Attribute MSA Study Requirements? Marginally good & marginally bad with good & bad
ozziegood
Registered Visitor
Hello All-
I am wondering what exactly is required for a MSA study for attribute data? We are using a Go/NoGo gage and for the PPAP I need to perform a MSA study. I have read the manual but it is still a bit fuzzy to me. Thanks in advance!
ozziegood said:
Hello All-
If you could be more specific as to what's confusing you, we can try to help.
Helmut Jilling
Auditor / Consultant
ozziegood said:
Hello All-
A common format is 3 x 3 x 10. Three test people taking 3 readings each of 10 parts. I have also seen 10 x 2 x 2.
That's for a variables study, Helmut (a standard GR&R study). The OP is (I assume) referring to Section 3 of the AIAG MSA manual for attributes studies.
Helmut Jilling
You're right. ...Maybe I shouldn't reply late at night...
cyberjyothi
Re: Attribute MSA Study Requirements?
Hello folks,
During our surveillance audit, we face one question from the auditor on how do you perform the attribute study using good,bad,marginally good and marginally bad samples.
can any one help me on how to do attribute study with marginally good & marginally bad along with good& bad.
from my process we are not finding any marginally good/bad samples.The auditor ask us to forcefully make the above samples and perform the study.
I look forward to get the relevent details from u and suggest me how to proceed further.
:thanx:
With regards,
Jyothiswar.M
cyberjyothi said:
Hello folks,
:thanx:
With regards,
Jyothiswar.M
The important thing about an attributes study is that you demonstrate that the gage (or system) is capable of detecting "bad" parts without also rejecting "good" ones. This means, as your auditor has pointed out, that you need parts near the limits. Is there some reason you can't produce some marginal parts for the study? Sometimes there is good reason, in which case you need to demonstrate that for the purposes of verifying the system, "bad" or marginal parts aren't necessary. You might do this by showing a statistical analysis that demonstrates that the process is well-centered, in control, and producing parts near the limit is highly unlikely. Nevertheless, it seems that if you're using an attributes gage, you are concerned about marginal parts, so you'll need to demonstrate the efficacy of the system, or use variables measurement.
H
HRinAZ
You need to perform what is called “Attribute agreement analysis” study. Here are some basic guidelines for conducting an attribute study:
1) Select 10 parts or samples for inspection. These samples should include some clearly good, some clearly bad, and some borderline. Overall, I would try to end up with 5-6 good and 4-5 bad.
2) Have 2 appraisers inspect the samples in random order. They should each do this twice. This will allow you to assess how often they agree with each other (reproducibility) and how consistent they are in their own assessments (repeatability).
3) Compare these results to the standard. This part can be tricky. When you put the study together, you should have a team or expert do this evaluation. I say it is tricky because many times, the standards are just being developed or haven't been developed at all. To perform this study correctly the standard should have been established first, prior to beginning this study!
4) Plug the data into Excel or Minitab (preferred) for the analysis. The reproducibility and repeatability of the test method will be evaluated by calculating:
• Percent of the time an appraiser agreed with own results over two trials
• Percent of time an appraiser agreed with other appraiser’s results over two trials
• Percent of time an appraiser agreed with standard over two trials
• Percent of time an appraiser’s agreed with each other and with standard,
Upon test completion, the following statistical calculations should be performed.
% Agree self = (Total number of times trial 1 results are equal to trial 2 results)/10 *100
% Agree others = (Total number of times trial 1 results are equal to trial 2 results for appraiser 1 and are equal to appraiser 2 results over both trials)/10 * 100
% Agree Standard = (Total number of times trial 1 results are equal to trial 2 results and equal to standard for each appraiser) / 10 *100
Percent of time an appraiser’s agreed with each other and standard over two trials
% Agree standard/others = (Total number of times appraiser 1 agreed with appraiser 2 over both trials and agreed with standard) /10 * 100
So in a nutshell the acceptance criteria we use are:
Output Acceptance Criteria
% Agree Self ≥ 90%
% Agree Others ≥ 81%
% Agree Standard ≥ 90%
% Agree Standard/Others ≥ 73%
You are looking for an overall assessment agreement of 90% or more to accept your measurement system. This means that 90% of the time your appraisers need to agree with themselves, each other and the standard. Deficiencies should be addressed with training and development of standards (basic rules, visuals, etc).
jager
Re: Attribute MSA Study Requirements? Marginally good & marginally bad with good & ba
Would this be for the Attribute Gage Study? How about for the attribute study showing we have good parts? I remember one company asking for 300 pieces to be passed through a gage as a flatness attribute study. Their variable dimensions required a Cpk of 1.67 as usual. I was wondering if there is a form where you just check "Pass" 300 times, and "Fail" hopefully zero times. Is there a form like that?
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
Manix MSA - How to Approach a Gauge R&R Go/NoGo Attribute Study Statistical Analysis Tools, Techniques and SPC 2
Rameshwar25 Acceptance Criteria for Attribute MSA Study Effectiveness Summary Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
V MSA (Measurement System Analysis) Doubt on Analytic Method (Attribute Study) IATF 16949 - Automotive Quality Systems Standard 8
S Separate attribute MSA study required for each Go/No Go gauge? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Attribute MSA Study using Kappa - Why Kappa value is low Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
A MSA - Is an attribute study required for visual inspection? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J How to do attribute data GR&R (Gage R&R)? Do a Kappa study or follow the MSA book? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A GR&R (Gage R&R) - MSA - Section 6 Attribute Gage Study - Short Method Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Attribute MSA-CrossTab Study Example in MSA Manual:How to compute the Expected Count? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J AIAG's MSA Manual 3rd Edition Attribute Gage Study - Calculating the UCI and LCI Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Attribute MSA - Number of samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
E MSA of Attribute Gauges Signal Detection Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C MSA-4 Attribute Kappa Template - Verification Check Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
D Requiring a "bad" part for attribute MSA studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Attribute Agreement Analysis - MSA - False Negative/Positive IATF 16949 - Automotive Quality Systems Standard 3
N How to make a MSA for an Attribute Gauge if the Pp=Ppk=1.33 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Attribute Data MSA for more than 3 Operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J MSA for Attribute Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G MSA Gage R&R and Attribute Forms Attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Designing an attribute MSA for a new piece of metrology equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
C Attribute Measurement System Analysis (MSA) Template Document Control Systems, Procedures, Forms and Templates 0
J The appropriate Attribute MSA for Automatic Visual Inspection Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Attribute Gage MSA - What is the width of the gray area of ​​doubt? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Attribute MSA Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B How many Samples are required in Attribute Data MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C MSA on Attribute Data - Can use Different Parts with Different Cosmetic Issues? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Cross Tabulation in Attribute MSA - Help Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S What is the Reference Value when we do Attribute MSA Studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
S Sample Size for Attribute MSA (Measurement System Analysis) in 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Choosing Parts for Attribute MSA (Measurement System Analysis) in 4th Edition, pg 132 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Attribute MSA for Visual Inspection via Camera Automatic Inspection Tool Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
automoto Attribute MSA (Measurement System Analysis) - .xls Form attached Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
V Questions on Variable and Attribute MSA Interpretation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O How many bad parts needed for Attribute MSA? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B Attribute MSA of Automatic Inspection Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
I Attribute MSA for 3 factors Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Destructive Attribute MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
P MSA Attribute Studies - Calculate Cross Tabs, Effectiveness, Miss Rate, False Alarm Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
W Attribute MSA (Measurement Systems Analysis) for Low Volumes Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
C AIAG Attribute MSA - Analytical Method - Page 135 of MSA manual 3rd edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
L MSA 3rd Edition - Attribute Data - Page 134 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA Attribute gage repeatability and reproducibility IATF 16949 - Automotive Quality Systems Standard 1
