Auto-Correlated Data and Capability Index
StatMan45
What pre-processing method(s) would you recommend to calculate the capability for a data set that follows an ARMA(2,2) process? Since there is significant positive correlation the variance will be underestimated and therefore will produce control limits that are too small. This data comes from a catalyst temperature with an upper limit only. The temperature of the catalytic bed is determined by the reaction rate of SO2 -> S03. The concentration of SO2 is diluted to reduce the reaction and hence the temperature. The dilution is via a control loop, hence the ARMA behavior.
Stijloor
Comments anyone?
Thank you.
Stijloor.
bobdoering
Stop X-bar/R Madness!!
It sounds to me that you have a closed loop automated adjustment, which generally will generate a sawtooth chart and continuous uniform distribution (note - not discreet uniform distribution and not independent data, so typical capability calculations are not applicable.) For this (if that is true):
Capability= (tolerance)/(process variation)
or...for this case:
Capability=(USL-LSL)/(UAL-LAL)
where the adjustment limits (AL) are the upper and lower values where the closed loop system makes its adjustment.
StatMan45
Thanks for the reply. Yes, the process is under closed loop control but it is not a 'bang-bang' or on-off control as might be found with a home thermostat. It is either a proportional-integral or proportional only control so it will not have any action limits in the traditional sense. Since it is a digital controller it does have and update rate but it is fast enough to not be of concern.
The distribution is not uniform as you might suspect if the controller were being used in an on-off type mode. The distribution is left skewed and 'Johnson' transformable.
I guess the goal here would be to answer the question "What is the probability of exceeding the upper spec limit given the process." Usually this means estimating the distributional parameters and using them to answer the question.
If I do this with the Johnson transformation should I relate the probability to a sigma of a normal distribution?
bobdoering
If I do this with the Johnson transformation should I relate the probability to a sigma of a normal distribution?[/FONT
I would say if you have a good fit, then that would be a good estimate of the capability.
Automotive understands that the common capability indices are for bilateral normal distributions, and everything else has to be handled in a different manner. That can be construed to mean "as the customer wishes" and most will not have any idea what to do except for transformation. So, that being the case, it should be as good of an estimate as any other single number to represent the ratio of the variation to the specifications of a process over time!
Good luck!
Transformation of the data is one option. Another option is:
  • Replace the mean in the Cp/Cpk formulae with the median
  • Replace 6s with the difference between the 0.99865 and 0.00135 percentiles
  • Replace 3s with the difference between the 0.99865 and 0.5 percentiles or the difference between the 0.5 and 0.00135 percentiles depending on whether you are calculating CPu or Cpl.
B HIGH QA Software - Auto ballooning software Quality Assurance and Compliance Software Tools and Solutions 2
G Auto electronic signature on Calibration Form ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
I Auto Industry Resume Template for a Quality Manager Career and Occupation Discussions 2
R Mobile Auto Valeting Services - Waste Disposal (Environmental Perspective) Miscellaneous Environmental Standards and EMS Related Discussions 3
Chennaiite Instruments used in Auto industry on which engraving is strictly prohibited? General Measurement Device and Calibration Topics 11
E Auto Populate Date and Time in an adjacent cell to one the user will complete..... Excel .xls Spreadsheet Templates and Tools 7
M Auto Parts Warehousing Facility ISO 14001 Significant Aspects ISO 14001:2015 Specific Discussions 23
S Internal Quality Audit Tracking Sheet with Auto Report Excel .xls Spreadsheet Templates and Tools 2
B List of all Auto Parts in a Commercial Vehicle Manufacturing and Related Processes 11
S Is ISO 50001 Certification useful for an Auto Components Manufacturer? Sustainability, Green Initiatives and Ecology 7
M Establishing a QMS - What Daily/Weekly/Monthly activities in Auto Industry IATF 16949 - Automotive Quality Systems Standard 4
W Excel Number Formatting - Auto Decimal Place by What You Type Excel .xls Spreadsheet Templates and Tools 16
M Mechanical Auto Repair Shop requires ISO 9001 Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M Microsoft Excel - Trouble with Auto-Entry of Dates Excel .xls Spreadsheet Templates and Tools 13
N Auto email reminder sent to customer - Calibration Due Notices Calibration and Metrology Software and Hardware 5
D SPC Software that will satisfy auto/furniture data submissions - Opinions wanted Quality Assurance and Compliance Software Tools and Solutions 5
H Auto Service Repair Shops in Michigan that are ISO 9001 Registered ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Excel Sheet Format for Assembly line rejection of Auto Parts Document Control Systems, Procedures, Forms and Templates 2
R Product (auto parts) manual example requested Quality Tools, Improvement and Analysis 1
Chennaiite Auto Expo in New Delhi Book, Video, Blog and Web Site Reviews and Recommendations 0
P RPS (Reference Positioning System) Measurement for Auto Parts General Measurement Device and Calibration Topics 8
Stijloor China emerges as world's auto epicenter World News 0
bobdoering Half of top U.S. auto parts suppliers at risk of bankruptcy World News 10
W U.S. Auto Suppliers Ask Treasury for $25.5 Billion Bailout World News 0
Stijloor Senate approves tax break for auto loan interest World News 11
P Auto - Lean Terms Lean in Manufacturing and Service Industries 0
bobdoering Auto Parts Makers - Key Plastics LLC and Special Devices Inc. File For Bankruptcy. World News 0
D How do I Auto fill colour on excel if certain risk criteria is met on PFMEA? Help! Excel .xls Spreadsheet Templates and Tools 13
J Auto Fair for 2008 Beijing World News 3
L Auto evaluation (No need for registration) to OHSAS 18001 Other ISO and International Standards and European Regulations 11
W Auto Makers Missing the Point? World News 6
Marc Toyota Passes GM To Top World Auto Sales For First Time World News 7
Marc Auto workers occupy Scarborough, Canada plant World News 0
Marc Luxury brands take beating in auto-reliability survey World News 13
Marc Fifth Largest Auto Industry Recall in U.S. History - Ford Trucks, Vans, SUVs World News 19
P Indian Auto major Tata motors planning to launch 2200USD cars World News 3
E QS 9000 Global Explanation - Sourcing manufacturers of auto parts Book, Video, Blog and Web Site Reviews and Recommendations 13
Marc As GM withers, so do US towns that once depended on auto industry World News 0
Marc Honda Accord Advanced Driver Assist System (ADAS) auto-pilot system World News 3
Marc Kraft Foods plans to slash 8,000 jobs - Auto, Food - What else??? World News 1
Marc First Chinese auto for sale in the US in Detroit auto show World News 0
T Movement of Auto Industry to the south in the US Career and Occupation Discussions 17
Marc 2006 North America International Auto Show - Picture Gallery World News 2
Q If iso 9001 registration is a mandatory, would... Japanese auto manufacturers pass? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
R Auto oil change engine problem Coffee Break and Water Cooler Discussions 12
Marc Ford's U.S. Auto Sales Fall - Toyota, Nissan Gain World News 1
Howard Atkins Valeo 5000, what is "quality auto-matrix" Customer and Company Specific Requirements 8
A Attribute vs. Variables Data - Variable data preferred over Attribute - Auto Industry Statistical Analysis Tools, Techniques and SPC 3
T Auditors and Auto Racing and Getting rid of all incompetent auditors General Auditing Discussions 15
G How many hours does it take the big 4 to build an auto? IATF 16949 - Automotive Quality Systems Standard 9
