Audit Points for Auditing a Welding Supplier
sally2012
Hi everyone, I'm here again to ask question from you guys. I will audit one of our supplier who is engaged in steel works and I'm not knowledgeable enough in terms of welding activity. Could you please share some guiding questions and what documents to look for when I audit their welding process? I did some research and I saw terms like WPS, PQR and others. Please help me on this.
jbeckproe
Re: ISO 9001:2008 Audit Points for Welding
Google, American Welding Society Welding Inspection Handbook.
It will be very hard to audit a welding company without prior knowledge of welding, processes or WPS's (which stands for Welding Procedure Specification).
Not only will you need to audit their welding process but I would also recommend auditing their NDE process, PWHT (Post Weld Heat Treatment), calibration of welding equipment, rod storage control, etc.
I do a lot of welding audits. Most of the time the welder is not following the WPS. This will include rod selections, pre-heat, amp, volts, etc.
Some other books to review.
AWS D1.1
ASME Section 9
Good luck
Jason Beck
qusys
We should know the objective and the criteria of the audit.
Do you intend to potentially qualify it to work for your organization or is it an audit to check eventual open issues?
Is the scope related to their Quality mgmt system on their premises or versus the work performed directly on your site?
If you have signed off a contract with them and a scope of the work , you may want to assess their activity on your site based upon the requirments you have agreed with them in terms of quality, costs and time.
Besides, you could involve technical expert for the part related to the service if you do not have any competence about them.
Lead auditor of the team can involve adequate resources for the scope, taking into account the request of the commitment of this supplier audit.
I do not know if it helps:bigwave:
Sally - why are you going to be doing this audit? I agree with the previous post. If you are not familiar with the welding process, an audit will be almost meaningless and, frankly, the result of your audit won't be worth very much if you are looking to qualify a supplier etc. Do you have someone you can take along with you, who knows welding? They can act as an 'interpreter' almost...
sally2012
Hi Andy, sometimes there are task that should be done because your boss asked you too. Sometimes, there are boss that ask you to do things thinking that you are superwoman who can do everything and knows everything. I'd like to believe that my audit will not be meaningless (as you said) because I still have weeks to study the basics of welding process. I would never do something futile that is why I'm exerting extra effort for this. And of course, you guys are helping me with all these ideas. Thanks for the COVE!. =)
qusys
Hi Sally, only a question for you.
DId you ever conduct audit? Do you have experience in supplier audit as well?
This could be critical more than technical knowledge.
ISO 19001 guidelines are useful for this.
Besides the committent shall indicate the objective and the criteria of this audit. The risk is that if you are studying welding basics, it will be unusefull if the scope is not clear.:bigwave:
sally2012
Yes, I have been auditing and audited for several years now. No worries about that. The only thing that bothers me is that it is my first time to audit welding process. =)
Antyp
My input will be surely not full, and probably i forgot a lot (i didn't work with welding for last 5 years) but i will write little something i was always checking and find a lot of issues on those fields.
If it is automatic welding line, check very deeply quality control performed by operators and rules for repairs, as well as records after repairs i never seen autmatic welding without manual repairs.
Important is welder training (internal depending on circumstances - for special characteristics and so is not enough) and very clear visual aids, as this is visual control...
Whats worth also to go into, is cut control (idk proper english name) to see and evaluate weld penetration on both materials. Requirements, records and finally take a sample and let them cut and measure it in front of You, microscope is kind of a "must".
If welding is performed on special "jigs - lock tables" check if clamping of welded parts are proper and this table is inspected and adjusted (it can be treaten like semi pokayoke, not to mention about preventive maintenance).
If not check how they secure welded parts against mistakes rooted with position.
As was already mentioned setup of parameters is a must and depends on type of welding, as well as welding materials.
I would also go into quality control of parts that are going to be welded - material composition and such, which can determine welding method and parameters, and naturally periodical inspection of material.
Finally i do not completely agree that auditor should know the process before auditing, i got far better results when i took position of a men that dont know nothing and is asking for complete explanation and help to understand. I used this approach even when i knew how the process should go.
E What are Theo Points in a checklist document for a TS16949 Audit IATF 16949 - Automotive Quality Systems Standard 1
A 8D (8 Disciplines) Problem Solving for TS16949 Audit Points IATF 16949 - Automotive Quality Systems Standard 20
R Ethics: Audit Question points auditor to a possible nonconformance General Auditing Discussions 73
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Supplier audit Medical Device and FDA Regulations and Standards News 2
M Go Live With New ERP System before Recertification Audit General Auditing Discussions 6
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
A Define timeline for Major and Miner Audit finding General Auditing Discussions 4
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
B Remote IATF 16949 audit preparation General Auditing Discussions 10
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
I Do I need to sign off my annual audit calendar? Internal Auditing 2
M Nice and simple invitation email to an audit kickoff meeting Internal Auditing 1
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
Q Self-assessment audit information Quality Management System (QMS) Manuals 6
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
xfngrs NIOSH Audit for N95 respirators US Food and Drug Administration (FDA) 1
Sidney Vianna IATF 16949 News Risked Based Audit Day Calculation IATF 16949 - Automotive Quality Systems Standard 2
T AS9100 audit due to facility move AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B SAP Audit trail Periodic Review EU Medical Device Regulations 1
N What are the software audit and control steps Reliability Analysis - Predictions, Testing and Standards 2
R Gap Audit Aerospsace and Rail QMS Quality Manager and Management Related Issues 0
salaheddine96 Internal audit planning Internal Auditing 2
A MDSAP Audit Questionnaire Medical Device and FDA Regulations and Standards News 7
H Obligations as a contract manufacturer during an MDSAP audit ISO 13485:2016 - Medical Device Quality Management Systems 5
M What are the basics of Medical Device Single Audit Program (MDSAP)? ISO 13485:2016 - Medical Device Quality Management Systems 7
Sidney Vianna IATF 16949 News Update on the IATF CARA Project (“Common Audit Report Application”) - 12/2020 IATF 16949 - Automotive Quality Systems Standard 1
R ISO 17025 vertical audit checklist wanted Document Control Systems, Procedures, Forms and Templates 2
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
S Quality Audit Training Activities Quality Manager and Management Related Issues 2
G IATF Rules for COVID 5th revision - Re-certification audit timing IATF 16949 - Automotive Quality Systems Standard 3
E MDR internal audit Internal Auditing 1
Ed Panek Remote Audit GOTOMEETING thoughts Coffee Break and Water Cooler Discussions 22
B ISO 9001 - "Remote Audit Fee" Registrars and Notified Bodies 13
L IATF external audit virtual (remote) IATF 16949 - Automotive Quality Systems Standard 13
M Audit Criteria Training Materials Internal Auditing 1
K New supplier audit as per V3.1 by French Automotive OEM General Auditing Discussions 2
S Complexity Rating - CB adding another audit day for "high complexity" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
K MDSAP Audit Approach 2020 for Brazil Other Medical Device Regulations World-Wide 1
