Automotive Interior Trim - Vibration Standards - Anyone suggest One?
Manix
Get Involved!!!
HI all,
We are currently developing a product designed to be mounted to an automotive trim panel. I am having a hard time trying to stipulate some vibration requirements that the parts should withstand, as many OEM trim parts we have done before simply do not have vibration requirements stipulated at the part level. This would be done as an assembled set of trim together, usually by the customer.
We are keen to ensure that our new design can withstand the sort of vibration levels experienced with a vehicle interior environment and not start to rattle, squeak or even fall to pieces whilst in the field.
Does anyone know of an OEM specific specification that stipulates vibrations requirements for mounted trim panels? Does anyone indeed have any recommendations? All interior trim specs I have on file from OEMs take all other environmental exposures into account except vibrations!
I have plenty of vibration specs for chassis and body in white mounted parts, but these are a bit extreme! for an interior part.
Manix
Get Involved!!!
Hi Harry,
Thanks for that, but I am not sure I could warrant spending too much cash on a collection of specs such as this.
I will try and have a good look around the web again!
HI all,
It appears that you're interested in testing the thing you're making independently of it's end use, and that one concern is that it might "fall to pieces." Is it an assembly of some sort? Do you have the requisite test equipment? If so, why not just vibrate it to failure? That would at least give you some basis for a decision as to whether further investigation is necessary. If you don't have the equipment and you're planning on having the testing done by an independent source, that source can help you with the standards as well. In fact, you might want to query some local testing labs regarding the relevant standards, even if you plan on doing the testing yourself.
Manix
Get Involved!!!
Thank Jim, we do not have the required test facilities in house and the facility we usually use is a bit "give us the requirements and we will test them".
It is a plastic pod on a unique bracket that we have designed. The bracket can mount to a suitable trim panel by way of self tapping screws. It's not OE, but it will be subject to OE requirements, and it is the connection between the pod and the bracket that we are concerned with.
We could test it to failure, but there are many different severities of vibration tests, so I was trying to define the correct severity related to a are mounted on interior trim, as this is subject to much lower vibration than a part mounted on a vehicles chassis! As I am sure you will know.
It is more about the squeak thing really, as we are confident about the thing not falling apart, though there is always the possibility with a new design.
I will take your advice and enquire about requirements from a relevant test house.
Thanks again.
harry
I found out from another source the the NVH (noise,vibration & harshness) specs for the big 3 are as follows:
OEM Specifications:
• General Motors — GM6420M
• Ford — ESB-M6G17-A
• Chrysler — DCX Spec. MS-JZ8-22
I wonder if they contain the details you need.
C Automotive Interior Standards (Class A & B) - Defect Allowances for Interior Trim Customer and Company Specific Requirements 1
S An overview of the automotive safety requirements around the globe; interior products IATF 16949 - Automotive Quality Systems Standard 3
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
H Automotive wires - Compliance with USCAR21-4 & USCAR38-1 Various Other Specifications, Standards, and related Requirements 0
P Training department ideas and development for automotive supplier Training - Internal, External, Online and Distance Learning 6
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
K New supplier audit as per V3.1 by French Automotive OEM General Auditing Discussions 2
D Automotive Hospitality Consultant Career and Occupation Discussions 11
B Quality manual for automotive industry wanted Quality Management System (QMS) Manuals 2
G Handling Unpacked (Additive Chemical) Product For Automotive Applications IATF 16949 - Automotive Quality Systems Standard 3
T Ideas for developing a Supplier Quality Management System, non automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Sample size definition in an Automotive SMT pilot lot run Misc. Quality Assurance and Business Systems Related Topics 1
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
D O Ring capability and measurement - What is the automotive 'norm' for capability studies on O Rings? General Measurement Device and Calibration Topics 3
E Translating from Automotive to Medical Device industry - [email protected] Other Medical Device Related Standards 2
A The latest revision number and changes in automotive core tools IATF 16949 - Automotive Quality Systems Standard 1
R The alignments and contradiction in Quality Engineering and management between the Automotive and Aerospace industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
Q IATF 16949 certification without automotive products in "production" IATF 16949 - Automotive Quality Systems Standard 5
tony s What is the automotive process approach for auditing? IATF 16949 - Automotive Quality Systems Standard 2
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
eule del ayre List of Level 3 PPAP requirements for automotive suppliers APQP and PPAP 20
S IMDS=REACH for automotive industry? REACH and RoHS Conversations 3
E CSR SHIPPING - Need suggestions for making SOP/WI for our shipping dept (automotive)... Customer and Company Specific Requirements 11
qualprod What tier number fits in a company producing paper labels stuck on automotive parts? IATF 16949 - Automotive Quality Systems Standard 7
E Is there an Automotive Customer Complaint Index? IATF 16949 - Automotive Quality Systems Standard 3
S New to the automotive business and VDA VDA Standards - Germany's Automotive Standards 5
D Automotive Warranty Analysis Software Quality Tools, Improvement and Analysis 0
E Solder thermal profiles for PPAP - Automotive IATF 16949 - Automotive Quality Systems Standard 1
P Automotive Customer asking PPAP for catalogue parts IATF 16949 - Automotive Quality Systems Standard 16
A Should we do business in the automotive sector? IATF 16949 - Automotive Quality Systems Standard 7
O QRQC (quick response quality control) methodology in automotive industry IATF 16949 - Automotive Quality Systems Standard 3
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
I Making a process PFMEA, no DFMEA (non-automotive toll manufacturer) FMEA and Control Plans 1
V Paint batch approval procedure for automotive industry Manufacturing and Related Processes 6
D Introducing an existing product into automotive context - DFMEA needed? IATF 16949 - Automotive Quality Systems Standard 8
J IATF Minimum Automotive Quality Management System Requirements for Sub-Tier Suppliers IATF 16949 - Automotive Quality Systems Standard 12
J What classifies something as "automotive"? Looking for input? IATF 16949 - Automotive Quality Systems Standard 11
J IATF 16949 Cl. 8.4 - Externally provide process not for automotive part IATF 16949 - Automotive Quality Systems Standard 3
B Improper R&R Test? Downdraft Velocity in Automotive Spray Booths Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Approval of Supplier with ISO 9001 (Automotive) General Auditing Discussions 18
H Documentation Required by IATF 16949 (Automotive QMS) IATF 16949 - Automotive Quality Systems Standard 38
P Automotive Supplier PPAP Level Requirements Supplier Quality Assurance and other Supplier Issues 12
W Documented Problem-Solving for Automotive IATF 16949 - Automotive Quality Systems Standard 4
S Compliance to GADSL (Global Automotive Declarable Substance List) RoHS, REACH, ELV, IMDS and Restricted Substances 4
H FMEA for electrophoresis deposition of automotive parts FMEA and Control Plans 1
M The biggest gaps and problems in QMS or Quality in Automotive Misc. Quality Assurance and Business Systems Related Topics 3
M Please explain the following Automotive Acronyms IATF 16949 - Automotive Quality Systems Standard 3
D Clarification of Applicability of TS 16949 Requirements to a Non-Automotive Business IATF 16949 - Automotive Quality Systems Standard 13
