Attribute MSA (Measurement System Analysis) - .xls Form attached
Ratchetman
#11
First you need to fill "status of inspection" in header. Enter your criteria (OK/NOT OK, GO/NOT GO...). Then you will be able to chose from the list what you will eneter under "status of inspection" in the colums standard, try 1,....
Thanks!!!:bigwave:
That definetly worked, now I'm off and gaging away:cool:
Baheran
#13
What is the different or changes that occurred after updated to 4th Edition? Comparison of appraiser?
:confused:
I
Ingo1966
#14
AUTOMOTO File looks very good.
I prepared the Cross Tab Calculation acc. AIAG 4th see attached Excel File.
But I do not see a different approach compared to AIAG 3th.
K
kcinala
#18
This form is good. However, I would like to ask if anyone has and is willing to share a Template that includes Three Operators, Performing Three checks each equalling 9 instead of 6.
Any assistance will be greatly appreciated.
I
Ingo1966
#19
you can perform an attribute MSA with 3 Operators and 9 Parts with 3 repeated assesments but this will not give you any confidence in the Assesment Process.
You need "enough" Parts --> Clear BAD, somewhat BAD, somewhat GOOD, Clear GOOD to see that you have enough Assesments to get an Idea how good your Attributive Assesment Process works:
- repeated aggreement within the Operators and the Reference
- repeated aggreement Operator with his own assesment
- repeated aggreement Operator with the other Operator
Attached File can be used for 9 Parts 3 Operators 3 Repeated Assesments.
B U T check the Confidence --> it gives you no valuable Prediction or assesment to the Aggreement Test.
#20
Ingo1966 is absolutely correct. It is the number of parts used that provides a godd assessment, not the number of operators and certainly not the number of times an operator performs the assessment; Twice is sufficient, three times is a waste.
for further reference you can check out this document I posted on Measurement System Validation and the attached companion spreadsheet on MSA calculations. It includes a very flexible tab for Kappa testing: multiple operators, multiple categories, etc.
EDIT ADD: Bev has posted a lot of forms and documents here. You can find them all here: Bev's Attachments
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
C Attribute Measurement System Analysis (MSA) Template Document Control Systems, Procedures, Forms and Templates 0
S Sample Size for Attribute MSA (Measurement System Analysis) in 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
V MSA (Measurement System Analysis) Doubt on Analytic Method (Attribute Study) IATF 16949 - Automotive Quality Systems Standard 8
R Destructive Attribute MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
W Attribute MSA (Measurement Systems Analysis) for Low Volumes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J Attribute Gage R&R MSA (Measurement Systems Analysis) on Pin Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Attribute MSA - Number of samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Manix MSA - How to Approach a Gauge R&R Go/NoGo Attribute Study Statistical Analysis Tools, Techniques and SPC 2
E MSA of Attribute Gauges Signal Detection Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C MSA-4 Attribute Kappa Template - Verification Check Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
D Requiring a "bad" part for attribute MSA studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Attribute Agreement Analysis - MSA - False Negative/Positive IATF 16949 - Automotive Quality Systems Standard 3
N How to make a MSA for an Attribute Gauge if the Pp=Ppk=1.33 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Attribute Data MSA for more than 3 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J MSA for Attribute Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G MSA Gage R&R and Attribute Forms Attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Designing an attribute MSA for a new piece of metrology equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J The appropriate Attribute MSA for Automatic Visual Inspection Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Attribute Gage MSA - What is the width of the gray area of ​​doubt? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Attribute MSA Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B How many Samples are required in Attribute Data MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C MSA on Attribute Data - Can use Different Parts with Different Cosmetic Issues? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Cross Tabulation in Attribute MSA - Help Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Rameshwar25 Acceptance Criteria for Attribute MSA Study Effectiveness Summary Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
S What is the Reference Value when we do Attribute MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
B Attribute MSA for Visual Inspection via Camera Automatic Inspection Tool Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
V Questions on Variable and Attribute MSA Interpretation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O How many bad parts needed for Attribute MSA? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Attribute MSA of Automatic Inspection Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
I Attribute MSA for 3 factors Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA Attribute Studies - Calculate Cross Tabs, Effectiveness, Miss Rate, False Alarm Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Separate attribute MSA study required for each Go/No Go gauge? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C AIAG Attribute MSA - Analytical Method - Page 135 of MSA manual 3rd edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
C Attribute MSA Study using Kappa - Why Kappa value is low Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
L MSA 3rd Edition - Attribute Data - Page 134 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
D MSA for Attribute Data System - We have a gauge called ?Focus? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A MSA - Is an attribute study required for visual inspection? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Attribute MSA Study Requirements? Marginally good & marginally bad with good & bad Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J How to do attribute data GR&R (Gage R&R)? Do a Kappa study or follow the MSA book? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Attribute MSA calculation - Trying to find a form or software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
