Auditors Auditing Against ISO 9001:2015 Draft
TPMB4
#12
Stupid question from a novice, what is the value that is added by auditing against a draft standard that has not been issued and might never be issued as the current draft? I don't get it.
Also, I understand with each ISO 9001 version you get a transition period equal to one certificate cycle (3 years). I could be wrong but that happened with 2000 and 2008 versions I think so why would it not with 2015 (or whenever it finally gets issued)? If it does allow for this transition period then surely there is no point or value to be added by auditing against the draft version? As I said, I just don't get it.
TPMB4
#13
+1 on the comments about contract and both sides agreeing to the audit method/standard used. They are providing a service to your company which is the customer and there will be a contract relating to this. Any deviation from the contract without agreement is against commercial law I think. If your bosses agreed to the deviation then you have to live with it for similar reasons, namely it is part of the contract both sides signed up to. More fool them if that happened but it is you who has to live with working to the current standard and to a draft standard too.
BTW how much different in real terms is the 2015 draft?? Would you say it is mostly equivalent to the current or has there been a game changer here?
rob73
looking for answers
#14
Tpmb4
For us its a major change, we have both 9001 and 13485, the new standard diverges from 13485 in a couple of major ways. When I showed a copy of the draft to our CB/NB auditor his initial opinion was that the two standards could not work side by side.
I would be certainly interested in the opinion of other in our position (i.e 9001 and 13485 certs)
Rob
Helmut Jilling
Auditor / Consultant
#17
Tpmb4
Rob
That's silly...13485 is based on ISO 9001....it is highly unlikely that they will not harmonize 13485 to it when the changes become finalized. Traditionally, the addon standards come out a year later. Also, in most cases, the updates don't contradict previous requirements. So, they will likely supplement current requirements in 13485. That sounds like foolish talk coming from an auditor, unless he read the draft and made his conclusion based on specific passages.
Helmut Jilling
#18
I have noticed that some auditors are already auditing against the committee draft of the ISO 9001:2015. Most of them classify the findings as observations.
In my opinion it's not right. The document is barely in its initial draft and findings like that may confuse people. What if some of those requirements don't make it to the final draft?
I don't know if you're seeing the same practice.
Auditing to the 2015 draft is not appropriate it is only a discussion draft and has not been authorized for certification. The language is not even final or voted on yet. Perhaps an interesting comment now and then, but I would NEVER write something like that in a report...An ANAB witness auditor would definitely take issue with that, as should the audit review panel at the CB.
Sidney Vianna
Post Responsibly
#19
Apparently you have not been following the News on the ISO 13485 revision - 2011 - 2012 (now 2014?) thread. One of our ISO 13485 resident experts in The Cove, and member of the ISO TC 210, has already mentioned that the upcoming version of the ISO 13485 standard will NOT follow the High Level Structure, thus, by definition, will not be aligned with ISO 9001:2015. How compatible will ISO 13485:2014 and ISO 9001:2015 be? Impossible to answer at this time, but it seems that they will significantly diverge from the current "alignment".
Similarly, a couple of people have already mentioned in this Forum that the ISO/TS 16949 standard is NOT going to remain aligned with ISO 9001. While that is unsubstantiated, at this time, there is a chance that several standards, currently using ISO 9001 as the baseline, stop doing so.
Helmut Jilling
#20
Apparently you have not been following the News on the ISO 13485 revision - 2011 - 2012 (now 2014?) thread. One of the ISO 13495 resident experts and member of the ISO TC 210 has already mentioned that the upcoming version of the ISO 13485 standard will NOT follow the High Level Structure, thus, by definition, will not be aligned with ISO 9001:2015. How compatible will ISO 13485:2014 and ISO 9001:2015 be? Impossible to answer at this time, but it seems that they will significantly diverge from the current "alignment".
You are correct, I don't follow 13485....it would be very surprising if they do not align... there is no logic to be a "standard," then unstandardize the standard. I suspect that will resolve itself over time, or they will decouple from ISO 9001 altogether.
On TS-16949, recently in July 2013 I was in a meeting with Dale Hammer, IAOB President, and he commented that he expects that TS will adopt the ISO 9001 changes, and do a release perhaps in 2016. That would be consistent with the pattern that ISO standards have followed.
B ISO/TS16949 Internal Auditing - How many auditors? Internal Auditing 4
B Food Safety: Who is Auditing the Auditors? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
P Are Canadian Auditors prohibited from Auditing U.S. based ITAR Companies? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M Internal Auditing Problems that Auditors Face Internal Auditing 16
S ISO 9001 prohibits auditors auditing their 'own work' while other standards don't? Internal Auditing 59
A Auditing the Internal Auditors and Management Review Internal Auditing 5
C Reference Guide for Process Auditors - Yet another Process Auditing Tool General Auditing Discussions 1
Jim Wynne International Differences in Third Party Auditing and Auditors General Auditing Discussions 63
R Changing auditors - How do I know I'm getting one experianced in auditing processes Registrars and Notified Bodies 7
R The Legal Aspects of Auditing - Risks that auditors may face and practices to avoid Registered Visitor Articles Archive 2
Marc IIA (Institute of Internal Auditors) Defines Internal Auditing Internal Auditing 25
M Do AS9100 Registrar Auditors have nonconformity quotas? General Auditing Discussions 18
B Internal Auditor Competency - Product Auditors Internal Auditing 9
M Question for Auditors - "Off the Record" Conversation? General Auditing Discussions 14
I What direction do you provide your internal auditors on OFIs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
M Choosing Auditors - ISO 9001 / ISO 27001 (UK) IEC 27001 - Information Security Management Systems (ISMS) 2
E Choosing an ISO 9001 registrar with auditors familiar with our industry Registrars and Notified Bodies 10
ScottK Question for Auditors on 7.1.4 in the ISO9001:2015 revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S MDR (Medical Device Regulations 2017/745) training recommendation for Auditors EU Medical Device Regulations 1
S How can we demonstrate to MDSAP auditors that we have the requisite training ISO 13485:2016 - Medical Device Quality Management Systems 9
M CB and Internal auditors most common nonconformities against AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
C Selecting potential internal auditors Internal Auditing 3
K Tips for dealing with third party auditors General Auditing Discussions 11
J ISO 9001 Competency - Forklift License and Internal Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
O How will you handle Clause 6.1 - Risks and Opportunities for AS9100 Rev. D Auditors? Risk Management Principles and Generic Guidelines 22
T Can a Lead Auditor Train other Auditors? Internal Auditing 4
A Professional Headhunters for External Auditors Career and Occupation Discussions 7
Sidney Vianna Auditors and CB's further investigating certified QMS' with ethical breaches? Registrars and Notified Bodies 8
W DCMA and AS9100C - Dedicating a week and 5 auditors to perform a AS9100C audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
Crimpshrine13 ISO/TS 16949 CBs & Auditors not following up on the schedules IATF 16949 - Automotive Quality Systems Standard 43
H Any ISO 9001 consultants/auditors in Oahu, Hawaii ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Subject Matter Expert Training for Auditors Internal Auditing 13
S Is it a Finding if all Internal Auditors are from the Quality Department? Internal Auditing 18
R Are ISO 9001 Lead Auditors in demand? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Number of Internal Auditors Best Practice Quality Manager and Management Related Issues 18
A Training Supplier Auditors ISO 13485:2016 - Medical Device Quality Management Systems 5
T Would my AS 9110 certificate lapse due to non availability of auditors ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
T Kids in the office from an auditors standpoint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Qualification System of Internal Auditors is not Effective General Auditing Discussions 5
S Internal Auditors shall not audit their own work? Internal Auditing 21
R Female auditors earn 18% less than male auditors - IRCA Salary Survey 2014 Career and Occupation Discussions 0
J Wanting to Train our Internal Auditors Ourselves Internal Auditing 7
S Recertification Frequency for TS 16949 Lead Auditors General Auditing Discussions 4
Sidney Vianna As a profession we, auditors, are not doing enough - Simon Feary speech Registrars and Notified Bodies 36
Ninja Blind Gopher Auditors Comment - Who is responsible? Registrars and Notified Bodies 23
R Auditors can NOT audit their own work audit finding Internal Auditing 17
Q Qualified Internal Auditors for AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
B API approved Auditors in India Oil and Gas Industry Standards and Regulations 3
M How to measure effectiveness and efficiency of the established QMS as Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
R Should internal auditors be compulsorily certified as internal auditors ? Internal Auditing 11
