
automoto Attribute MSA (Measurement System Analysis) - .xls Form attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
V Questions on Variable and Attribute MSA Interpretation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O How many bad parts needed for Attribute MSA? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Attribute MSA of Automatic Inspection Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
V MSA (Measurement System Analysis) Doubt on Analytic Method (Attribute Study) IATF 16949 - Automotive Quality Systems Standard 8
I Attribute MSA for 3 factors Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Destructive Attribute MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
P MSA Attribute Studies - Calculate Cross Tabs, Effectiveness, Miss Rate, False Alarm Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
W Attribute MSA (Measurement Systems Analysis) for Low Volumes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
S Separate attribute MSA study required for each Go/No Go gauge? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Attribute MSA Study using Kappa - Why Kappa value is low Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
L MSA 3rd Edition - Attribute Data - Page 134 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
