Audit Programme - Include CB Audits, Customer Audits, Supplier Audits?
#11
Is the applicable standard ISO 9001:2008 OR ISO/TS 16949:2009?
It is true that you cannot schedule your audits taking into account these other audits. But, the standard in two sections (8.2.2 and 8.2.2.1) makes a reference to ......any other quality management requirements.....and
.....................actions taken without undue delay to eliminate detected nonconformities and their causes.
Hence, defining the audit scope by including these, it is expected that your internal audits and the internal auditors verify these also for effectiveness of the actions taken. If any gap(s), the internal auditor reports the same.
I think this is a somewhat different matter. You CAN schedule audits depending on external audits! But the CB auditor saying that their audit programme MUST include them is different. Putting together a 12 month calendar of audits, including the external ones, is impractical, however, taking them into consideration, when scheduling an internal audit is a subtle but important difference.
If the CB auditor found no evidence of that being considered, they might have good reason to make such a statement, but to demand their inclusion in the programe is wrong.
Richard Regalado
#12
We had just being audited on our stage 1. The CB auditor commented on our Audit Programme, according to them we should include other audit such as CB audit, customer audit, supplier audit because the content of our audit programme is the internal audit and management review for two cycle. Did raised it appropriately?
Thanks.
Hi. It's just a comment ("should" right?). Anyone can comment on anything. Has the comment found its way into the audit report? You may consider it as an opportunity for improvement.
Including external audits on the audit programme is being done by some organizations. It is an added input to audit planning, ensuring that internal audits and supplier audits are evenly spaced out and resources are provided for both.
For your customer audits, you may ask the customer for this information and plug the information to your audit programme.
You will then have a timetable on when ALL the audits would happen and allow you to plan for audits, both internal and external, ahead of schedule.
qusys
#13
Re: Audit Programme
Actually, that was not the only weird result that they noted on thier stage 1, they seems to be doing consultation and they are debulging from the ISO9011 standard. Do you want to read their other weird audit result. I will post it if you want to and it was the first audit I experienced too many debates going around.
Yes, it could be usefull to share the info , so that we could have more details and the precise statement the CB auditor wrote.:bigwave:
jm1231
#14
Attached is their audit report. Though some of them has grounds to raise it and was acceptable. But the rest, you would agree that it is inappropriate. They do consulting actually, not auditing.
qusys
#15
Thnaks a lot.
I think that there is a few confusion.
Are you applying for ISO 9001 or ISO 14001 certification?
I interpreted in a certain way, if you give more precise info also for all covers, they will help so much.
The report is quality and environmental oriented and I do not know what the rules are for your certification body. Lots of Observations seem to be their "desiderata" and I do not on what basis they raised up.:bigwave:
RoxaneB
#16
Thanks.
I agree with the others in that this is not a requirement, however to use such sources as input for continual improvement and as part of your management review could be beneficial.
For example, results from your supplier audit may show that a new product is being developed and your existing equipment is unable to process it....or results from the customer audit may indicate that they will be soon stop accept material that happens to be contained within your product and your management will need to decide how to handle this.
Again...requirement, no...nice to have?...yes.
qusys
#17
Agree with you, but audit results are however an input to management review.
I think that the cover will provide additional details on this topic.
I think there is a confusion because we do not understand yet if it is a stage 1 for ISO 9001 certification or ISO 14001 one.
Considert that stage 1 audit should be only a pass/no pass for stage 2, therefore certification audit. I did not understand the final result of this stage 1.
As the cover said, it seem a sort a consultancy gap assessment.:confused:
RoxaneB
#18
While the requirement is for audit results, most organizations (in my experience) limit this to ISO internal and external audit findings only, and do not include supplier, customer, contractual, financial, and non-ISO (or non-standard) audits.
While these additional audits may be outside of the scope of an ISO-based QMS or EMS, my point is that an organization wishing to truly adopt a culture and system of improvement and innovation should go beyond the mere requirements.
It sounds as if the external auditor for the original poster has recognized the organizations steps towards CI in the past and perhaps the original observation was simply a means to help them continue on that path.
#19
Now I'm confused! Who is doing this 'stage 1'? You originally posted it was your CB!
Are you using a consultant to do some preparation before you get registered with a CB? It's going to be confusing if the consultant is doing the same kinds of things and calling it the same and then, offering you silly observations like this!
Perhaps you'd clarify for us.
Raffy ISO 14001 9.2.2 Internal Audit Programme Content Internal Auditing 10
A IATF 16949 - 9.2.2.1 Internal Audit Programme - looking for example IATF 16949 - Automotive Quality Systems Standard 5
RoxaneB Carte Blanche to Create an Audit Programme General Auditing Discussions 5
I The Beginning of an Audit Programme / Plan Internal Auditing 4
S Internal and External Audit Programme Implementation Internal Auditing 6
Q Reducing the Frequency of Audits - Internal Audit Programme 2012 Internal Auditing 13
C EASA Part 145 Audit Programme example wanted EASA and JAA Aviation Standards and Requirements 6
G What is an "Audit Program (Programme)"? General Auditing Discussions 18
P Work plan to support Internal Audit Programme Internal Auditing 6
T Standardised audit programme, advantages and disadvantages General Auditing Discussions 5
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Supplier audit Medical Device and FDA Regulations and Standards News 2
M Go Live With New ERP System before Recertification Audit General Auditing Discussions 6
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
A Define timeline for Major and Miner Audit finding General Auditing Discussions 4
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
B Remote IATF 16949 audit preparation General Auditing Discussions 10
M AS9100D Registrar pre-audit requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
I Do I need to sign off my annual audit calendar? Internal Auditing 2
M Nice and simple invitation email to an audit kickoff meeting Internal Auditing 1
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
Q Self-assessment audit information Quality Management System (QMS) Manuals 6
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
xfngrs NIOSH Audit for N95 respirators US Food and Drug Administration (FDA) 1
Sidney Vianna IATF 16949 News Risked Based Audit Day Calculation IATF 16949 - Automotive Quality Systems Standard 2
T AS9100 audit due to facility move AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
A Internal Audit Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B SAP Audit trail Periodic Review EU Medical Device Regulations 1
N What are the software audit and control steps Reliability Analysis - Predictions, Testing and Standards 2
R Gap Audit Aerospsace and Rail QMS Quality Manager and Management Related Issues 0
salaheddine96 Internal audit planning Internal Auditing 2
A MDSAP Audit Questionnaire Medical Device and FDA Regulations and Standards News 7
H Obligations as a contract manufacturer during an MDSAP audit ISO 13485:2016 - Medical Device Quality Management Systems 5
M What are the basics of Medical Device Single Audit Program (MDSAP)? ISO 13485:2016 - Medical Device Quality Management Systems 7
Sidney Vianna IATF 16949 News Update on the IATF CARA Project (“Common Audit Report Application”) - 12/2020 IATF 16949 - Automotive Quality Systems Standard 1
R ISO 17025 vertical audit checklist wanted Document Control Systems, Procedures, Forms and Templates 2
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
S Quality Audit Training Activities Quality Manager and Management Related Issues 2
G IATF Rules for COVID 5th revision - Re-certification audit timing IATF 16949 - Automotive Quality Systems Standard 3
E MDR internal audit Internal Auditing 1
Ed Panek Remote Audit GOTOMEETING thoughts Coffee Break and Water Cooler Discussions 22
B ISO 9001 - "Remote Audit Fee" Registrars and Notified Bodies 13
