Auditor found Form with Identical Contents but different Format - is this an NC?
QATN11
During an audit, two versions of the same form are found. All questions and content are identical; however, the format is different. Is this a non-compliance? major? minor? observation? The issue resulted from a form format that existed prior to addition of revision number and date was added was used and completed; therefore, a controlled record was created. The annotated form questions and content are identical to the form without date/version footer.
Auditor stated this was a major noncompliance. Counter argument was content should have priority over format and this should not be a major NC ("a pervasive and systemic error" auditor's wording), but rather an observation, or minor(isolated) NC.
I would appreciate feedback.
harry
Re: Audit found Form with Identical Contents but different Format - is this an NC?
1. Is this an internal audit or a third party audit.
2. Were there evidence that there were other forms of a similar nature to conclude that this is a 'systemic' issue?
3. Generally, an internal audit is for improvement purpose. An NC is an NC and it is quite meaningless to classify it as major or minor. Carry out the necessary investigation and take appropriate action such as correction for isolated events and corrective action for recurring events and improved from there.
4. Assuming this to be a systemic issue and hence evidence of weaknesses in your Document Control, third party auditors will usually consider the possible damage it can create. I don't think a 'format' issue will result in a major for most auditors that I know
5. However, I do know of a few dinosaur auditors over here who were from the 'write what you do and do what you write' era that will jump on you for this one.
P
Peter West
Hi QATN11
At first reading i thought a major nonconformance was way over the top. If it was one document used by one person amidst 100 documents used by 100 people its a minor at best.
Harry has made some good points, but what really stood out was if the issue was systemic (indicating that the process for controlling documents had repeatedly failed). Were there any other identified issues relating to document control? How do you communcate changes to documents and ensure only the most up-to-date templates are available? We use our company intranet so that if this arises the primary cause is down to the individual (training tells them to refer to intranet too).
If it is a 1-off (1 person from a big group, 1 time, 1 office) then I would consider it barely grades as a minor. If there are more instances (more than one person doing this, more than one document, a failure in training) then a major should be expected IF the outcome would have a serious impact on the service/product delivered or if it would be picked up by a systems audit or management review etc.
I would rate at minor from info i have at the moment, with a subsequent major if clear close out and root cause resolution was not evident.
Good luck
Marc
<snip> The issue resulted from a form format that existed prior to addition of revision number and date was added was used and completed; therefore, a controlled record was created. The annotated form questions and content are identical to the form without date/version footer.<snip>
Did this happen because you had printed paper forms that you were using to "use up" the old paper forms after you switched to the new form with the date and version in the footer?
I bring this up because many times a company will have paper forms which they make minor (inconsequential) change(s) to, but have a lot of the older format forms already in stock. Rather than throw them away, they use them until they are gone. If so, as long as everyone knows this is happening it shouldn't be a problem.
If a CB auditor found this, then they clearly need to get a life! A major? Not in this life... What they SHOULD have done is investigated some more and determined what happened to have the situation, to at least be helpful.
If it were an internal audit, then firstly, there's no point in grading the thing. It doesn't read like a major, and management are going to shrug their shoulders in confusion/apathy/indifference...
Too many auditors get excited over documents! Who cares, really? The same data was recorded? Was the data any good? What happened as a result of duplication? Did it affect anything which was delivered to the customer? Risk, anyone?
IMHO, this type of finding is what constantly undermines the credibility of audits (and auditors) as a management tool...
QATN11
1. 3rd Party
2. No other evidence of a systemic issue. Auditor stated his only choices were "systemic" or "Isolated". 2 records of the odd form were used and conclusion was 2 indicated "systemic". Our rebuttal, was the occurrence was "isolated" since the 2 records were used at the same time and not spaced over a period of time.
3. Data was good and no risk was exposed. Form was purely an informational survey and not product/performance related.
Sidney Vianna
Post Responsibly
I am clearly on your side on this issue. The proper categorization for this finding would be an observation. If all the important data was captured on the form, making it a valid record, the format is secondary. The fact that the auditor considers this a major nonconformity makes me wonder about his/her ability to appropriately assess evidence against criteria.
Without a doubt this nonconformity MUST be appealed. Not only the categorization of a major, but also the categorization as a nonconformity itself.
If possible, keep us posted.
Totally agreed, Sidney! Further more, when considered within the context of the total number of forms etc. this cannot be considered anything but a "found it, fix it" type of finding!
I'd also recommend that this 'major' (yeah, right!) be appealed directly with the technical staff at the CB. Based on what they reply with, you might wish to seek at least a different auditor...
I will take a different approach.
My first thought was the timeline. The question is what format was in play when the forms were filled out. Format 1 might have been the proper format when one was filled out, then later format 2 was issued and the second one was done on that. In that scenario, all would be normal.
However.....
If you are allowing two separate formats to be used in your organization, you are openening yourselves up for some real trouble. If folks know multiple formats are acceptable, the document control system can become casual. Format, revision level, document identification could all be compromised. You could very easily lose total control of your doc control. That is why I don't allow docuemnts (or gages) "for reference only". When we start allowing exceptions and multiple rules (including formats), then folks can get confused and the entire system could end up with the perception of being meaningless.
D What should the QMS Auditor do if a Major Nonconformity is found during an Audit? Internal Auditing 11
S External Auditor Findings when an Internal Audit found a Nonconformance Yesterday Document Control Systems, Procedures, Forms and Templates 11
W Redacting Info Before Giving to Auditor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Quality auditor legal right to see Board meeting minutes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
V Internal Auditor Competency KPI IATF 16949 - Automotive Quality Systems Standard 14
R American Petroleum Institute - Becoming an API Auditor Professional Certifications and Degrees 2
B Lowest cost way to pass Lead Auditor exam ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Internal Auditor Competency - Product Auditors Internal Auditing 9
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
Z Auditor Findings ISO 14001:2015 vs. 45001:2015 ISO 14001:2015 Specific Discussions 6
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
A Becoming an ISO27001 3rd Party Auditor Career and Occupation Discussions 4
L ASQ's Biomedical Auditor Course Test ASQ - American Society for Quality 1
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
Gun46 ISO 9001 : 2015 Lead Auditor Exam General Auditing Discussions 16
K %GRR was between 10-30% so we have to have a "backup plan" per auditor IATF 16949 - Automotive Quality Systems Standard 15
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 17
R ISO 45001 Lead Auditor Exam paper Training - Internal, External, Online and Distance Learning 1
B Internal and external auditor competency to CSR's IATF 16949 - Automotive Quality Systems Standard 20
A Our auditor told if we didn't have a patent we would have to do a validation or verification ISO 13485:2016 - Medical Device Quality Management Systems 6
W Certification for IATF Lead Auditor will expire in 2020 IATF 16949 - Automotive Quality Systems Standard 2
D Impartiality of Internal Auditor ISO 9001/13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Ed Panek Auditor driving us nuts - ESD requirements ISO 13485:2016 - Medical Device Quality Management Systems 23
A OHSAS 18001 external auditor finding personal interpretation? Occupational Health & Safety Management Standards 5
S IRCA Lead Auditor training and Exam tips Training - Internal, External, Online and Distance Learning 5
L ASQ CBA biomedical auditor - CBA primer material is enough to study? ISO 13485:2016 - Medical Device Quality Management Systems 6
B VDA 6.3 Qualification as Process Auditor training course and exam VDA Standards - Germany's Automotive Standards 0
F ISO 21001 Educational Organizations Management - How to become an auditor Other ISO and International Standards and European Regulations 1
J Getting training either from ASQ or from SAI Global - ISO 9001 Lead Auditor training Training - Internal, External, Online and Distance Learning 1
P ASQ Certified Biomedical Auditor (CBA) Certification Preparation 2019 ASQ - American Society for Quality 3
M Medical Device Design Control Auditor Recommentations General Auditing Discussions 19
G Third party auditor mentions no grace period for calibration Calibration Frequency (Interval) 22
D Where (in US) can I get the VDA Auditor Edition book? VDA Standards - Germany's Automotive Standards 3
S AIAG CQI Auditor Qualification and 3rd Party Certification Requirements General Auditing Discussions 2
M IATF 16949 7.2.3 Internal Auditor Competency - Trainer's competency Internal Auditing 7
C Recommendations for UK-based ISO 13485 internal auditor training ISO 13485:2016 - Medical Device Quality Management Systems 1
Sidney Vianna AS9100 News July 2019 AAQG/RMC CB Auditor Workshop - Presentation Materials AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
D Scope of Facility - Our auditor asked us last week for our "Scope of the Facility" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A ISO 9001 lead auditor as Full time career India Career and Occupation Discussions 2
J Manufacturing Process Auditor Requirements - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 9
GreatNate ISO 9001:2015 Lead Auditor Course? (who to take with) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
A External Auditor issue with Internal Audits Internal Auditing 7
Q Internal Auditor competence for ISO 14001 ISO 14001:2015 Specific Discussions 11
S IATF 16949: Is "Certified" Internal Auditor mandatory? IATF 16949 - Automotive Quality Systems Standard 9
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
J Your opinion on the better training org for IATF16949 Internal auditor and Lead Auditor IATF 16949 - Automotive Quality Systems Standard 3
K Turtle diagram or process interaction chart - Making it easier for an auditor Process Maps, Process Mapping and Turtle Diagrams 23
