Audit and Calibration question - does verification alone meet the requirements?
stevew
We verify weight scales each shift. The auditor representing the customer found that to be inadequate and the scales should be calibrated. We maintain verification meets the ISO standard - “calibrate, verify or both."
We always meet our customer requirements but I'd like to know – does verification meet the standard or not? stevew
:whip:
harry
Re: Audit and Calibration question
Some argue that calibration and verification are the same but this is another issue argued in many threads here.
The key words for this issue is in clause 7.6a, 'traceable to international or national measurement standards'. Can your so-called verification meet this requirement? I guess not!
Common practice is to send for periodical calibration by a competent lab to meet this requirement. Subsequent verification which may be done as often as daily (depending on factors such as risk involved, etc) is more a matter of good practice and risk management.
:whip:
You can simply verify scales, as you are doing. What was the basis of the evidence of inadequacy the auditor called out? If they simply 'felt' it was inadequate, then that's not good enough to justify you doing anything different.
David DeLong
Verifying and confirming the calibration of measuring instruments is quite different. Possibly your verifying method is really the confirming of the calibration process. It depends upon what exactly is done.
Let's say that you place a sample of known quality on the scales and the scales read within a set boundary. Possibly, one could even adjust the weight or zero it off. I guess that you could say that this process is similar to zeroing off a dial indicator at the beginning of a shift which is is not calibration but a verification process.
You confirmation of calibration should contain various samples (at least 3) throughout the scale usage range. On a regular basis, place the samples on the scale and read the results. Are all within your scale calibration tolerance or not? That is an example of confirming the calibration of your measuring instrument.
One could also bring in a person from a calibration company to perform the same task with the exception that if the scale was out of calibration, this person could also adjust it to bring in back into calibration tolerances.
Before we make this too complex, we also need to understand - in addition to why the auditor make the comment - what these scales are being used for.
What's common practice in calibration and discussions of "confirming calibration" :confused: are misplaced unless we have a good understanding of the use of the scales, first. It seems we ourselves are behaving like the auditor - rushing to judgement before having a complete set of facts. Nothing needs changing until then......
SteveW, over to you.......
C Internal Audit of Internal Calibration Laboratory - Inspection sample size question Internal Auditing 2
K FAA Audit - Major nonconformity for lack of timely calibration of two devices EASA and JAA Aviation Standards and Requirements 5
B IATF 16949 7.1.5.3.2 FAQ #7 Audit Finding - External Calibration Laboratory IATF 16949 - Automotive Quality Systems Standard 7
B Audit of equipment after certified external calibration... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Calibration & Testing Lab here in the States - RA Audit - Wow! General Measurement Device and Calibration Topics 8
A Need to Audit an External Calibration Laboratory? - Customer Audit Finding Other Medical Device Regulations World-Wide 5
B Definition of Calibration Frequency - Dispute during Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A ISO 17020 Audit Findings - Calibration from Accredited Laboratory required Other ISO and International Standards and European Regulations 8
5 Gage not calibrated to full use/range of the gage - Surveillance Audit - Calibration General Measurement Device and Calibration Topics 7
L Is a Supplier Audit required for an ISO certified calibration company? Process Audits and Layered Process Audits 12
A Audit NC (nonconformance) for not following guidelines on calibration! General Measurement Device and Calibration Topics 9
I TS 16949 Audit Minor non conformance - Outside Calibration Laboratory IATF 16949 - Automotive Quality Systems Standard 15
V Audit of Supplier - Calibration Company Internal Auditing 7
Icy Mountain Calibration Purchasing Information - TS 16949 Audit Finding General Measurement Device and Calibration Topics 47
K TS 16949 Calibration System Audit - What questions will they ask me? General Measurement Device and Calibration Topics 11
M How to Internal Audit the Calibration Process Internal Auditing 12
R ISO 9001 Clause 7.6 - Calibration - Audit finding ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
F ISO 9001:2000 Calibration Audit Checklist General Measurement Device and Calibration Topics 4
S Calibration SOP - Surveillance audit Nonconformances in the Calibration Laboratory General Measurement Device and Calibration Topics 4
D Supplier Survey vs. On-site Audit - 13485 Calibration Supplier Quality Assurance and other Supplier Issues 2
Marc Customer Audit of Guide 25 Calibration - Full pre and post adjustment data? General Measurement Device and Calibration Topics 1
B Gamma Quarterly Audit Medical Device and FDA Regulations and Standards News 0
A Anxiety - ISO Re-registration Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
Ed Panek Auditor MDR (Presub audit) finding EU Medical Device Regulations 2
Q Easy CARs for Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
D Question and advice for a supplier self audit questionnaire ISO 13485:2016 - Medical Device Quality Management Systems 6
S Quarterly Dose Audit Medical Device and FDA Regulations and Standards News 5
H When is a SOC 2 audit necessary? IEC 27001 - Information Security Management Systems (ISMS) 3
J NCR- Failure of contract review process - NADCAP audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D Special IATF audit of sub-supplier IATF 16949 - Automotive Quality Systems Standard 5
A Internal audit plan and processes for ISO 14001:2015 ISO 14001:2015 Specific Discussions 3
D Question on using audit checklist ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 12
C API Q1 internal audit report Internal Auditing 3
P Filled in F48/F49 for internal audit ISO 17025:2017 Internal Auditing 1
A IRIS audit - Discussion about Special Processes General Auditing Discussions 11
J Internal audit random sampling methodology Internal Auditing 2
D Major NC from last audit not fixed not sure how to fix General Auditing Discussions 9
X Sample SOC2 audit report (or a redacted one) IEC 27001 - Information Security Management Systems (ISMS) 0
D Lead time to schedule an ISO 13485 audit General Auditing Discussions 2
G Organizing internal audit program for an Integrated QHSE Management System Internal Auditing 13
S Does anyone have a checklist to prepare for ISO 13485, Stage I audit? ISO 13485:2016 - Medical Device Quality Management Systems 1
W How do you phrase your internal audit questions? Internal Auditing 3
Z Steps to take before an MDSAP audit for Canada Canada Medical Device Regulations 2
V Csv, excel format - audit trail file of HPLC system ( Empower, openlab, EZchrom or any other ) Qualification and Validation (including 21 CFR Part 11) 0
G Not accepting a non conformity during an audit General Auditing Discussions 11
K IATF audit day requirements table 5.2 IATF 16949 - Automotive Quality Systems Standard 6
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
M IATF - Internal Audit 3 year span Internal Auditing 4
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
