Auditing TS 16949 Cl. 7.6.3.1 - Internal Calibration Laboratory Requirements
SandyStarkie
Good Afternoon
I also have a question concerning 7.3.3.1. It states "The laboratory shall specify and implement, as a minimum, technical requirements for
adequacy of the laboratory procedures
competency of the laboratory personnel
testing of the product
capability to perform these services correctly, traceable to the relevant process standard and
review of the related records
The two items I have in bold I could not find evidence of during an internal audit. I found a training record from lab tech from 2001 and it was before the word "Competent" was added to training ledgers. I found nothing describing how the lab tech is trained or deemed competent. Does this have to be in the lab scope or procedure?
What is evidence of review of related records?
John Broomfield
Good Afternoon
Sandy,
Of course training does not always result in competence. You need to ask the auditee how they determine the competence of the lab techs and others whose work affects quality. You may find they have not determined the competencies required or have not verified that people are competent for the work they do or that it is simply a record keeping issue.
When planning the fulfillment of future requirements the organization considers the competences necessary to fulfill those requirements, it may even review its competency records! The same goes when assigning work to competent staff and when informing the team who has the expertise they seek.
John
SandyStarkie
Thank you John... I agree that they have not defined the competence level. When I ask this often during internal audits the auditee often gets up-set and explains they have a training record. I explain that I understand that but these are old and do not show competence was evaluated so I need to know how do you determine they are competent. It seems I get no where in resolving this issue. I have added a competence column to the current training ledgers. This still does not assure the competence.
More specific, in the 7.6.3.1 clause is states "The laboratory shall specify and implement, as a minimum, technical requirements for
Does this mean the auditee must specify how they determine competence in a procedure or lab scope? Or is it enough for them to explain to me how they determine competence level?
Sorry I am so confused.....
John Broomfield
Sandy,
Start with the definition of competence. It comprises three parts:
  • Abilities (or innate attributes)
  • Skills
  • Knowledge
Often, job specifications* define these three in order to recruit the competent people or at least the people who have the required abilities. Trying to impart skills and knowledge in people who not have the ability is a waste of time and money.
Supervisors usually are clear on the competencies they require and would not be upset being asked to define them; then you can ask where these are documented. I would not talk in terms of "levels".
Does the person who owns the recruiting and training processes have these specifications? If not how do these processes result in the compencies required by the lab?
* example: http://www.ok.gov/opm/jfd/x-specs/x13.htm
John
SandyStarkie
Thank you again John. This was very helpful information. I will improve our training processes based on better understanding. :)
antoine.dias
Hi Everyone,
What is your interpretation of "Review of the related records" in 7.6.3.1 ?
What should be done to fulfil this and how can it help the lab process?
We had a discussion about it internally and want to know your opinion about it.
Thanks in advance
John Broomfield
Hi Everyone,
Thanks in advance
Antoine,
Managers review the work and records to see how well their management system is helping people to do good work.
They do this to determine:
1. The adequacy or effectiveness of procedures,
2. The ability of staff to do their jobs well,
3. Their understanding of the essential abilities, skills and knowledge (to recruit further staff as required),
4. The proper provision of testing services including, as applicable, sampling, sample prep, set-up of equipment, conduct of the test, recording data, analyzing data and reporting results,
5. The capability of equipment to measure traceable to applicable standards,
6. Any needed preventive action,
7. Any needed corrections,
8. Any needed corrective action.
As you can see this, and listening to staff, is basic supervisory management.
John
MWR4QA
Trying to prove someone is competent on the front end is difficult. A person can have impressive credentials and experience and still commit errors. And therein lies how auditors determine competence.
In my experience...
If your MTE management system is in good order, if there are no product issues traceable back to MTE being incorrectly calibrated, if MTE reviewed during the audit are within the calibration dates auditors will usually not dig. In auditing, "If there's no smoke, there's no fire." is a pretty good rule of thumb.
JoShmo
"Trying to prove someone is competent on the front end is difficult."
Not at all. If you go by the definition of competency it becomes a lot easier. Competency is defined as "the demonstrated abilty to apply skills and knowldege. If you know what a job requires from someone, why can't they be asked to demonstrate their knowledge and skills and have that observed? If you take a driving test your not experienced, by definition, but you have to demonstrate to a tester.
S Internal Auditing Requirement for TS 16949 Certification (Registration) IATF 16949 - Automotive Quality Systems Standard 3
Crusader Internal Auditing for ISO/TS-16949 - Quality Digest article May 2006 General Auditing Discussions 1
J Auditing other plants of the multinational - ISO TS 16949 Internal Audits IATF 16949 - Automotive Quality Systems Standard 6
F ISO/TS 16949 - Auditing supporting activities IATF 16949 - Automotive Quality Systems Standard 1
Q Which ISO/TS 16949 clauses are applicable to auditing Quoting and Sales? IATF 16949 - Automotive Quality Systems Standard 19
S Auditing Transportation/Logistics to TS 16949 Requirements Quality Manager and Management Related Issues 3
Q ISO/TS 16949: Requirement for Auditing the Sub-Supplier IATF 16949 - Automotive Quality Systems Standard 6
P Problems with TS 16949 CSR (Customer Specific Requirements) Auditing General Auditing Discussions 3
T TS 16949 is a way of Eliminating each of your Customers Auditing you - Need to Vent IATF 16949 - Automotive Quality Systems Standard 40
P Auditing CSR (Customer Specific Requirements) during TS 16949 Audit IATF 16949 - Automotive Quality Systems Standard 17
W Auditing multiple standards - TS 16949, ISO 14001 & OHSAS 18001 General Auditing Discussions 12
P Certification Body Auditor Competency Criteria for Auditing to ISO/TS 16949:2002 General Auditing Discussions 8
C Auditing a Tooling Shop - Does that area need to be audited to TS 16949 IATF 16949 - Automotive Quality Systems Standard 2
D Auditing 2 standards with 1 audit? TS 16949 and ISO 9001 Registrars and Notified Bodies 5
V Registrars auditing to the spirit of TS 16949 The Reading Room 14
B Systems Auditing (TS 16949) - Example of an effective systems audit IATF 16949 - Automotive Quality Systems Standard 2
V Auditing TS 16949, Section 6.3 for information systems General Auditing Discussions 5
A Seeking Checklist for Auditing 7.3 Design Development for TS 16949 - pls help! Design and Development of Products and Processes 2
T Auditing Process and System to TS 16949 - SMMT Industry General Auditing Discussions 7
N TS 16949 and Process oriented auditing IATF 16949 - Automotive Quality Systems Standard 1
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
R Auditing COT's Suppliers / First Post Supplier Quality Assurance and other Supplier Issues 2
K ISO 9001 Auditing in a Healthcare setting Process Audits and Layered Process Audits 15
H Auditing Santa's workshop General Auditing Discussions 0
C List of MDSAP Auditing Organizations Medical Device and FDA Regulations and Standards News 1
cscalise Suggestions for MDR Auditing tools EU Medical Device Regulations 1
J Auditing of Support Function IATF 16949 - Automotive Quality Systems Standard 9
D ISO 13485, FDA 21 CFR 820 and Auditing the Accounting Department ISO 13485:2016 - Medical Device Quality Management Systems 5
S Risk based internal auditing Internal Auditing 6
Randy Remote auditing (for disaster, disease, disturbance etc...) during the Neo Coronavirus Pandemic and Social Distancing Registrars and Notified Bodies 7
K ANVISA B-GMP Auditing requirements for Contract Manufacturers Other Medical Device Regulations World-Wide 1
F AS9100D Internal auditing requirements Internal Auditing 11
R Does any here use an internal auditing tool that works on different platforms? Internal Auditing 3
W Does anyone have an API Q2 checklist for internal auditing? Oil and Gas Industry Standards and Regulations 1
G Best Practices for IT auditing - Is a session-id necessary for a complete audit trail? IEC 27001 - Information Security Management Systems (ISMS) 0
I Questions to ask when auditing for Organizational Leadership and Planning for the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C CE marking for general IVD (self-certified) & ISO 13485 QMS requirements - auditing EU Medical Device Regulations 6
blackholequasar Internal Auditing Inspiration - Getting volunteers to perform internal audits. Internal Auditing 22
W Internal Auditing carried out by a 3rd party - Review of previous audits AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
tony s What is the automotive process approach for auditing? IATF 16949 - Automotive Quality Systems Standard 2
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
R I've been auditing for a CB for 18 years General Auditing Discussions 10
P Consultant Auditing Qualifications Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
E Informational Internal Audits - Wear multiple hats what can and can't I audit (so I'm not auditing my own work) Internal Auditing 149
M We still have not received our certificate due to a 'backlog' with our auditing body Registrars and Notified Bodies 25
N Online Internal Auditing Course for ISO 13485 - Suggestions ISO 13485:2016 - Medical Device Quality Management Systems 8
A Agenda for 8D audit on Supplier's side - Auditing Corrective Actions General Auditing Discussions 5
U Internal auditing - Company employees or contract second party Internal Auditing 10
