Auditor Sued for Damages, for Failure to Warn of Process Risk
MIREGMGR
#21
Was this firm an auditing firm or was it a consulting firm?
This regulatory law blog http://www.fdalawblog.net/fda_law_b.../10/jensen-farms-sues-auditor-primuslabs.html seems to say that the Jensen perspective is that the auditor was expected by them to provide advice.
Lay persons might think that an auditor would be there to "make sure that everything was safe" or whatever, but those of us in the regulatory community probably would agree that auditors usually audit for conformance to one or more particular standards or rule-sets, and that what a third party auditor is there to do is (always?) defined as part of their establishing business agreement. I haven't seen anywhere yet a specific statement as to what standard the auditor was auditing to.
It'll be interesting to see if the courts adopt the "auditors make sure that everything is safe" perspective.
treesei
#23
I agree. For example, an auditor would review sterilization validation records against validation procedures and plans etc. to see if they satisfy an ISO standard. However, the auditor usually is not in position to judge whether the validation itself is technically adequate. He is there to check the effectiveness of the quality system not the technical decisions. This melon case may be a little special because it is almost common sense. And if you go deep with the HACCP decision tree, you may find the process inadequate. However, I don't know the details of the audit. Iit would be very interesting to see how the court rules.
Wes Bucey
#24
For my part, what's the big deal about washing melons at the farm? I consider the entire supply chain from farm to table in my thinking and can imagine a number of way stations where the outside of melons can pick up contamination, but I don't eat the rind of a cantaloupe. Therefore, cutting the melon introduces the possibility of having the knife blade carry outside contamination into the flesh of the melon.
For the last sixty years or so, I've been washing off the surface of fruits and vegetables right before slicing. I wash the blade of a knife before using it on another food. Any fruit or vegetable can pick up contamination from the environment or from storage and handling anywhere along the supply chain to the table.
Some growing practices introduce higher likelihood of dangerous bacteria (organic fertilizers) or toxins (chemical fertilizers, insecticides) which are not easily washed off with plain water. The end consumer has no way of knowing whether such dangerous contamination has occurred. A reasonable assumption is to prepare food in such a way to reduce the possibility of carrying contamination from the surface to the the part to be consumed.
The fact these farmers are making a plea deal merely means they and their attorneys find it less "risky" to take a negotiated deal than to take an expensive chance on a trial. It does not necessarily mean their method was illegal, only that it was a bad choice in light of subsequent events, since there is no regulation mandating chlorinated rinse in EVERY growing operation. I'm pretty sure my suppliers at the local farmer's market are not washing produce in specially chlorinated water (other than normally chlorinated tap water straight from the faucet or non-chlorinated water straight from their well.)
MIREGMGR
#25
I'm not an HACCP expert, but my understanding is that for some food operations HACCP is legally required. That of course comes from the difference between the world of standards and the world of FDA.
That, I think, will be a legally and practically important factor in the judicial resolution of the matter at hand.
MIREGMGR
#26
...the auditor usually is not in position to judge whether the validation itself is technically adequate. He is there to check the effectiveness of the quality system not the technical decisions.
Interestingly, some standards are audited by subject matter experts, specifically so that they are able to judge the technical decisions. ISO 11135-1 (EO sterilization), for instance, normally is audited not just by a "normal" auditor, but also by a qualified microbiologist. It is normal for such microbiologists to get deep into the technical validity of the audited party's understanding and application of the standard's goals and purposes...not just the documentation of conformance to the precise wording in each standard-clause.
In USA, the organization with responsibility for sterilization standards is AAMI. I recently attended a three-day AAMI seminar on industrial EO sterilization--for practitioners, not auditors--at which the three instructors all were microbiologists by training, and about 3/4 of the attendees (typically with full or shared responsibility for their company's sterilization activities) also were microbiologists. It was made very clear during the seminar, for those that didn't already know, that audits in this area were driven by technically proven safety and effectiveness, not solely by the standard.
Wes Bucey
#27
I came across a pdf file from University of California (Davis campus) which describes pre- and post-harvest safety guidelines for produce. This DOES describe "chlorinated" water and monitoring of same for washing. The LINK from which the following excerpt is taken
Use only clean and sanitary field containers.
Continuously monitor chlorine concentrations and pH of hydrocooling or
wash water.
Clean and sanitize field tools. containers and packing lines on a
frequent and scheduled basis.
Clean and sanitize forced air coolers, cold storage rooms and cooler
drain tiles on a frequent and scheduled basis.
Clean and sanitize transport trucks on a frequent and scheduled basis.
Only use cleaning compounds and sar.itizers that are approved for food
contact surfaces.
Use transportation that is dedicated to hauling only produce. Do NOT
use trucks which have been used to transport live animals.
However, these are ONLY "guidelines," NOT "regulations." Perhaps someone can steer us to a regulation and its penalty if not followed which applies to using chlorinated wash water for cleaning produce at the grower (versus in a food establishment which prepares produce for consumption.)
Wes Bucey
#29
This FDA document http://www.fda.gov/Food/GuidanceReg...nformation/ProducePlantProducts/ucm278456.htm was published after the cantaloupe incident in question, in response to it, but it contains links to the prior-existing regulations and "guidances" relevant to the matter.
Right! I've seen this, too. My question (and the issue) is not whether there are "guidelines" (lots of those), but whether there is ANY regulation which mandates washing fresh produce with chlorinated water, thus exposing one to either criminal or civil penalty by a government agency when the regulation is not followed. In the absence of the regulation, the imbroglio just becomes one of "personal judgment" in determining whether water needed to be additionally chlorinated and monitored.
In MY judgment, it would be a good idea to use the chlorinated water, but ALSO my inclination to make a point of it in my marketing (like putting "all natural ingredients" on a label) to justify a premium charge to cover the cost in the same way organic produce commands higher price at the market.
Sadly, it all boils down to a mundane "risk assessment" which depends on the personality of the assessor to accept or avoid risk.
#30
I think the criterion needs to be whether or not the produce is contaminated, not whether or how it's washed, unless the washing solution is expected to have an extended antimicrobial effect. Even then, it seems like what was missing was testing for the presence of potentially harmful microbes. The two brothers who ran the farm have been charged with releasing contaminated food into interstate commerce, not with failure to use chlorinated water.
W Redacting Info Before Giving to Auditor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Quality auditor legal right to see Board meeting minutes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
V Internal Auditor Competency KPI IATF 16949 - Automotive Quality Systems Standard 14
R American Petroleum Institute - Becoming an API Auditor Professional Certifications and Degrees 2
B Lowest cost way to pass Lead Auditor exam ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Internal Auditor Competency - Product Auditors Internal Auditing 9
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
Z Auditor Findings ISO 14001:2015 vs. 45001:2015 ISO 14001:2015 Specific Discussions 6
B IATF16949 audit requirement - Auditor request UCL and LCL must be show Xbar-R, IATF 16949 - Automotive Quality Systems Standard 7
A Becoming an ISO27001 3rd Party Auditor Career and Occupation Discussions 4
L ASQ's Biomedical Auditor Course Test ASQ - American Society for Quality 1
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
Gun46 ISO 9001 : 2015 Lead Auditor Exam General Auditing Discussions 16
K %GRR was between 10-30% so we have to have a "backup plan" per auditor IATF 16949 - Automotive Quality Systems Standard 15
S ISO 13485 Lead Auditor - Debate between our Quality Team and Regulatory Auditor - Internal Auditor Training ISO 13485:2016 - Medical Device Quality Management Systems 17
R ISO 45001 Lead Auditor Exam paper Training - Internal, External, Online and Distance Learning 1
B Internal and external auditor competency to CSR's IATF 16949 - Automotive Quality Systems Standard 20
A Our auditor told if we didn't have a patent we would have to do a validation or verification ISO 13485:2016 - Medical Device Quality Management Systems 6
W Certification for IATF Lead Auditor will expire in 2020 IATF 16949 - Automotive Quality Systems Standard 2
D Impartiality of Internal Auditor ISO 9001/13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Ed Panek Auditor driving us nuts - ESD requirements ISO 13485:2016 - Medical Device Quality Management Systems 23
A OHSAS 18001 external auditor finding personal interpretation? Occupational Health & Safety Management Standards 5
S IRCA Lead Auditor training and Exam tips Training - Internal, External, Online and Distance Learning 5
L ASQ CBA biomedical auditor - CBA primer material is enough to study? ISO 13485:2016 - Medical Device Quality Management Systems 6
B VDA 6.3 Qualification as Process Auditor training course and exam VDA Standards - Germany's Automotive Standards 0
F ISO 21001 Educational Organizations Management - How to become an auditor Other ISO and International Standards and European Regulations 1
J Getting training either from ASQ or from SAI Global - ISO 9001 Lead Auditor training Training - Internal, External, Online and Distance Learning 1
P ASQ Certified Biomedical Auditor (CBA) Certification Preparation 2019 ASQ - American Society for Quality 3
M Medical Device Design Control Auditor Recommentations General Auditing Discussions 19
G Third party auditor mentions no grace period for calibration Calibration Frequency (Interval) 22
D Where (in US) can I get the VDA Auditor Edition book? VDA Standards - Germany's Automotive Standards 3
S AIAG CQI Auditor Qualification and 3rd Party Certification Requirements General Auditing Discussions 2
M IATF 16949 7.2.3 Internal Auditor Competency - Trainer's competency Internal Auditing 7
C Recommendations for UK-based ISO 13485 internal auditor training ISO 13485:2016 - Medical Device Quality Management Systems 1
Sidney Vianna AS9100 News July 2019 AAQG/RMC CB Auditor Workshop - Presentation Materials AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
D Scope of Facility - Our auditor asked us last week for our "Scope of the Facility" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A ISO 9001 lead auditor as Full time career India Career and Occupation Discussions 2
J Manufacturing Process Auditor Requirements - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 9
GreatNate ISO 9001:2015 Lead Auditor Course? (who to take with) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
A External Auditor issue with Internal Audits Internal Auditing 7
Q Internal Auditor competence for ISO 14001 ISO 14001:2015 Specific Discussions 11
S IATF 16949: Is "Certified" Internal Auditor mandatory? IATF 16949 - Automotive Quality Systems Standard 9
S Internal Auditing for API Spec Q1 - auditor qualification requirements Oil and Gas Industry Standards and Regulations 6
J Your opinion on the better training org for IATF16949 Internal auditor and Lead Auditor IATF 16949 - Automotive Quality Systems Standard 3
K Turtle diagram or process interaction chart - Making it easier for an auditor Process Maps, Process Mapping and Turtle Diagrams 23
C TL-9000 Certifying Body Issue - Auditor failed to find an issue for 10 years TL 9000 Telecommunications Standard and QuEST 16
C Advice on becoming a AS9100 Auditor - Need to audit organizations that are Design Responsible AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
