Attribute Sampling Plan help wanted
dipeshjayswal
Greetings All-
We have following situation for acceptance sampling and we use standard for sample size.
An order of 1000 units came in one container containing 10 sub-containers, 100 each. Now required sample size is "n" per the standard, how should we select the sample and what is it call?
Currently we select equal (similar) # of units from EACH sub-container, but our auditor says it is not random. What term should we use if we want to continue with the same practice.
Thanks in advance!
DJ
Re: Attribute Sampling Plan
You should understand that if you're using a standard sampling plan, it's based on the assumption that the sampling will be random, meaning that each member of the 1000-piece population has an equal chance of being chosen.
That's not always practical, so if you need to call your sample something other than "random," just call it a sample.
dipeshjayswal
Thanks Jim,
What is the acceptable method if we want to have random sample?
Can we use stage wise random sampling?.
That is, selecting sub-container (s) at random (first stage random sample). And then selecting sample from that sub-container.
Is there any standard plan which allows stage wise random sampling?
Please help.
DJ
Tim Folkerts
There is a term known as "stratified sampling" -- http://en.wikipedia.org/wiki/Stratified_sampling
Basically, you divide the population into groups (strata) and then sample from each group in proportion to its relative size. In this case, each stratum would be a sub-container.
So you could tell your auditor you are doing a "random sample stratified by sub-containers." That should impress (or confuse!) the auditor enough to be acceptable.
With your example, you have 1000 parts. Suppose that AQL = 2.5 and you are using Normal, Level 2 inspection. The table says to sample 80, or 8 from each sub-container for a stratified sample. You would reject with 6 bad parts total.
I don't know of any standard plan that lets you sample from only some containers. One though I had before is to first follow a standard plan for sampling sub-containers.
With your example, you have 10 sub-containers with 100 parts each. Suppose again that AQL = 2.5 and you are using Normal, Level 2 inspection.
  • For a sample of 10 sub-containers, the tables say to inspect 5 sub-containers.
  • For each sub-container of 100, the tables say to sample 20 parts. 2 bad parts in any sub-container would reject the sub-container. And one rejected sub-container is enough to reject the whole lot.
U
Umang Vidyarthi
Thanks Jim,
Please help.
DJ
Yes you can. This is known as 'Stratified Sampling'. Here you take the sample from each sub-population. You have to judiciously plan the 'strata' or 'sub-group' within the population.
Umang :D
oops! Tim has beaten me on this.
dipeshjayswal
Thanks Tim and Umang,
I thought of using the term "Stratified Random Sampling", but we do not have any considerable or distinguishable property which can make each sub-container as strata. If I am not wrong, in stratified sampling we anticipate at least one property which changes from strata to strata. That means, homogeneity within strata and heterogeneity between strata.
Here, in my example variability between and within sub-containers are supposed to be the same.
I am thinking of writing following statement in my sampling procedure:
"If a final container is a collection of sub-container of products then a random sample of most appropriate size (depending upon the total n required and # of sub-containers) from each sub-container will be selected to have required total sample size n per standard sampling plan"
Please suggest better wording if you feel above statement is not clear or misleading.
You people are awesome!
Thank you again!
DJ
U
Umang Vidyarthi
Thank you again!
DJ
You got the bull by the horns! Go ahead and best of luck.
Umang :D
H
Hodgepodge
How does the auditor define "random"? If there is no definition of "random" provided by your customer, then your company gets to define the process for the purposes of product verification within your company. Without knowing all the details, it is likely that the top sub-container holds a random sampling of the lot. Considering the random possibilities of handling during manufacturing, cleaning, inspection, & packaging, each container is not likely to represent the product in order of manufacturing (not counting assembly line production, of course). I would not adopt this approach, but theoretically, it is possible.
Instead of making up some random definition of "random", a quick look at the government's procurement methods can help you set up something quickly.
For instance, MIL-STD-1916, DOD Test Method Standard, DOD Preferred Methods For Acceptance of Product, Section 4.2.4 Sampling of lots or batches (my emphasis in bold):
"4.2.4.1 Selection of units.
Units of product drawn from a lot for a sample shall be selected at random from the lot without regard to their quality. Random sampling requires that each unit in the lot, batch, or production interval has the same probability of being selected for the sample.
4.2.4.2 Representative (stratified) sampling.
When appropriate, the number of units in the sample shall be selected in proportion to the size of sublots or subbatches, or parts of the lot or batch, identified by some rational criterion. When representative sampling is used, the units from each sublot, subbatch, or part shall be selected at random.
4.2.4.3 Process of sampling.
A sample may be drawn after all units comprising the lot or batch have been assembled, or sample units may be drawn during assembly of the lot or batch, in which case the size of the lot or batch shall be determined befored samples are drawn. When the lot or batch passes the sampling plan, such lots or batches are acceptable and may be submitted to the Government."
This is such a ticky-tack finding! What would seem more important to me is how you determine the appropriate sampling size.
MIL-Standards are free @ http://assist.daps.dla.mil/quicksearch/.​
dipeshjayswal
Thanks a lot Hedgepodge,
The way we do sampling (Please see my initial post for reference) does not fit in any of these definition of Random Sampling and Stratified Sampling.
When we select units from particular sub-container, the probability of selection is zero for all other units which are not in that sub-container. Therefore, it is a violation of the assumption of random sampling.
Here, we do not have any rational criteria to differentiate sub-containers. Therefore, we can not use the word "stratified or representive sampling" for this technique.
I though of using word "Pseudo Random Sampling", but quality people argued that this can not be used in "Quality" as it sounds like "fake random sampling". As I know in statistics, people use word "Pseudo" for kind-of situation like "Pseudo Randomization" which is not pure randomization but generated trough computer using seed number.
Finally, i end up with writing following statement for the sampling we do:
Would you guys please reword if above statement is misleading or not clear?
Thank you very much in advance
DJ
I agree with Jim. I believe your auditor doesn't really understand. Just say you sample. On the premise that you are buying parts which are supposed to be almost identical, then you can pull examples from just about anywhere.
The fact is that sampling plans are not really suitable for receiving parts from a supplier unless you - and the supplier - have done all the requisite studies. Therefore - and I'm using my experience of doing similar over 4 years of running Receiving Inspection, just pull your sample from wherever you want and don't call it 'random'. Also, ask for an auditor who doesn't make such comments!
B Best Attribute Data Sampling Plan - Early Production Containment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Sampling Plan problem - Determining Sample Size for both Attribute and Variables Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Applying Weibayes to Attribute sampling Reliability Analysis - Predictions, Testing and Standards 0
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
A Attribute Sampling Plans with Switching Rules - Software Recommendations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A AQL Tables or Binomial/Poisson Method? Attribute Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
G Attribute Data Inspection Sampling Matrix Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Sampling - Measuring and Inspecting a part with both Variable & Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
Q Is DPM defective parts per million a form of Attribute Data Sampling? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q ISO/TS 16949 Questions About clause 7.1.2. Attribute Data Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
U Zero Acceptance number procedure for Attribute Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S SPC - Go/No Go Sampling - Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Acceptance Criteria for Attribute Data Sampling Plans shall be Zero Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
A Attribute Analysis for colour matching scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K Transform variable data into attribute data Reliability Analysis - Predictions, Testing and Standards 24
K IATF & Attribute Study requirements IATF 16949 - Automotive Quality Systems Standard 9
O Examples of Critical process parameter (CPP) and Critical quality attribute (CQA) Manufacturing and Related Processes 2
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Easy Software Needed for Recording Mainly Attribute Data Quality Assurance and Compliance Software Tools and Solutions 2
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Attribute Gage R&R study according to "Charbonneau" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Can a Attribute Study be considered a Visual Inspection? Reliability Analysis - Predictions, Testing and Standards 6
J MSA on Part Specific Attribute Fixtures Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
L Gage Blocks: Attribute or Variable Gage? General Measurement Device and Calibration Topics 3
T Attribute vs Variable Inspection Data ISO 13485 Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
R Visual Attribute Inspector Capability and KAPPA Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D attribute gage RR in a unique way Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P RQL/AQL from Attribute Data Six Sigma 1
M Population failure rate based on attribute data Statistical Analysis Tools, Techniques and SPC 4
V Minitab - Attribute Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Attribute G&R for all Visual Controls in Control Plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Attribute Test Method Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
B Bayes Success-Run on Attribute Data - Determining Sample Size Statistical Analysis Tools, Techniques and SPC 2
A Attribute Inspection P Chart Statistical Analysis Tools, Techniques and SPC 9
Chennaiite Do Attribute Control Charts really help? Statistical Analysis Tools, Techniques and SPC 9
S Visual Inspection Galvanized Attribute Study Quality Tools, Improvement and Analysis 2
N Example of how to perform a Visual Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
K MINITAB 16 - Attribute gage study (Analytic method) and Gage R&R Study (Expanded) Using Minitab Software 2
J Minimum number of parts to do an attribute gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
D Reliability of an Attribute Inspection based on Historical Data Capability, Accuracy and Stability - Processes, Machines, etc. 8
S Cross Tab Attribute Gauge Study form Excel .xls Spreadsheet Templates and Tools 3
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
