N.galt, I've read many interesting and thoughtful posts in this thread. In your case, it's probably about both culture (change management and managing people, as you mentioned) and technical (ISO9001 is more general than AS9100). I am rather junior in QA here in the US (as a new and soft chapter in life, under circumstances), but pretty senior in business management as CxO in several countries for 21 years. My personal tips:Yes, I've gathered that it's been advised against.
It's more culturally that I'm struggling with, than technical Quality Problems.
Because the NCR's are in the hundreds it's nearly impossible to tackle- I've posted previously on this forum about it separately. It's a very bad sticky plaster that I'm managing, we've always just had enough in place to pass audit but not a robust QMS. We're coming up to audit and I'm just trying to pick up the pieces from previous years, just at least for this years audit. It's a tough job but someone has to do it and it's a pick your battle situation.
Culturally, it's more just about change management and managing people. I can look in all areas of the QMS and see issues, it's just about picking one problem and seeing it through until it's fixed.
- Have two "books", one for yourself and one for "outsiders".
- For yourself, be very sincere to yourself and your management, carefully list and plan for what should be done for your QMS.
- For outsiders, very well prepare to handle possible questions/concerns/ etc. the immediate goal is to pass the audit. Try to make "majors" look "moderates" or "minors".
- Nothing else.
- If you pass the audit, you will have some break to implement your plan (who do what and when and how, and how much etc.). If you cannot convince your management about your CAPA plan (because they don't see the necessity, as you already pass it, why putting more resources?), get tips from a management forum and start plan B for your career (with 1 more star in your CV, passing the 9001 audit).
- If you fail the audit, it's unfortunate for your company, but a good opportunity for you to carry out your plan. Very likely that your management will accept your plan.
At the end of the day, I guess you are the one who can sit on a "very bad sticky plaster" for too long. So, the "CAPA" plan should be your ultimate goal, not the audit.
Good luck!
