Audit Schedule for Multi Site Certification
joshua_sx1
#11
...The last option is to let your 3rd party auditor "discover" the problem during their audits...
…usually, it is better for your organization to discuss what would be your corrective and/or preventive actions to your nonconformance and/or foreseen nonconformance… instead of taking the risk and see if the external auditor would find it… ISO does not work on that way…
#12
…internally? this can be done… provided that you have enough no. of qualified internal auditors on each sites (and that they should be independent from the site they are auditing)…
Not at all - in fact it's advisable to have the auditor from the site being audited. Indeed, as we've done over so many times, there is no requirement for the auditor to be 'independent'..........they just can't audit their own work (which you pointed out in one of your own posts, recently)
joshua_sx1
#13
(He he he… here we go again… :eek:)
OK, as AndyN said, there is no requirement for the auditor to be 'independent'… - as long as the assigned auditor is not directly involved in the development and implementation of the QMS in the process he is going to audit… :)frust: you know guys, I was having a hard time why you cannot consider those scenarios as “independent”?)
…anyway, just to add (as quoted from another thread), ISO 19011 doesn't say anything about auditors not auditing their own work... ISO 9001 is very specific, but ISO 14001 doesn't prohibit it and neither does, OHSAS 18001, PAS 99, or BS 25999… :notme:
(whew... I hope it'll stop there...)
Helmut Jilling
Auditor / Consultant
#14
If you reread the context of that sentence, you will see I was inferring that sometimes you can use an external auditor to your advantage. Sometimes when no one listens to an internal auditor or manager, when the external auditor writes it up, it has a little more leverage. But, that is a risky move and should not be used often. As an auditor, I don't like it, but I am sure I have been "shown" a few things over the years.
Helmut Jilling
#15
The concept of auditors being independent is pretty well ingrained in all the ISO standards and history. And, I would point out, that 19011 applies to 9001 and 14001, and can be applied in principle to 18001. The words change slightly with each iteration, possibly in an attempt to clarify the intent, to stop just this sort of discussion or debate as to what is allowable.
The answer is not black and white. There is a little grey. But the principle is that people should be improving their processes all the time, and should not wait for an audit. And the second is that auditors should have a fresh perspective, not the same perspective they apply to that job every day. And, third, less emphasized in the current version, is they should have some degree of freedom from their direct boss, when they have to write findings.
Now, these are my paraphrases, not quotes from the standards, but I think they do a good job of explaining in plain English what we should look for.
PS Josh, the internal auditors can audit at their own sites without any problem, just not their own work (or processes they have responsibility for).
Coury Ferguson
Moderator here to help
#16
I have used the Third Party Auditor in that way, when I have hit a roadblock on something. Which doesn't happen that many times, but does happen.
The Third Party Auditor is a person that can reiterate your concerns and help you with changes, but don't rely on the Third Party all of the time. If you are in a position, that drives changes, then only use the Third Party Auditor on an occasion. Because relying on the Third Party for changes, only could hurt your goals and aspirations in the Organization, in my opinion.
MichelleD
#17
I truly believe we have the auditors in place. The problem I'm having is that the powers that be came along several months ago and said you will know have a multi site certification without giving us the proper time to make it happen. Everyone is comfortable with the way the are doing the audits at their site and they don't want a knew way of doing things. Even though the registrar pointed out that is an area that could be beefed up. We were chosen as the lead site because we have a mature system in place and we know have to roll reports up on audits, CAR's/PAR's, Quality System, etc.
Helmut Jilling
#18
Based on what you say, then, the only thing you may need is to develop that harmonized multi-site schedule you have discussed.
MichelleD
#19
That's where I'm headed but does anyone have a good way I can explain the benefits of having one schedule for all sites. I would appreciate any bites of wisdom that you have. Rather than me just saying "do it":whip: I want to give them some valid reasons why this is a good idea for all of us.
Helmut Jilling
#20
...cuz Corp said so.....
Actually, a multi-site schedule can be a simple matrix made up of the individual schedules:
Corp:
Process # 1
Process # 2
Process # 3
Plant A:
Process # 1
Process # 2
Process # 3
Plant B:
Process # 1
Process # 2
Process # 3
with twelve columns to show the dates the various audits will take place.
U Internal Audit Schedule for Multi-site certificate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
A Add MDSAP to Internal Audit Schedule Medical Device Related Regulations 0
N Internal Audit Schedule – Who gets to set the schedule? Internal Auditing 16
T Internal Audit Schedule when Hiring Out Internal Auditing 7
R How far apart can you schedule separate areas or departments in your internal audit? Internal Auditing 4
A API Spec Q1 9th Edition - 12 month Internal Audit Schedule Audit Nonconformance Oil and Gas Industry Standards and Regulations 10
D Where I can find an ISO 13485:2016 Audit Schedule example? ISO 13485:2016 - Medical Device Quality Management Systems 4
J AS9100D - Good ways to document an internal audit plan / schedule Internal Auditing 25
K Is an annual "audit schedule" the same thing as an audit scope/ audit plan? Internal Auditing 8
C Does anyone have an AS9100:2015 audit schedule template? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D Please share your IATF 16949 Internal Audit Plan and Schedule Internal Auditing 13
M MDSAP Audit Plan - Please share an Audit Plan/Schedule/Agenda ISO 13485:2016 - Medical Device Quality Management Systems 7
P Internal Audit Schedule Complexity (ISO 9001:2015 ) Internal Auditing 3
A Developing a ISO 9001:2015 Internal Audit Plan and Schedule Internal Auditing 40
M Example Internal Audit Schedule wanted Internal Auditing 47
L Sourcing Audit Schedule for Supplier Audits IATF 16949 - Automotive Quality Systems Standard 3
S No Audit Schedule and Internal Audit not Performed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
L R2 Certification Internal Audit Plan, Audit Sheet, and Schedule Manufacturing and Related Processes 2
B Is there an FDA requirement for a Supplier Audit Schedule US Food and Drug Administration (FDA) 22
S Help me with preparing Internal Audit Schedule based on Risk analysis 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R Internal Audit Schedule Conformance Quality Manager and Management Related Issues 31
L ISO 13485 Internal Audit Schedule example needed Internal Auditing 9
Moncia Supplier Audit Requirements for ISO 22000 - Is a schedule required? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
M QSIT-Based ISO 13485 Internal Audit Schedule Internal Auditing 8
C Does anyone have an example of an ISO 14001 Internal Audit Schedule ISO 14001:2015 Specific Discussions 2
J Timing of an Internal Audit Schedule ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
R Receiving inspection and Internal Audit schedule ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
V Layered Process Audit Schedule example Process Audits and Layered Process Audits 2
N Second Party (Supplier) Audit - Audit Schedule and Audit Report Template/Format General Auditing Discussions 3
J Creating an Audit Schedule & Revamping QMS Internal Auditing 18
C IMS (ISO 14001/ BS OHSAS 18001) combined Audit Checklist & Schedule ISO 14001:2015 Specific Discussions 1
J Internal Audit Schedule - Please review my Internal Audit Schedule Internal Auditing 19
S Internal Audit Procedure and Schedule example Internal Auditing 2
T Internal Audit Plan/Schedule wanted Internal Auditing 19
M Audit schedule example (TS16949 & ISO14001) General Auditing Discussions 9
J Internal Audit schedule & Process Audit Checklists Internal Auditing 3
T Audit Schedule Advice Needed - To cover all ISO 9001 requirements General Auditing Discussions 4
S Internal Audits not performed - Useful data from internal audit schedule Internal Auditing 31
V Creating an ISO 14001 Internal Audit schedule Internal Auditing 13
GStough Internal Audit Frequency Schedule: Monthly, Quarterly, or Bi-Annually? Internal Auditing 46
M Audit of Goods In as part of the QSIT "Production & Process Controls" Schedule 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Scheduling or Creating a Global Audit Schedule - Examples General Auditing Discussions 5
V Is there a requirement for Internal Audit Schedule to be Approved? Internal Auditing 11
Crusader Design Activities Schedule - ISO 9001 Audit Nonconformance 7.3 - Opinions? Design and Development of Products and Processes 21
P The Optimal IA Schedule - How should the Internal Audit Schedule be set up? General Auditing Discussions 26
D How to Schedule a Manufacturing Process Audit General Auditing Discussions 13
N Creating an Internal Audit Schedule Internal Auditing 48
B TS16949 internal audit schedule template Internal Auditing 4
A Internal Audit Schedule Updates - Necessity of a revision date on the schedule Internal Auditing 8
