Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization
Hello all ,
When API product or other industry specification requirements, including addenda, errata and updates, are used in the design or manufacture of the product, the organization shall maintain a documented procedure for the integration of these requirements into the product realization process and any other affected processes.
We have a Document and Data Control Procedure that defines the works and methods of defining, preparing, controlling, approving, publishing, revising and canceling the documents in our Integrated Management System. What can I adding for revised? I don't know what to write
Does anyone have procedures or information?
Thank you
jmech
Based on the title of your post, you are likely trying to resolve an audit nonconformance. If so, I recommend posting the whole nonconformance and a description of how you were trying to meet the requirement at the time of the audit.
Objective Evidence1.The Quality manual refers to the procedure Pr. KGS 02.04 rev.04, but no documented method for integration of external requirements presented in the procedure
Nonconformance/Concern Description1.The Quality manual refers to the procedure Pr. KGS 02.04 rev.04, but no documented method for integration of external requirements presented in the procedure
The methods for document changes that may occur in our system are available in the Document Data Control Procedure. The auditor did not consider the content of the procedure appropriate.
We wrote the following information to the procedure:
The Quality Unit Manager and the IMS Specialist will provide you with all of the documentation pertaining to IMS once a year; the activities, standards, legal requirements and the system are reviewed for efficiency and efficiency.
External Resources;
Externally sourced documents are supplied externally by the units in need. The related units are responsible for the distribution of these documents, the revision monitoring and revision procedures, and the maintenance of these documents. It is followed by List of Foreign Documents
Document from Customers;
Technical drawings, specifications, specifications, engineering instructions, inspection and test instructions, etc. from customers are documents. These documents are reviewed by the unit responsible and controlled by the Technical Affairs Director.
Standards, Periodicals
The procedures applied to the Standards, Laws and Periodicals are explained in the Legal and Other Conditions Procedure Stand
jmech
The auditor appears to be correct: your procedure doesn't describe how requirements from external documents are integrated into your processes. You don't just have to review/maintain/control a copy of external documents; you have to ensure that your processes meet the applicable requirements from these documents, and your procedure needs to describe how you do this.
For example, if you make API 6A valves, simply maintaining a copy of 6A is not enough - you need to integrate the 6A requirements into your product realization process to ensure that your valves conform to 6A.
If you are producing a product to an API spec, how do you ensure that your product meets all the API spec requirements?
Okey. I understood. Tahnks for informations
Dear Nidayes,
Let me share here my view on this. Hope that will clear your doubts.
The external documents are those which you buy. These are the sources on which you integrate your organization.
For example, consider you have API 5CT standard procured. they have specially given Annexure I for thread protectors testing requirements. This is what you have to integrate within your product. That is if you are getting it sourced, provide your supplier a TDc of the same and get the test reports from his every time you source. This integrates that your work is in line with the std requirements. Simply having a licensed purchase version of 5CT is not accepted by auditors.
Consider the color coding requirements on pup joints and accessories. This you have to strictly integrate within your product line.
You may have purchased latest version of spec Q1, E9.. This suggests various steps to be followed. But unless you have your organizational procedures that define all that is included in Spec Q1, and your organization implements it, you cannot integrate the same.
Keep in mind that also as per the changes with addendum or errata in any licenses, dont forget to buy the latest license. This may also lead to a major non conformance.
I have utilized an outside standards service for external documents like - tech street, IHS if you can afford it, it saves you a lot of headaches controlling external docs.
API and it's Normative References - ACK
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 16
B Audit Non-Compliance (Nonconformance) form example needed Document Control Systems, Procedures, Forms and Templates 3
G Not accepting a non conformity during an audit General Auditing Discussions 11
D Do non-IATF customers need to be included in audit scope? IATF 16949 - Automotive Quality Systems Standard 23
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
W Non-Conformance from recent Audit carried out on Purchasing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
G Non Conformance During ISO 9001 Audit - Not All Internal Audits Completed General Auditing Discussions 19
Ed Panek Are audit non conformances also risk based? ISO 13485:2016 - Medical Device Quality Management Systems 1
W ISO standards /Social Audit Franchise (Accredited & Non Accredited) Service Industry Specific Topics 7
I "We don't have enough resources" as an Audit Non-conformance Response General Auditing Discussions 14
E Example of 9001:2015 audit report with non-conformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E Non Conformity due to Outsourced Internal Audit Error ISO 14001:2015 Specific Discussions 2
P Scope of a TS 16949 Audit (Non-Automotive Products) - What?s your opinion? IATF 16949 - Automotive Quality Systems Standard 6
D Consequences of Major Non-Conformances during a Registration Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
G Writing up BRC audit non-conformance Internal Auditing 9
B Root Cause Analysis for Minor Non-Conformities identified in an Audit Nonconformance and Corrective Action 13
W Internal Audit Non Conformance Tracking Logs and NC Systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Non Conformity in Audit: Missing Deputy Rule ISO 13485:2016 - Medical Device Quality Management Systems 10
S Internal Audit - Non conformity not easily fixable (Sales and Contracts) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
A Non-Conforming Product vs. Supplier Audit Finding Supplier Quality Assurance and other Supplier Issues 8
J Developing Plans for Corrective Actions for Audit Non-Conformities ISO 13485:2016 - Medical Device Quality Management Systems 5
P Objecting to Registrar Audit Non-conformances General Auditing Discussions 43
S External Audit Non-Conformance - Control Plan and Inspection Issues IATF 16949 - Automotive Quality Systems Standard 1
Y Audit Non Conformance or not? General Auditing Discussions 6
R Your views and comments on these AS 9100 Related Audit Non Conformities AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K AS 9100 Related Audit Non Conformities AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
B EU MDD Requirement on impact of Rev STDs and audit non-conformance EU Medical Device Regulations 6
V Documenting the Root Causes for Internal Audit Non-Conformance Findings Problem Solving, Root Cause Fault and Failure Analysis 5
V Auditing Treatment, Storage and Disposal Facilities - Non-Visit Audit ISO 14001:2015 Specific Discussions 20
I TS 16949 Audit Minor non conformance - Outside Calibration Laboratory IATF 16949 - Automotive Quality Systems Standard 15
L Non-medical device is in the ISO 13485 audit scope? ISO 13485:2016 - Medical Device Quality Management Systems 11
R Valid Date to Close Internal Audit Non-conformance Internal Auditing 1
C Internal Audit Concerns including Escalation of Non-Conformances General Auditing Discussions 6
M One weakness of audit non-conformance reports is the poor writing Miscellaneous Environmental Standards and EMS Related Discussions 10
Douglas E. Purdy Non-Conformance due to obsolete ISO/TS 16949 audit checklist General Auditing Discussions 36
A Non-conformance logged following a TS16949 Stage 2 audit - APQP Control Plan IATF 16949 - Automotive Quality Systems Standard 15
K Using an "obsolete" test method - TS 16949 Audit Non-Conformance General Measurement Device and Calibration Topics 13
D TS 16949: 2002 section 7.6.1 - MSA non conformity at registration audit IATF 16949 - Automotive Quality Systems Standard 2
K Major Non-Conformity During Initial TS16949 Audit Nonconformance and Corrective Action 2
S Can a registrar recommend with minor non-conformities closed before end of audit? General Auditing Discussions 7
D Major NC from last audit not fixed not sure how to fix General Auditing Discussions 8
X Sample SOC2 audit report (or a redacted one) IEC 27001 - Information Security Management Systems (ISMS) 0
D Lead time to schedule an ISO 13485 audit Auditing Quality and Environmental Management Systems 2
G Organizing internal audit program for an Integrated QHSE Management System Internal Auditing 13
S Does anyone have a checklist to prepare for ISO 13485, Stage I audit? ISO 13485:2016 - Medical Device Quality Management Systems 1
W How do you phrase your internal audit questions? Internal Auditing 3
Z Steps to take before an MDSAP audit for Canada Canada Medical Device Regulations 2
V Csv, excel format - audit trail file of HPLC system ( Empower, openlab, EZchrom or any other ) Qualification and Validation (including 21 CFR Part 11) 0
K IATF audit day requirements table 5.2 IATF 16949 - Automotive Quality Systems Standard 6
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 10
