Audit Nonconformance - 7.2.2 - Contract Review (Review of Requirements)
#11
Hmmm - before we all run off with the idea that the "easy thing" to do is change the procedure, I'm going to ask why this requirement is in there in the first place?
Did the particular director approve this document? It sounds like they could be a process owner. Is there some level of approval for a particular $$ value on which they wish to sign off? Someone wrote this requirement into the procedure and it was approved like that, so what (apparently) went wrong? If it's now not required, who approved that change to the process without initiating a change to the document?
Before anyone simply fixes the document, you might just wish to put it in front of the relevant management and ask them! It is, after all, a MANAGEMENT system....:popcorn:
#12
Some good questions - perhaps this is some of what the auditor wondered about too.
Peace
James
#13
Peace
James
James - thanks, but there's no 'perhaps' about it! At the Cove we see most commonly, just the symptom being reported to CB clients! The auditors may well have found an issue worthy of reporting, however they don't exercise their auditor skills (IF they posses them) and track the real issue down for action!
#14
Granted, We here only get a very small snapshot and a one sided snapshot at that. We try to accept that our QA compatriots are honest and forthright but still, unless we are there, we cannot help but have only a narrow picture.
Likewise we need to accept that the auditor, also a fellow QA person, is trying to do his/her best but that they have to be careful only to report the problem and not try to prescribe the solution - at least that was what I was taught (years ago).
The better auditor will ask questions to, as you say, get at the "real issue" and make sure that the problem they suspect is actually a problem. If he deems it to be legitimate, he must report it and then he must leave it up to the company to look more closely at the troublesome area and determine the best solution.
Peace
James
#15
Agreed - there's a BIG difference between accurately diagnosing the issue and prescribing a fix. Just as we've seen here: people suggesting changing the procedure or the practice, without doing any further 'digging'...
Jason PCSwitches
#16
If this is part of their procedure and they are not following it, then they are not conforming to their procedures.
I would ask how did the auditor came to find out about this. Was it in a written procedure? Did they observe a missing signature field?
7.2.2 clearly states that the organization is required to review the requirements PRIOR to commitment. If the director is doing more than just signing the document this could be a critical part of the review and would need to take place prior to acceptance. If the director is responsible for final review/approval and identifies a potential conflict it's a problem if production has already begun.
On the other hand if it's merely a formality and the review has been thoroughly completed prior to this stage it can be omitted or reclassified.
You need to look at the reason this was incorporated and the age of the process as well. I don't know the size of the organization but it's possible this process was initially implemented back when the organization was small(er) and micromanagement was typical. If the organization has expanded, these elements may be outdated and need revision.
Either way it's an opportunity to possibly improve a process that may have been difficult to do without a finding due to it being associated with upper-management; which sometimes is what it takes to get things done in quality at that level.
#17
Jason's points are good and in fact could point to another issue within the system. Document review and control. If, as suggested, the procedure is old and the situation of the company has changed since it was written, it could point to potential problems with other documents.
IN other words, if this failure resulted from process changes that were not reflected in updated procedures, what other documents might have similar flaws that were not found at this audit, but might be found at future audits...
And even though this item might not particularly effect product quality or customer satisfaction, perhaps there are other items, so far overlooked, that might.
Peace
James
L How to deal with an ISO 13485 Supplier Audit nonconformance ISO 13485:2016 - Medical Device Quality Management Systems 17
K Counterfeit parts prevention - Audit Nonconformance - AS9100 8.2.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
qualprod Ineffective follow up of people performance - Audit Nonconformance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q AS9120 7.5.3.2 Control of Documented Information - Audit Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
J ISO 13485 Audit Nonconformance written against 6.3 Infrastructure ISO 13485:2016 - Medical Device Quality Management Systems 25
PastorBee13 IATF 16949 Audit Nonconformance Responses per 5.1.1.2 - Format IATF 16949 - Automotive Quality Systems Standard 11
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
R ISO 9001:2015 9.3 - Required inputs to the management review - Audit Nonconformance Manufacturing and Related Processes 14
W Minor Audit Nonconformance Against Determining the scope of QMS IATF 16949 - Automotive Quality Systems Standard 12
J Audit opportunity for improvement raised to nonconformance months after the audit General Auditing Discussions 7
GStough Pushback on a Nonconformance Found in a Supplier Audit General Auditing Discussions 22
GStough Nonconformance Found Outside the Audit Scope - Supplier Audit General Auditing Discussions 16
R Closing out an API/ISO QMS Audit Nonconformance - Magnetic Particle Examination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
N Laboratory Audit Nonconformance - Maintenance of Standards ISO 17025 related Discussions 10
D Interpretation of new IAQG ruling - Audit duration for nonconformance verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Gman2 Processes sharing the same nonconformance during an audit General Auditing Discussions 13
T Audit Nonconformance - ISO 9001:2008 Clause 6.2.2 - Competencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
J Audit Nonconformance for Design of Choke Manifold Oil and Gas Industry Standards and Regulations 4
R Internal Audit Scope Requirements - Audit Nonconformance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Raising a Major Nonconformance during an Internal Audit Internal Auditing 23
D Missing Document in a TS 16949 Audit - Nonconformance IATF 16949 - Automotive Quality Systems Standard 5
T Contacting the Supplier's CB vs a Supplier Audit - Nonconformance Problems AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
H API Spec Q1 7.5.2 & 7.5.2.1 - Audit Nonconformance Help Oil and Gas Industry Standards and Regulations 15
J Major Nonconformance on Stage 2 Audit causes to start over Stage 1? IATF 16949 - Automotive Quality Systems Standard 2
K AS9100 Change in Registration Scope - Audit Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
E "Internal" CAPA (Audit Nonconformance) Issuance to your own Department Nonconformance and Corrective Action 4
Q Third Party Audit Nonconformance for Training effectiveness IATF 16949 - Automotive Quality Systems Standard 20
R Audit Plan MNC (Minor Nonconformance) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Control of Documents Procedure - Audit Nonconformance Document Control Systems, Procedures, Forms and Templates 30
D Having trouble with corrective action on external audit nonconformance Nonconformance and Corrective Action 8
J Records Required by ISO 9001 - Audit Nonconformance - No record for 7.5.4 Records and Data - Quality, Legal and Other Evidence 13
J Auditing the Internal Auditing Process - Audit Nonconformance General Auditing Discussions 3
T Management Review - Audit Nonconformance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
Q Post Market Surveillance SOP - ISO 13485 Audit Nonconformance ISO 13485:2016 - Medical Device Quality Management Systems 3
D Corrective Action - AS9100 Approved Supplier List Audit Nonconformance Nonconformance and Corrective Action 14
D ISO/TS 16949 Stage 2 Audit Nonconformance Against 7.6.3.1 Laboratory Scope IATF 16949 - Automotive Quality Systems Standard 8
R Internal Audit Report Nonconformance Follow Ups Internal Auditing 5
P Nonconformance on the Corrective Action Process - Audit Finding Nonconformance and Corrective Action 13
K Audit Nonconformance? Employee References Work Instruction Internal Auditing 17
S Do you tie a Nonconformance (NC) into the last Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
C ISO 9001 Surveillance Audit Nonconformance - Thermometers not Calibrated General Measurement Device and Calibration Topics 117
Q Order Priority during Manufacturing - Audit Nonconformance (Effectiveness 7.5.1) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B ISO/TS 16949:2009 Quality Manual Requirements - Audit Nonconformance IATF 16949 - Automotive Quality Systems Standard 16
T Technical Directives (TD's) not used for Technical Updates - Audit Nonconformance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J AS9100C Clause 7.4 - Supplier Delegation - Audit Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
Q Supplier Audit Nonconformance: What if they adverse its certified QMS? General Auditing Discussions 12
B Mining Nonconformance Data for Potential Missed Audit Findings Misc. Quality Assurance and Business Systems Related Topics 2
T Auditors Reach - FSC (Forest Stewardship Council) Certification Audit Nonconformance Internal Auditing 12
E Internal Audit Nonconformance Classification Internal Auditing 18
