Attribute MSA (Measurement System Analysis) - .xls Form attached
#24
I saw your MSA Cappa cros tab Template, do you have a similar for 2 appraisers 2 trials?
If you check out my MSA spreadsheet attached in my post above you'll find a tab that allows any number of operators, factors and trials
#25
Mr happy - you got a 100% agreement for both appraiser but there was only one failed unit. you haven't really challenged the system...if you read the document linked in my post above it will give you some ideas about how to better structure your test.
Mr.Happy
#26
Hi Bev,
MSA study is from one of our sub-suppliers and parts are to expensive for on-purpose fails, thats why I asked if it was possible to put the data in Ingo's cross tab sheet and so give me some more information.
#27
sorry further analysis of your data will not yield any more insight. the information received from any experiment is only as good as the structure. Your structure is simply too sparse
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
C Attribute Measurement System Analysis (MSA) Template Document Control Systems, Procedures, Forms and Templates 0
S Sample Size for Attribute MSA (Measurement System Analysis) in 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
V MSA (Measurement System Analysis) Doubt on Analytic Method (Attribute Study) IATF 16949 - Automotive Quality Systems Standard 8
R Destructive Attribute MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
W Attribute MSA (Measurement Systems Analysis) for Low Volumes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J Attribute Gage R&R MSA (Measurement Systems Analysis) on Pin Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Attribute MSA - Number of samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Manix MSA - How to Approach a Gauge R&R Go/NoGo Attribute Study Statistical Analysis Tools, Techniques and SPC 2
E MSA of Attribute Gauges Signal Detection Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C MSA-4 Attribute Kappa Template - Verification Check Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
D Requiring a "bad" part for attribute MSA studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Attribute Agreement Analysis - MSA - False Negative/Positive IATF 16949 - Automotive Quality Systems Standard 3
N How to make a MSA for an Attribute Gauge if the Pp=Ppk=1.33 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Attribute Data MSA for more than 3 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J MSA for Attribute Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G MSA Gage R&R and Attribute Forms Attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Designing an attribute MSA for a new piece of metrology equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J The appropriate Attribute MSA for Automatic Visual Inspection Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Attribute Gage MSA - What is the width of the gray area of ​​doubt? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Attribute MSA Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B How many Samples are required in Attribute Data MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C MSA on Attribute Data - Can use Different Parts with Different Cosmetic Issues? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Cross Tabulation in Attribute MSA - Help Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Rameshwar25 Acceptance Criteria for Attribute MSA Study Effectiveness Summary Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
S What is the Reference Value when we do Attribute MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
B Attribute MSA for Visual Inspection via Camera Automatic Inspection Tool Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
V Questions on Variable and Attribute MSA Interpretation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O How many bad parts needed for Attribute MSA? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Attribute MSA of Automatic Inspection Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
I Attribute MSA for 3 factors Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P MSA Attribute Studies - Calculate Cross Tabs, Effectiveness, Miss Rate, False Alarm Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
S Separate attribute MSA study required for each Go/No Go gauge? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C AIAG Attribute MSA - Analytical Method - Page 135 of MSA manual 3rd edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
C Attribute MSA Study using Kappa - Why Kappa value is low Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
L MSA 3rd Edition - Attribute Data - Page 134 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
D MSA for Attribute Data System - We have a gauge called ?Focus? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A MSA - Is an attribute study required for visual inspection? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Attribute MSA Study Requirements? Marginally good & marginally bad with good & bad Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J How to do attribute data GR&R (Gage R&R)? Do a Kappa study or follow the MSA book? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Attribute MSA calculation - Trying to find a form or software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
