Auditing a process outside the realm of the formal Internal Audit
rvanelli
Is it common place for one department to audit a process outside the realm of the formal internal audit process as described in 8.2.2?
For example what might the logic be for a trainer in the HR department to audit training records kept by other departments but the audit takes place outside the controls of 8.2.2, is not part of the audit schedule and the results not reported at management review? Would this be an unusual practice?
JoeDM
I don't know if I can relate to your specific example, but maybe I can give you one that might relate:
I am auditing the manufacturing process. The production workers are working to design drawings. While conducting the audit I notice that the worker has a drawing open at his work station. I look at the drawing and notice red line changes on the drawing that are not signed off by an engineer, as required by the QMS.
In this case, though I am not auditing design, I would write an CA to the design group because the drawing was changed without an approval.
The example is not exactly the same as yours because the design process is in the audit schedule somewhere, but it is not currently being audited.
When auditing a process, it is important that the auditor not audit with 'the blinders on'. It is appropriate to write a CA on a non related process, if the auditor stumbles on something.
Hope this helps.:)
Ninja
Looking for Reality
Let's step outside of the documents for a second and consider the big picture...a person employed by the company noticed something going on in the company that is contrary to what the company has decided should go on.
Proper reaction: Raise a flag so that it gets fixed and comes back into line of what the company has decided should go on.
The rest is just terminology and paperwork...call it a "Quality System Improvement"...call it a "Preventative action"...tie it to 8.2.2...or tie it to the hitching post outside...
It is totally acceptable (it is WANTED) that employees of the company who see something falling short of the desired target would act to bring it back on track. The only question left is how the company chooses to bring it back on track.
:2cents:
Oh, and to answer the question asked...it happens all the time in my department and the departments with which they interact, I strongly encourage it.
Jen Kirley
Quality and Auditing Expert
I see nothing at all wrong with HR conducting oversight on other departmental training, which I presume was done to help ensure the departmental training was up to standards. I would argue that it represents a form of process control in training, and it's a good idea.
That said, in my view it is not a process audit of Training and can't substitute for one. However, I see no reason why its data can't be recognized by the regular auditor as an input to the audit on 6.2. In addition, I see no reason why not purposely plan to include this kind of help from subject matter experts in HR to assist the appointed person qualified as per 8.2.2.
I hope this makes sense!
I
isoalchemist
It happens all the time. You will certainly have the formal audit process set-up within the QMS, but random checks can occur at anytime by anyone. If issues are found certainly raise a NC and get it formally corrected in the system.
Internal audits are great tools to keep track of system health, but it's amazing how much a simple question "wonder what XXXX look like in....?" can uncover.
AndyN
Moved On
If you have an established audit program, why would anyone want to work outside of it? I would question the motives of the "informal" audits and also why the formal audit process isn't being used by those people. One way or another, you've got a problem on your hands!
Boingo-boingo
As usual, we need much more information before we are able to pass meaningful judgement.
What if HR was checking on safety related training? That has nothing to do with ISO 9001 8.2.2, simply because safety is not covered in 9001.
AndyN
Moved On
Who says an internal audit program has to address only ISO 9001? My comment stands!:mg:
Boingo-boingo
Certainly internal audits don't have to be confined to the QMS, but this thread is under ISO 9000, 9001 and 9004 and the original post in this thread mentioned ISO 9001 8.2.2.
I am just giving a potential scenario where HR was doing an audit/check of something that has nothing to do with the QMS and the QMS internal audit process.
AndyN
Moved On
Right! Where else would you post a question if you are from an ISO 9001 reg. company and you have a question about internal audits, is what I'd ask. If they have a management supported IA process, where management participated in the process, they still wouldn't need to do audits "outside" of the program, they'd ask the question "what do we have to do to arrange an audit of "X". Since the OP isn't outside the remit of an ISO 9001 IA, anyways, the issue I raise is valid. We can run the "what if scenario" until the cows come home...
S 9001 + 14001 Internal Auditing Process checklist, flowchart or questionnaire ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Information on Process-based Internal Auditing Needed Internal Auditing 6
Sortinghat Auditing the Manufacturing Process IATF 16949 - Automotive Quality Systems Standard 3
Q What is Process Auditing? Process Maps, Process Mapping and Turtle Diagrams 9
tony s What is the automotive process approach for auditing? IATF 16949 - Automotive Quality Systems Standard 2
J Recomended Values - Auditing process in a supplier IATF 16949 - Automotive Quality Systems Standard 18
P Auditing "process validation" process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Suggestions for a UK based course in Process Auditing wanted Training - Internal, External, Online and Distance Learning 2
A Best Method of Auditing an Installation Process at a client job-site ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Where in the ISO 9001 standard it asks for process based auditing? Process Audits and Layered Process Audits 6
K Auditing New Product Introduction Process General Auditing Discussions 21
P System Audit Approach - Application of VDA 6.3 - Process Auditing VDA Standards - Germany's Automotive Standards 2
L Stability of the Process vs Improvement during Auditing General Auditing Discussions 8
K Process Auditing Clause 7.3 Design and Development Internal Auditing 11
R On Auditing Internal Audit Process - How Independence can be Established Internal Auditing 4
G The future of the Process Approach to Auditing General Auditing Discussions 10
M Process Auditing in a Distribution Company Process Audits and Layered Process Audits 3
M Auditing the Internal Audit Process - 8.2.2 General Auditing Discussions 2
J Auditing the Internal Auditing Process - Audit Nonconformance General Auditing Discussions 3
J Help in Process Auditing - Turtle Diagram Examples Internal Auditing 2
K The Value of Turtle Diagrams in Process Auditing Internal Auditing 27
V Relevance of Process Based Auditing (PEAR) to regulated industry. US Food and Drug Administration (FDA) 3
Q Auditing Management Review - Who audits the management review process? IATF 16949 - Automotive Quality Systems Standard 5
B Process Approach to Auditing Quality Management System Internal Auditing 12
J Auditing the Budgeting Process (ISO 9001) General Auditing Discussions 13
A Auditing sufficiency of documented quality objectives vs the real process Internal Auditing 14
B Internal Auditing of a Process or Workplace? OHSAS 18001 Occupational Health & Safety Management Standards 12
A Green Belt Project for Improving Internal Process Auditing and Metrics Six Sigma 5
K Auditing the Internal Vendor (Supplier) Management Process Supplier Quality Assurance and other Supplier Issues 2
P Auditing Process Classics - I am planning to take CQA exam Professional Certifications and Degrees 5
T Can an Internal Auditor be involved in the process they are auditing? Internal Auditing 8
A Process approach to auditing ISO 9001:1994 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Layered Process Auditing (LPA) for a service provider Process Audits and Layered Process Audits 4
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
D Information Technology Process Audit - Suggestions for Auditing IT IATF 16949 - Automotive Quality Systems Standard 12
Z First time Auditor - Auditing an Outsourced Process General Auditing Discussions 3
J Determining Legal& Statutory requirements while Auditing Design & Development process Design and Development of Products and Processes 8
A Process Approach to Auditing Undocumented Processes at the System Level Internal Auditing 7
W What is meant by Process Approach Auditing and What questions should be asked? Process Audits and Layered Process Audits 11
C Reference Guide for Process Auditors - Yet another Process Auditing Tool General Auditing Discussions 1
H Auditing Lean as a process - Where to begin? Internal Auditing 9
5 Process based Internal Audits, instead of auditing to the elements of the standard Internal Auditing 21
R Auditing Accounting as a Key Process - TS16949 Audit Internal Auditing 6
R Process Auditing - Identifying/Monitoring "Key" Processes Sufficient? Process Audits and Layered Process Audits 5
J Internal Process Auditing - Auditor Unhappy - Wants Layered Process Audits Process Audits and Layered Process Audits 13
V Process approach based internal auditing Internal Auditing 1
S Automotive Process Approach Auditing sanctioned interpretations S1 04 04 General Auditing Discussions 1
P Process vs Elements/Checklist - Is the old method of auditing the clauses still legal General Auditing Discussions 41
H Auditing - System Approach and Process Approach Differences? General Auditing Discussions 20
S Auditing - by department, clause or process? General Auditing Discussions 14
