Auditor has requested that the granite table in the lab be Calibrated
mark_B
hi - my auditor has requested that the granite table in the measurement lab is calibrated. The actual measurement device (laser scanner) is calibrated. I've never known this before is the request valid. any thoughts / suggestions would be welcome.
Re: calibration
Surface plate calibration is the only sure way to know you are working with a level surface. Surfaces will wear after extended usage and should be maintained in order to provide accurate measurement results. There are many accredited vendors out there that will come in to your facility to ensure your surfaces are flat and even.
Hi and Welcome to the Cove!
Did your auditor "request" this action or write you a non-conformity?
Michael_M
What do you use the surface plate for?
Is the surface plate used when verifying conformity of at least one finished product?
The surface plate is typically treated as a measuring device if it is used as a means (or part of a means) to verify product conformity. We have an outside company come in once a year and resurface all the surface plates throughout the shop.
TWA - not the airline
If the laser scanner is the actual measuring device then you need to find out what this equipment requires regarding installation or from the MSA(what does the manual or the vendor say?).
JLyt207
We also have to calibrate our granites. It is one more source of variation. They do change over time. We use our 4 a lot. They do get their share of use and abuse.
somashekar
PRECISION GRANITE SURFACE PLATES
SPECIFICATIONS
FLATNESS TOLERANCE IN ?m FOR ACCURACY GRADE
SIZE OF
PLATE (in mm)
AS PER DIN 876:84
GRADE "00"
AS PER IS 7327-2003
GRADE "0"
GRADE "1"
GRADE "2"
GRADE "3"
Depends on the size and the grade. See the standard for details...
Also refer to HERE
FLATNESS TOLERANCE
The flatness deviation of a local area of 250 mm x 250 mm of the working surface shall not exceed :
1. 3.0 ?m for plates of Grade 00
2. 3.5 ?m for plates of Grade 0
3. 7.0 ?m for plates of Grade 1
4. 15.0 ?m for plates of Grade 2
5. 30.0 ?m for plates of Grade 3
Sean Kelley
A company I used to work for would have their granite tables verified and recalibrated as needed. The person that did this would apply various levels of abrasive material which would removed some of the top surface. The final step was a diamond power and he worked it around with a tool to make a very level surface. Depending on how bad it was and how accurate it needed to be he would work from 2-6 hours on a given table. Once done he would reseal the granite and perform final verification user a laser device. Sliding metal parts on the granite over time does change the flatness of it.
hogheavenfarm
I calibrate ours, it is on a 5 year schedule, it all depends on how much it is used. We have several smaller ones that are calibrated more frequently (2-3 years), the big table is used only by me, so I can extend it some. If high accuracy measurements are not required, you can use a portable cmm to validate it for flatness, at least to a degree. Like other measuring equipment, there is no sense calibrating to ten digits if you only need two. Establish your need first then apply the necessary calibration.
A Auditing Design Organization - Auditor has to audit 7.3 and 7.5.1 / 7.5.2 separately? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
GStough Has this happened to you? Internal Auditor challenges Lead Auditor Internal Auditing 17
A Auditor has rejected our in-house gage verification - Calibration in 17025:2005 ISO 17025 related Discussions 21
Ajit Basrur "Licensed" copy of ISO 9001 Standard During Audit - Has an Auditor Asked for Proof? General Auditing Discussions 44
H Auditor Opinion and consistency - Each auditor has different 'opinions' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
Randy The RAB has approved my advancement to EMS-Lead Auditor Miscellaneous Environmental Standards and EMS Related Discussions 2
W Redacting Info Before Giving to Auditor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Quality auditor legal right to see Board meeting minutes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
V Internal Auditor Competency KPI IATF 16949 - Automotive Quality Systems Standard 14
R American Petroleum Institute - Becoming an API Auditor Professional Certifications and Degrees 2
B Lowest cost way to pass Lead Auditor exam ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Internal Auditor Competency - Product Auditors Internal Auditing 9
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
Z Auditor Findings ISO 14001:2015 vs. 45001:2015 ISO 14001:2015 Specific Discussions 6
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
A Becoming an ISO27001 3rd Party Auditor Career and Occupation Discussions 4
L ASQ's Biomedical Auditor Course Test ASQ - American Society for Quality 1
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
Gun46 ISO 9001 : 2015 Lead Auditor Exam General Auditing Discussions 16
K %GRR was between 10-30% so we have to have a "backup plan" per auditor IATF 16949 - Automotive Quality Systems Standard 15
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 17
R ISO 45001 Lead Auditor Exam paper Training - Internal, External, Online and Distance Learning 1
B Internal and external auditor competency to CSR's IATF 16949 - Automotive Quality Systems Standard 20
A Our auditor told if we didn't have a patent we would have to do a validation or verification ISO 13485:2016 - Medical Device Quality Management Systems 6
W Certification for IATF Lead Auditor will expire in 2020 IATF 16949 - Automotive Quality Systems Standard 2
D Impartiality of Internal Auditor ISO 9001/13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Ed Panek Auditor driving us nuts - ESD requirements ISO 13485:2016 - Medical Device Quality Management Systems 23
A OHSAS 18001 external auditor finding personal interpretation? Occupational Health & Safety Management Standards 5
S IRCA Lead Auditor training and Exam tips Training - Internal, External, Online and Distance Learning 5
L ASQ CBA biomedical auditor - CBA primer material is enough to study? ISO 13485:2016 - Medical Device Quality Management Systems 6
B VDA 6.3 Qualification as Process Auditor training course and exam VDA Standards - Germany's Automotive Standards 0
F ISO 21001 Educational Organizations Management - How to become an auditor Other ISO and International Standards and European Regulations 1
J Getting training either from ASQ or from SAI Global - ISO 9001 Lead Auditor training Training - Internal, External, Online and Distance Learning 1
P ASQ Certified Biomedical Auditor (CBA) Certification Preparation 2019 ASQ - American Society for Quality 3
M Medical Device Design Control Auditor Recommentations General Auditing Discussions 19
G Third party auditor mentions no grace period for calibration Calibration Frequency (Interval) 22
D Where (in US) can I get the VDA Auditor Edition book? VDA Standards - Germany's Automotive Standards 3
S AIAG CQI Auditor Qualification and 3rd Party Certification Requirements General Auditing Discussions 2
M IATF 16949 7.2.3 Internal Auditor Competency - Trainer's competency Internal Auditing 7
C Recommendations for UK-based ISO 13485 internal auditor training ISO 13485:2016 - Medical Device Quality Management Systems 1
Sidney Vianna AS9100 News July 2019 AAQG/RMC CB Auditor Workshop - Presentation Materials AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
D Scope of Facility - Our auditor asked us last week for our "Scope of the Facility" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A ISO 9001 lead auditor as Full time career India Career and Occupation Discussions 2
J Manufacturing Process Auditor Requirements - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 9
GreatNate ISO 9001:2015 Lead Auditor Course? (who to take with) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
A External Auditor issue with Internal Audits Internal Auditing 7
Q Internal Auditor competence for ISO 14001 ISO 14001:2015 Specific Discussions 11
