Audit of essential QMS processes
G
glenn0004
Over the past 12 months we have undertaken a programme of System Audits across all departments who are involved within the process of product realization. Our system audits are designed to account for ISO 9001 and I4001 requirements and how the department is accommodating the stated requirements. This includes, Document Control, Record Control, Non-Conformance, Corrective and Preventative Actions and Internal Audit, in effect we are auditing the net results of the six required procedures, within all other requirements.
During our external surveillance audit we pick-up a minor NC for not auditing all of the QMS i.e. we hadn't directly audited our Document Control Process. Our past approach to internal audit has never directly audited Document Control and has always audited the net results.
Does our approach meet the requirements of the standard or will we have to make arrangements for an un-associated person(s) to directly audit the big six?
dsanabria
If you could demonstrate that the results of Document control
"A documented procedure shall be established to define the controls needed a) to approve documents for adequacy prior to issue,
b) to review and update as necessary and re-approve documents,
c) to ensure that changes and the current revision status of documents are identified,
d) to ensure that relevant versions of applicable documents are available at points of use,
e) to ensure that documents remain legible and readily identifiable,
f) to ensure that documents of external origin determined by the organization to be necessary for the planning and operation of the quality management system are identified and their distribution controlled, and
g) to prevent the unintended use of obsolete documents, and to apply suitable identification to them if they are retained for any purpose."
were audited during the process then you have reason to appeal the ncr to the registrar. If not, then added to the processes for all your processes.
Jen Kirley
Quality and Auditing Expert
I agree with dsanabria.
I do agree with sampling documents in the process of auditing all over the site where controlled documents are used. That can help ensure you're not missing a place where controls fall apart.
But there's an expectation that the entire standard gets audited. Demonstrating the support process's coverage as samples in process audits might be easier if a table is used in which the auditor could check off that a) through f) were addressed with the sample. I do this for Management Review too, especially where different clauses are covered in different meeting venues.
G
GoKats78
We don't have Document Control identified as a process. Never been questioned by an auditor as to why not.
Document control happens across all processes and is audited as part of those audits. It is my long-help opinion that is NOT a process.
dsanabria
You are correct - this is why competent auditors will not ask you for it - documents are there to support the process and it is / should be audited as part of the processes by internal and external auditors.
Your auditor is making up requirements and has no clue about process based audits of a management system. Reject the nc back the the CB management and tell them you don't expect to have the same auditor back.
RoxaneB
The way doc control was assessed at our organization was the individual departments to conformance to our documented doc control process...and the "owner" of the doc control process was assessed on the appropriateness of the doc control process.
It was two ways of looking at the process...(1) Are people following the process? (2) Is the established process appropriate?
I'm wondering if this is the approach taken by your auditor.
SmallBizDave
I'm always looking for ways to protect myself from bad auditors without expending any effort. When I create my audit scripts I note the reference for each question as to what section of the standard and what section of the QMS procedures is covered. For example, if I am checking a management review record for required outputs, that question addresses items in section 5 as well as 4.2.4 since it's a record. The record has to be legible, controlled, etc. as well as containing the right information.
There is no standalone Record Control audit but there are questions covering section 4.2.4 (and 4.2.3) scattered through all process audits. So when the auditor wants to see that I have audited records control I can provide traceability to a series of scattered questions proving its been covered. It's not in the format they like but it is certainly compliant.
John Broomfield
I agree with Dave's approach.
When process auditing you bring any applicable clause to bear on reporting the effectiveness of the process, and how well it is served by the system while making sure the audit fulfills its objective.
The idea of conducting a separate document control audit is laughable.
John
C The 10 Essential ISO 9001:2000 Audit Questions General Auditing Discussions 36
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Supplier audit Medical Device and FDA Regulations and Standards News 2
M Go Live With New ERP System before Recertification Audit General Auditing Discussions 6
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
A Define timeline for Major and Miner Audit finding General Auditing Discussions 4
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
B Remote IATF 16949 audit preparation General Auditing Discussions 10
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
I Do I need to sign off my annual audit calendar? Internal Auditing 2
M Nice and simple invitation email to an audit kickoff meeting Internal Auditing 1
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
Q Self-assessment audit information Quality Management System (QMS) Manuals 6
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
xfngrs NIOSH Audit for N95 respirators US Food and Drug Administration (FDA) 1
Sidney Vianna IATF 16949 News Risked Based Audit Day Calculation IATF 16949 - Automotive Quality Systems Standard 2
T AS9100 audit due to facility move AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B SAP Audit trail Periodic Review EU Medical Device Regulations 1
N What are the software audit and control steps Reliability Analysis - Predictions, Testing and Standards 2
R Gap Audit Aerospsace and Rail QMS Quality Manager and Management Related Issues 0
salaheddine96 Internal audit planning Internal Auditing 2
A MDSAP Audit Questionnaire Medical Device and FDA Regulations and Standards News 7
H Obligations as a contract manufacturer during an MDSAP audit ISO 13485:2016 - Medical Device Quality Management Systems 5
M What are the basics of Medical Device Single Audit Program (MDSAP)? ISO 13485:2016 - Medical Device Quality Management Systems 7
Sidney Vianna IATF 16949 News Update on the IATF CARA Project (“Common Audit Report Application”) - 12/2020 IATF 16949 - Automotive Quality Systems Standard 1
R ISO 17025 vertical audit checklist wanted Document Control Systems, Procedures, Forms and Templates 2
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
S Quality Audit Training Activities Quality Manager and Management Related Issues 2
G IATF Rules for COVID 5th revision - Re-certification audit timing IATF 16949 - Automotive Quality Systems Standard 3
E MDR internal audit Internal Auditing 1
Ed Panek Remote Audit GOTOMEETING thoughts Coffee Break and Water Cooler Discussions 22
B ISO 9001 - "Remote Audit Fee" Registrars and Notified Bodies 13
L IATF external audit virtual (remote) IATF 16949 - Automotive Quality Systems Standard 13
M Audit Criteria Training Materials Internal Auditing 1
K New supplier audit as per V3.1 by French Automotive OEM General Auditing Discussions 2
S Complexity Rating - CB adding another audit day for "high complexity" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
K MDSAP Audit Approach 2020 for Brazil Other Medical Device Regulations World-Wide 1
K MDSAP Audit Approach 2020 ISO 13485:2016 - Medical Device Quality Management Systems 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
